Old 01-07-2014, 10:52 PM   #1
lowranger
Member#: 124370
03 wrx stg 2.34159
Pro tuned by Cobb Tooning
First off, I have been searching and researching for the past few days and done (for the most part) research for the better/best turbo I could cram into the stock location.
My tuner suggests that the 20g XTR is the best bet for my car. But he also suggests that I do my research to make sure that is the turbo that fits my application.
Im also looking into the Dom 1.5 because thats the direction many people have been going lately, but still not neglecting the 20g. I'm not opposed to something similar to the 3071,3076, or any other of the Dom series. Just nothing with more lag.
Im asking because most applications that i have read are dealing with stock internals. I am not stock but im not all out completely built.
SUGGESTIONS!!
2003 hybrid swap
2.5, CP 100MM pistons with port matched heads.
Pauter Rods
COBB 1000CC injectors
255 fuel pump
Light weight pulley
Spearco TMIC (debating on going FMIC)
Stage 2 ACT clutch with LW flywheel
Sti u/p
TurboXS d/p + turbo back exhaust
I am currently tuned by Cobb.
Goal is as close to 400whp as i can. i think 375 whp is more reasonable but I've seen some great numbers closer to 400 on 93 pump. No E85. No meth. I understand i am still on the stock 5 speed. I do not shift hard for that reason and i do not launch the car. Plans for another transmission are down the road.
i may be forgetting something. PLEASE DONT FLAME!
Thanks and Gig'em
lowranger is online now   Reply With Quote
Old 01-07-2014, 10:53 PM   #2
lowranger
Member#: 124370
03 wrx stg 2.34159
Annddddd I wasn't sure if this goes here or built motor discussion. I did not see any turbo questions in the first few pages. Move if needed, sorry.
Old 01-08-2014, 01:06 AM   #3
umscooby
Member#: 50902
05 STi
Full Race up/down pipe with the borg warner 7163. Stock like spool and easily over 400whp on E85/race gas. Step into the future, spend the extra cash and be the envy of us 20g and 3076 guys.
Hands down best stock location turbo out right now.
umscooby is offline   Reply With Quote
Old 01-08-2014, 08:50 AM   #4
dstroy
Member#: 283711
2012 STI sedan
Black with scratches
Originally Posted by umscooby View Post
Full Race up/down pipe with the borg warner 7163. Stock like spool and easily over 400whp on E85/race gas. Step into the future, spend the extra cash and be the envy of us 20g and 3076 guys. Hands down best stock location turbo out right now.
$5000 later after you buy the turbo. Most ridiculously overpriced up/dp ever. And the turbos don't have investment cast housings anymore. More worth it to go rotated at that price point unless class regulations require you to have a stock location turbo.
Old 01-08-2014, 08:55 AM   #5
umscooby
Member#: 50902
05 STi
5k? way to over exaggerate the price. this is one of the guys i mentioned who will be drooling over your superior setup
Old 01-08-2014, 09:47 AM   #6
lowranger
Member#: 124370
03 wrx stg 2.34159
I would just got rotated then. But still no e85.
Most turbos will put me over 400 if I had e85.
Old 01-08-2014, 10:01 AM   #7
dstroy
Member#: 283711
2012 STI sedan
It's $4500 if you get everything coated and buy injectors. Without install labor. So no, I didn't exaggerate the price. And I would never drool over any stock location turbo unless it's a wormhole generator.
Old 01-08-2014, 10:16 AM   #8
BroBroBroBroBro
Member#: 338211
2011 wrx
if i had the money i would get the EFR 6258 even....just to experience that would be amazing.
BroBroBroBroBro is offline   Reply With Quote
Old 01-08-2014, 11:28 AM   #9
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Yimi Sport made 432whp 464wtq on the 6258 on E85...
2Fast4U1DAY is online now   Reply With Quote
Old 01-08-2014, 11:48 AM   #10
Leafy
Member#: 330625
2006 WRX
You should be able to do 400 on 93 with even the 6758, the 7163 should be near or over 450 on 93 safely, depending on compression ratio.
And yes, IMO the full race setup is mega overpriced. The downpipe is easier to make than the stock one (because its all round tubing), and the up pipe is no more difficult and even uses an easier/cheaper to source turbo flange. Even making the up pipe out of 321 stainless (like I would ****ing hope they do for that kind of money), and competent DIY fabricator with a tig welder could make these kits in their garage and sell them for $800-$1000 and make money hand over fist with each one.
Old 01-08-2014, 12:05 PM   #11
brooksumw89
Member#: 319266
2013 WRX
CBS
Since you are still on the stock 5 speed the dom 1.5 would probably be the best bet. It may still make the trans go (obviously sooner rather then if kept stock turbo). If 375 whp is more then reasonable that gets my vote. check out the ppb section, lots of dyno plots to show it is a very capable turbo.
brooksumw89 is offline   Reply With Quote
Old 01-08-2014, 12:15 PM   #12
lowranger
Member#: 124370
03 wrx stg 2.34159
If I was going to replace up and dp, I would just say screw it and go rotated. Would be worth it.
That's where I got my info with the Dom 1.5 is in the proven power. I'm just seeing what people think with better internals.
Hell, may just go rotated for end all be all
Old 01-08-2014, 01:40 PM   #13
brooksumw89
Member#: 319266
2013 WRX
CBS
I see that now, I guess I glanced over the up/dp replacement. If going that route then rotated wouldn't cost much more then you had planned so why not?
Old 01-08-2014, 02:17 PM   #14
lowranger
Member#: 124370
03 wrx stg 2.34159
Well for less then a rotated seyup, I could have my car on the street and tuned with say the 20g. Rotated is anywhere between 3400 and 4200 depending on where you buy the kit and what you get. Plus having to buy new exhaust and go fmic (which I should do anyways). So it will be a few thousand more.
Old 01-08-2014, 03:54 PM   #15
northman
Member#: 163631
07 Forester XT
Dom 1.5XT-R
Dom1.5 is a great turbo, but it is not really a 400 whp turbo, on pump gas. I'm guessing Cobb in Texas or SoCal will tune similarly to Cobb in Oregon, which should be a fantastic tune but not overly aggressive. I'm tuned at Cobb Surgeline with a Dom1.5 and make about 350 whp. Look at their Dyno Database, cars making closer to 400 tend to use E85, or run bigger turbos, or have cams and headwork.
If you want closer to 400 maybe look at the Dom3 or 3.5.
northman is offline   Reply With Quote
Old 01-08-2014, 04:23 PM   #16
subaru05sti
Member#: 214700
05 subaru STi
black on gold
These cars come with turbos?
subaru05sti is offline   Reply With Quote
Old 01-08-2014, 06:40 PM   #17
lowranger
Member#: 124370
03 wrx stg 2.34159
yeah i got the one that runs off T-rex bones
Old 01-08-2014, 06:43 PM   #18
lowranger
Member#: 124370
03 wrx stg 2.34159
and this is the type of answer im looking for. thank you
and yes, i am tuned by Cobb in texas
Old 01-09-2014, 12:07 AM   #19
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I run a 20g on my hybrid and it does 370whp on 91 and 398whp on meth. Hope that helps.
Old 01-09-2014, 10:07 AM   #20
lowranger
Member#: 124370
03 wrx stg 2.34159
That does since I have a hybrid. Thank yoh
Old 01-09-2014, 03:46 PM   #21
lowranger
Member#: 124370
03 wrx stg 2.34159
Anyone running the Dom 2.5 or dom 3.0? Seem to be putting down some good numbers.
Old 01-09-2014, 04:57 PM   #22
brooksumw89
Member#: 319266
2013 WRX
CBS
They do put down good numbers but if you're avoiding lag and trans problems I wouldn't
Old 01-09-2014, 05:56 PM   #23
lowranger
Member#: 124370
03 wrx stg 2.34159
From some of the dyno pulls I've seen, it's not terrible. I plan on putting a 6 speed in my car anyways.
Old 01-09-2014, 11:27 PM   #24
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I installed the dom 2.5 xtr on my stroker it was fun but my kinugawa 20g put down bigger numbers. Maybe the difference is the stroker and the hybrid.
Old 01-14-2014, 07:58 PM   #25
Cloud85
Member#: 378557
Does FP make anything that could help you get there? I know they make the Black, Red, and Green for the Evos.
Cloud85 is offline   Reply With Quote
