Old 01-05-2014, 05:38 PM   #26
Ram_Wrex
Member#: 377880
11 WRX
-49 degrees Celsius with the windchill this morning and it did not sound good lol. Couldn't let the clutch out for bout 30 seconds or else it would've stalled. Can't wait until this is over.
Ram_Wrex is offline   Reply With Quote
Old 01-06-2014, 10:21 AM   #27
C4RBON_F1BER
Member#: 208507
'15 BRZ
It was 12F in my garage this morning, and it started a little slower than usual. Its supposed to be -15F around the time I leave work... will be the coldest I've ever tried starting it.
C4RBON_F1BER is offline   Reply With Quote
Old 01-06-2014, 10:33 AM   #28
Scrappy_do
Member#: 376064
2007 WRX
this morning it was 10* F in my garage (judging by the indash temp meter). The car started up just fine, but did make a few rattles before it quieted down to normal.
This is the coldest temps we have seen in my lifetime (I'm 28) in this part of TN. So yeah, we are freaking out a little bit down here.
Scrappy_do is offline   Reply With Quote
Old 01-06-2014, 11:11 AM   #29
mejifair
Member#: 11356
2012 WRX STi Hatch
No kidding - this afternoon will be my first attempt at starting the car in -0 temps. I am sure there will be a whole lot of fun noises, and will be grimacing the whole time!
mejifair is offline   Reply With Quote
Old 01-06-2014, 11:21 AM   #30
phieleven
Member#: 108466
'98 GT & '95 LX
Outback BH & BP
I just make sure the tank is filled.
Let it idle before I go to bed, and when i Get up.
If it won't start, throw the magnet heater on it for awhile.
It's -20* right now, and I had no problem.
(I did take it around the block a few time last night, that helps.)
phieleven is online now   Reply With Quote
Old 01-06-2014, 11:29 AM   #31
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Bacon117 is offline   Reply With Quote
Old 01-07-2014, 12:28 PM   #32
Photog1
Member#: 359201
So that "banshee" noise on start up when its below zero is normal then?
Heres a video of someone else who's wrx is making the same noise as mine when its super cold:
Mine did it yesterday afternoon which was the first time driving it when it was below zero. It was minus 7 at the time. Freaked me out when I first heard it. Then again this morning. Normal?
The other thing I noticed were my brakes were super grabby this morning when I first started driving but returned to normal after a few miles.
Photog1 is offline   Reply With Quote
Old 01-07-2014, 12:37 PM   #33
cmiovino
Member#: 134005
2004 WRX Premium
My neighbor had a garage work light set out all night under his oil pan. It appears it made a difference as his car had no issues starting this morning. Probably a 100w bulb. First time I actually saw someone do that.
Related question: Can we see major problems from starting cars in super cold weather? Right now we're at about -5 here in Pittsburgh and last night my car started, but took a few cranks over, then started rough. It immediately was normal after that though.
I'll assume this is more wear on the battery and starter, but can there be any internal damage done by starting in cold temps, given your oil and filter and the correct viscosity and pressure?
Old 01-07-2014, 12:59 PM   #34
bebesito21
Member#: 176128
5862 ...baby boosted
Cold startup is the hardest time on your internals. The oil is too cold to do its job. Get a block warmer
bebesito21 is offline   Reply With Quote
Old 01-07-2014, 01:01 PM   #35
Ram_Wrex
Member#: 377880
11 WRX
Originally Posted by cmiovino View Post
My neighbor had a garage work light set out all night under his oil pan. It appears it made a difference as his car had no issues starting this morning. Probably a 100w bulb. First time I actually saw someone do that. Related question: Can we see major problems from starting cars in super cold weather? Right now we're at about -5 here in Pittsburgh and last night my car started, but took a few cranks over, then started rough. It immediately was normal after that though. I'll assume this is more wear on the battery and starter, but can there be any internal damage done by starting in cold temps, given your oil and filter and the correct viscosity and pressure?
I'm curious about this too. My car gets so cold that when I start it, I can't let off the clutch for like 30 sec or it would stall. That's only happened to me once though.
Old 01-07-2014, 01:05 PM   #36
tonytwopiece
Member#: 345715
1997 4runner
Desert Dune M
The work light under the oil pan trick sounds about right. It would probably keep the oil from getting as cold as the outside temps, making start up a little bit easier. May have to try that one tonite...
I also heard that banshee noise yesterday when I started my car. Rough idle and then it was fine. I imagine all cars are going to act bad at first, until the circulation starts and gets some heat going. My transmission was very stiff too. All to be expected in this weather. Come on weekend! May get a break by then...
tonytwopiece is offline   Reply With Quote
Old 01-07-2014, 01:26 PM   #37
trife86
Member#: 301368
PBP
Heres a video of someone else who's wrx is making the same noise as mine when its super cold: Video Link: http://youtu.be/rn58L1xwQew
Mine sounded just like that today. I assume it's normal, maybe turbo waiting to get oil? But it's not the first at least I'm not alone lol
trife86 is offline   Reply With Quote
Old 01-07-2014, 01:33 PM   #38
LUMBERZACK
Member#: 340009
2007 STi
48W
Glad that I don't have to put my car through any of this.
LUMBERZACK is offline   Reply With Quote
Old 01-07-2014, 01:34 PM   #39
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
It'll be 71 degrees here today.
That is all.
Gallo2011 is offline   Reply With Quote
Old 01-07-2014, 02:52 PM   #40
Bak3rSkat3r
Member#: 328769
2005 WRB WRX
2007 UGM 2.5i
Awesome snow and winter drifting in a subie = worth the cold weather
Bak3rSkat3r is offline   Reply With Quote
Old 01-07-2014, 03:29 PM   #41
Abgrooms
Member#: 298640
'14 WW Evo X GSR
Nitrous Rhodes
Heres a video of someone else who's wrx is making the same noise as mine when its super cold: http://youtu.be/rn58L1xwQew
I picked up my car last January. The next day, after driving home from the dealer, it was only 1* outside. It made that horrific noise and the TOB was chattering like crazy. I wasn't surprised by the TOB, but that start up noise was quite alarming. I quickly found out it was normal.
Abgrooms is offline   Reply With Quote
Old 01-07-2014, 04:13 PM   #42
dead_eye
Member#: 308265
2008 WRX
Originally Posted by Bacon117 View Post
Some subies have a clear flood mode. Floor it while cranking, and you get no fuel, perfect for priming the oil galleries.
I was under the impression all modern vehicles would fuel-cut if the pedal is floored when you turn the key and start ignition.
dead_eye is offline   Reply With Quote
Old 01-07-2014, 06:20 PM   #43
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
its pretty normal near 0 degrees. i get that noise, a whisting and some other weird noises when its real cold. also, 1st gear and reverse are a mf to engage too. my cars 6 years old this month and has always made those noises. i think your video is the power steering pump whining cause of cavitation.
424wrx is online now   Reply With Quote
Old 01-07-2014, 06:37 PM   #44
anonmassive
Member#: 158464
YER MOM
BLURPLE
I leave my cheap northern tool garage heater on all night. Start the cars about 15 minutes before we leave. Never an issue.
anonmassive is offline   Reply With Quote
Old 01-07-2014, 06:46 PM   #45
Blobeye95
Member#: 375547
2004 sti
jbp
I get that same noise too it's 4 degrees in central mass right now I hate the cold
Blobeye95 is offline   Reply With Quote
Old 01-07-2014, 10:53 PM   #46
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
His sounds like the power steering pump whining. Mine doesn't make that noise long, it sounds more like a bad idler pulley for a second. Sounds normal. Not much to do about it, it's too cold. Just pray nothing breaks.
Old 01-07-2014, 10:55 PM   #47
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Yea, I don't know for sure. My 02 doesn't. Maybe it's not modern enough. All gasoline Fords do, I know for sure. It's possible that all cars do.
Old 01-07-2014, 11:09 PM   #48
Turd Nugget
Member#: 346017
2013 STi Wagon
Mine makes that same exact noise, its pretty loud and can last probably 10 seconds or so although it feels like forever!
I chalk this up to being normal, when starting in sub zero temps, it sounds like the power steering pump. Kinda ****ty since the car is only 3 months old and making those horendous noises on startup but I know the dealer is going to tell me to pound sand if I complain about it.
Turd Nugget is offline   Reply With Quote
Old 01-08-2014, 08:47 AM   #49
jojo69
Member#: 309196
2012 Hatch
wrb
Banshee noise; Normal. I've had that sounds more days than not, especially when temps have been around 15 and below, which has been most nights here in Maine! Wish I had a garage...
jojo69 is offline   Reply With Quote
Old 01-08-2014, 11:53 PM   #50
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Same sound here around -30C. Plus a cacophony of 11 others, some of them being as if a chainsaw was going through glass. A while after, it purrs, normally.
