Old 01-06-2014, 10:42 AM   #1
nightmoves001
Member#: 218795
2004 WRX
RED
Default Alignment question?
Is a all wheel alignment necessary? I wanted an all wheel alignment and the guy at the shop said they didn't do it because it wasn't needed? Just did the fronts
Car still pulls left?
nightmoves001 is offline   Reply With Quote
Old 01-06-2014, 10:43 AM   #2
Dirty25RS
Member#: 56731
2004 STi, 00 Insight
10 Volvo C30R-d 11 F150
All 4 wheels can contribute to the car pulling one way or another so if a 2 wheel alignment didn't fix the pulling I'd suggest a 4 wheel alignment yes.
Dirty25RS is offline   Reply With Quote
Old 01-06-2014, 10:47 AM   #3
milab21
Member#: 157833
2007 WRB STI
I feel that it's needed for all 4 wheels...they can wear properly, what do they care if your paying for it?
milab21 is offline   Reply With Quote
Old 01-06-2014, 10:53 AM   #4
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
2 wheel alignments are dumb.
Old 01-06-2014, 11:34 AM   #5
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
People still do 2 wheel alignments in 2014?
Old 01-06-2014, 11:36 AM   #6
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Ask them for a thrust angle alignment.
Old 01-06-2014, 11:52 AM   #7
al_s14
Member#: 168077
Only time you need a two wheel alignment is on a solid rear end with no adjustments.
On any and all normal cars rear is set up first and front is matched up to it. If your ass is ****ed up and you set up your face to it, guess how well its going to come out.
Run Run away from that hillbilly hackafix if you know whats good for you.
al_s14 is offline   Reply With Quote
Old 01-06-2014, 11:52 AM   #8
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
You still need to reference the rear to thrust in the right direction.
Old 01-06-2014, 11:59 AM   #9
msy5286
Member#: 377629
2013 WRX
2013 wrx question - 4000 miles
Took the car in (dealer) for an alignment fix because it was drifting to the left and I had to slightly hold the wheel to the right - no pothole runs or damages btw.
After the fix, I have about 1/2 cm off center steering where I need to tilt the wheel slightly to the left. Is it worth taking it in the get fixed? If the wheel is perfectly straight, the car drifts to the right. I told the dealer this, and they said that because it is minor, it is usually due to the crown in the road. Is this accurate or should I expect to have a perfectly centered wheel?
msy5286 is offline   Reply With Quote
Old 01-06-2014, 12:01 PM   #10
Psychoreo
Member#: 79643
2015 WRX STI
Bring it back.
Old 01-06-2014, 04:58 PM   #11
nightmoves001
Member#: 218795
2004 WRX
RED
Thanks for the replies guys they'll help out when I go back to the shop.
Old 01-06-2014, 06:19 PM   #12
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
I had a dealer tell me that the bolts were frozen on the rear and that they expect they would break parts if I insisted on the rear being done.
I had them just do the front. But I had replaced a front control arm so that's all I really wanted anyways.
Old 01-06-2014, 07:50 PM   #13
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
They should at least check it... I went to bell tire for a 4 wheel alignment on my wifes truck, they put the sensors on all four wheels, but only the front were out of alignment. They didn't charge me for the full four wheel alignment. I thought that was cool.
Bacon117 is offline   Reply With Quote
Old 01-07-2014, 10:08 PM   #14
al_s14
Member#: 168077
Ofcourse, but all adjustments are done up front , so its still technicaly a two wheel alignment.
PS all modern machines require all 4 sensors on, it wont even let you go to adjustments or compensate till all of them are on. which leads me to believe they are likely using outdated "string" machines or worse....not the accuracy youd want on a sports car especialy if you enjoy long tire life
Old 01-07-2014, 10:58 PM   #15
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
You can adjust toe in the rear....
Old 01-07-2014, 11:14 PM   #16
al_s14
Member#: 168077
not on a solid axle, which was the initial example . come on bro pay attention
Old 01-08-2014, 12:31 AM   #17
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
... Got it. It's too cold for my brain to function.
Old 01-13-2014, 01:26 PM   #18
justlovejava
Member#: 378611
Would love to know if a 4 wheel alignment did the trick for you.
justlovejava is offline   Reply With Quote
Old 01-18-2014, 11:34 AM   #19
BassClefB
Member#: 324938
2008 Impreza 2.5i
Topaz Gold Metallic
Subarus = all-wheel symmetrical drive. All must be adjusted to ensure the car tracks properly and that the power is distributed as it should be. Not to mention the fact that if your alignment is way out of whack, it will eat up tires and possibly foul up the differentials along the way. My shop always gives me a computer printout of the before/after measurements so I can see exactly what was done and why - and it appears by this printout that toe, camber and thrust angle are all independently adjustable on the front and rear. You'd be crazy to only do 2 wheels with all those variables.
BassClefB is offline   Reply With Quote
