Old 12-30-2013, 10:43 PM   #76
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
Plugs are ngk iridium one step colders. Gapped to whatever they come.
codesbugeye is offline   Reply With Quote
Old 12-30-2013, 11:09 PM   #77
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Got a wideband? Bucking is usually a lean condition. Check fuel pressure also.
spoolinsti05 is offline   Reply With Quote
Old 12-30-2013, 11:55 PM   #78
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
No wideband... I need one but I would imagine.
Old 12-30-2013, 11:57 PM   #79
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
Its not bucking. Its just popping like a shotgun in wot only. I can gradually build boost and finally get to 75% throttle untill I get the pop. But when I wanna wot it from low rpm it does it.
Old 01-03-2014, 10:13 PM   #80
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
Could going from front mount to top mount caude this "lean" pop at higher rpms? I don't know about tuning so I have no clue if its sensitive to front mount or not.
Old 01-03-2014, 10:38 PM   #81
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Wouldn't a bad coil pack say misfire? Cause I have no check engine codes. And when I put it on a code reader nothing comes up.. I'm absolutely dumb founded with it. All the coil packs boots are perfect looking. No tears nothing..
People disable misfire codes sometimes on tuned cars.
Typical bad coil will run just fine at idle. It shows itself under load when coil pack can't keep up with needs of engine. Car will lay down under full load and run perfectly fine at 0 to partial load. I've only replaced probably 50 under these conditions and always fixed problem. A bad coil pack most times won't look any different than good coil pack. Visual inspection won't tell you anything most times.
bswilmington is offline   Reply With Quote
Old 01-05-2014, 01:57 AM   #82
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
So going from front mount to top mount wouldn't mess with the tune? And what if I get these coil packs and that doesnt fix it.
Old 01-05-2014, 02:03 AM   #83
missmysubie
Member#: 313857
07 STI LTD
(Mustang) 306/346 VF48
^ I think switching IC might mess with tune but find out for sure before you go that route.
I had similar issues with my STi last year with bucking and backfiring under boost. I used octane boost as a bandaid and it helped the problem for a few weeks. Finally had the car checked out and it turned out I had two issues:
(1)Failing boost control solenoid
(2)the tips of my spark plugs were corroded due to overuse of octane boost.
Had a Grimmspeed 3port installed, brand new NGK IX plugs and retune and all is right again. Needless to say i'm going to avoid using octane boost if I don't need it.
missmysubie is offline   Reply With Quote
Old 01-05-2014, 02:08 AM   #84
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
Crazy thing is.... I had the shop revworks In casselberry fl, install the grimmspeed 3 port before the tune. Took the car home after 3 hours of long tuning. Car was running fine the whole way, until last second it seemed like the wastegate was stuck open... upon futher investigation I found that revworks had the boost controllor set up backwards... after swapping it back to how grimmspeed says to install and going top mount I can't wot!
Old 01-05-2014, 02:23 AM   #85
missmysubie
Member#: 313857
07 STI LTD
you have an accessport?? I also had an 03 bugeye and I had an issue with the bcs.....the ecu seemed to not want to see boost so I had to go to manual boost controller. I was only seeing stock wastegate spring pressure. My tuner had set the wgdc to 0% if I remember correctly. Three bugeyes all had the same issues the same week I did so that was the fix discovered. Bugeye ran like a champ afterwards.
Old 01-05-2014, 02:26 AM   #86
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
No accessport... opensource tuned my mike adkins. Brand new ebcs 3 port.
Old 01-05-2014, 02:28 AM   #87
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
I'm ewg setup with a 14lb spring. Pushing 21 lbs. I get the lean sounding pop around 70% throttle and 18lbs.
Old 01-05-2014, 02:31 AM   #88
missmysubie
Member#: 313857
07 STI LTD
being that I had a similar experience with a bugeye, ask your tuner to see if the ecu is seeing boost. My bugeye's ecu didn't even register that it had a bcs. The issue might have come up on your drive home.... Just a suggestion.
Old 01-05-2014, 02:33 AM   #89
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
Yeah since I don't have a computer to hook up and pull data I'm set up an appointment with mike to pull a data log and possibly retune tuesday.. guess I just gotta wait.
Old 01-05-2014, 02:36 AM   #90
missmysubie
Member#: 313857
07 STI LTD
sorry I couldn't help ya more...only my experiences....definitely recommend an accessport....
Old 01-07-2014, 09:40 PM   #91
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
Took it to Revworks today to get a retune and see what its doing. After 2 hours of tuning they told me the wastegate is not even fully open until 26 lbs. So supposably I need a new wastegate to fix the pop. It amazes me how the wastegate can be causeing a pop especially when my boost gauge is only reading 16-18 when I get the pop. There's a 14 lb spring in it now.
Old 01-07-2014, 11:17 PM   #92
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
The ebcs hooked up wrong can do that. If it wasn't opening you will over boost. If it was stuck open you would have no power and a very loud turbo. If it wasn't opening on time you'd see a boost spike and it would fall off.
Old 01-08-2014, 12:20 AM   #93
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
Yeah mike looked over it before retune. Its hooked up how grimmspeed says.
Old 01-09-2014, 02:51 PM   #94
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
Man I think revworks is just saying ***** to get money out of me.. I replaced the wastegate and still got the pop but even more intense when it happens... my boost gauge reads 17lbs at 60-70% throttle when I get the pop, pop, pop... just waiting to hear that final boom, that's ends it.
Old 01-09-2014, 05:59 PM   #95
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
Did you change your coil packs? When I built my best friends Bugeye he had a bad coil pack and wouldn't show a problem at low low boost but under real power bucked exactly like you say.
Bamofo is offline   Reply With Quote
Old 01-09-2014, 07:01 PM   #96
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
Did it ever show a misfire code? A failing coil pack should throw a code. All the new plugs looks to me like they are burning perfect. Before when I had a problem with them it showed a code.
Man when you say bucking what do you mean? My car doesnt buck or sputter or pause..it boost and goes but pops its way there. It just sounds like I'm hitting ignition cut at 4-5k rpm.
Old 01-09-2014, 07:49 PM   #97
nickelninez
Member#: 326607
2004 WRX
I had around the same problems as you in my 04 WRX... Make sure you swap out your MAF sensor with a friends or something. it fixed my problem, and oh yea if its not that then i agreed check the coil packs.
nickelninez is offline   Reply With Quote
Old 01-09-2014, 07:59 PM   #98
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
Nickel: when you say around the same what do you mean? What was your setup? I just bought a new maf sensor about 5 months ago denso. My iacv went out the other day and I had to drive with it like that for a week until I got a new one. But I have no cel codes at all..
Old 01-09-2014, 08:09 PM   #99
codesbugeye
Member#: 362137
2002 wrx bugeye
Wrb
All though this morning the cel came on for a little throwing a p1312.
Old 01-09-2014, 08:23 PM   #100
atomicfire
Member#: 136296
2005 STi
p1312 is EGT sensor failure. I'm hoping you already deleted and turned off this code.
atomicfire is offline   Reply With Quote
