Old 01-08-2014, 08:41 AM   #1
swcrow17
Member#: 304498
07 vf43 Waggie
Default Reverse Throw Out Bearing symptoms!
Just to start, I searched and my symptoms are almost complete OPPOSITE of everyone else's, hence why I'm posting.
Tranny: Manual - Clutchmaster 350 (TOB was replaced with install less than 5k miles ago)
Issue:
-Killer squeal (60% of the time) when car is in neutral or any gear, but 4th and 5th. Sounds like one of those cars that has a bad accessory belt.
-Squeal goes AWAY when clutch is pressed in, even pressed in only 2" or fully pressed in.
-Squeal is NOT related to RPM (so doubt it's pilot bearing)...it's the same sound at a stand still as at 3000 rpm
- I believe it starts to happen more once car has been running awhile...almost non-existent when cold.
Solution: Think this is something that a TOB adjustment could help?
Thanks all...much appreciated!
swcrow17 is offline   Reply With Quote
Old 01-09-2014, 08:20 AM   #2
swcrow17
Member#: 304498
07 vf43 Waggie
man.....no one has any idea? Do you think I can try and adjust the TOB myself to see if it will help?
Old 01-09-2014, 05:01 PM   #3
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
By not RPM related you mean its there all the time.. the squeal follows engine speed though..
Its the TOB most likely.. its almost never a good idea to use anything but a stock TOB..
The fact that it goes away when you press the clutch pretty much seals the deal.. as soon as load it put on it it goes away.. one way or another its on its way out
Old 01-10-2014, 09:40 AM   #4
swcrow17
Member#: 304498
07 vf43 Waggie
Thanks so much! I appreciate it.....will try to adjust and I guess I'll look at future replacement
Old 05-20-2014, 07:31 PM   #5
novacivic
Member#: 117980
2005 sti
wr blue
There is no adjusting for a throw out bearing. You need a new one
novacivic is offline   Reply With Quote
Old 05-22-2014, 08:11 PM   #6
S1CkWrx
Member#: 325249
2012 wrx
dgm
im having this same issue on my stock clutch (12 wrx) clutch feels spongey/notchy and at idle and nuetral it squeels like the belt you said. slight pressure on the clutch and it goes away.
S1CkWrx is offline   Reply With Quote
Old 05-23-2014, 05:51 PM   #7
chadls
Member#: 381003
2013 Subaru WRX
I am having the same symptoms with my 2013 subaru wrx. I went to a local shop to get the noise checked out and the man said it was the Clutch Throwout Bearing.
chadls is offline   Reply With Quote
