Old 01-12-2014, 07:25 PM   #76
makofoto
Member#: 25243
2006 Legacy Outback
Is that green "teflon" coating on new Suby engines on the pistons or the cylinder walls?
And correct me if I'm wrong ... it's suppose to help protect against piston slap on the boxer engine?
Thanks ... Makofoto@earthlink.net
makofoto is offline   Reply With Quote
Old 11-20-2014, 06:32 AM   #77
TGM2
Member#: 373923
Many thanks for this Unabomber. Great information.
TGM2 is offline   Reply With Quote
Old 12-03-2014, 10:29 PM   #78
Kcwiro
Member#: 57366
1999 Legacy-Sleeper
Burgandy
Unabomber.. my head just asploded... good info long over due thank you for providing!
Kcwiro is offline   Reply With Quote
Old 12-11-2014, 12:28 AM   #79
neven22
Member#: 166063
great read ,,,,
neven22 is offline   Reply With Quote
Old 04-29-2015, 09:45 AM   #80
GotMeUnderPressure
Member#: 419774
2010 STi
I'm glad I was not around to witness your "digestive malfunction". Another failed ringland?
Thanks for this FAQ!
GotMeUnderPressure is offline   Reply With Quote
Old 05-31-2015, 01:08 AM   #81
joe_r
Member#: 421445
Originally Posted by RalliSpec View Post
A few comments....
3) It is only assumed that USDM STI pistons are hypereutectic although their problems seem to bear this out. Older JDM STI models with forged pistons (Ver.7 and older) used 4032 alloy pistons. There are some newer cast alloys that have been developed with higher tensile strengths and improved ductiliy...its possible that they are being employed on JDM STI models rather than hypereutectic alloys. Who knows. But the change from forged to cast pistons was probably necessary to meet stricter emissions standards.
JDM sti motors used forged pistons?! This was the information i was looking for, but didn't know i was looking for.
joe_r is offline   Reply With Quote
Old 06-08-2015, 12:06 AM   #82
shoemaker6009
Member#: 405097
1998 Impreza OBS
Awesome thread new to the world of engines really appreciate all the information contained within your threads.
shoemaker6009 is offline   Reply With Quote
Old 06-26-2015, 02:51 PM   #83
J.B.M.
Member#: 424394
Well done, lots of great stuff in there!
I'm rebuilding a stock NA ej251 with OEM pistons and rings and would like to know what is a good approach for determing the proper fit of the oil expander ring? Should it have a similar gap as the oil rails?
I have the sensation the tension from the expander ring is a little high and the gaps from the oil rails can be seen on the cylinder walls when dropping in the pistons.
Any help would be much appreciated!
J.B.M. is offline   Reply With Quote
Clutch & Flywheel FAQ: Read if you are thinking of buying them! Unabomber Transmission (AT/MT) & Driveline 283 Today 12:26 AM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 08:49 AM
Intercooler Hose FAQ: Read if you are thinking of buying them! Unabomber Newbies & FAQs 42 04-05-2014 11:18 PM
Spring/Strut/Coilover FAQ: Read if you are thinking of buying them! Unabomber Brakes, Steering & Suspension 39 04-19-2013 06:30 AM
