Vancouver Impreza Club
Notices
Old 08-10-2012, 01:14 PM   #726
Pickler
Member#: 301247
09 Impreza 2.5i MT
this has got to be the greatest dyno forum i have seen for a subaru. i just finished going through all 29 pages. i have a question for the NA owners or anyone familiar with the engine. im trying to find my peak torque and peak horsepower engine speeds. i have seen many NA dyno graphs and each suggest a different RPM.
for example this two from 06-07 2.5i suggest different RPMs?:
from an 08 impreza and 09 legacy also are conflicting:
can anyone explain? thanks.
Pickler is offline   Reply With Quote
Old 08-10-2012, 01:28 PM   #727
tora
Member#: 5851
09 Forester XT
+ NA Miata
They have two different runs, like a stock run and tuned run or before and after.
tora is offline   Reply With Quote
Old 08-10-2012, 01:50 PM   #728
Scott_2.5TS
Member#: 163806
Those are 4 different dyno plots you're comparing and they all read different. If you're just looking for peak hp and torque at what rpm best just google the specs of your car; it will tell you where you make the most power and torque.
Scott_2.5TS is offline   Reply With Quote
Old 08-10-2012, 02:19 PM   #729
Pickler
Member#: 301247
09 Impreza 2.5i MT
well subaru claims peak horsepower at 6000 and peak torque at 4400. however on the dyno the car peaks at 4600 in torque and 5700rpm for horsepower. power nosedives at 6000rpm. this is why im confused.
Old 08-10-2012, 06:23 PM   #730
tora
Member#: 5851
09 Forester XT
+ NA Miata
So many variables, and these are rolling dyno's probably whereas Subaru would use engine dyno.
Old 11-01-2012, 02:24 PM   #731
Karmalina
Member#: 308597
2007 WRX Limited
Urban Gray Metallic
Default Liz's 07 WRX score @ Cobb Surgeline
Nothing crazy since the tune is on the conservative side, but I'm a very happy owner and the difference is night and day
Karmalina is offline   Reply With Quote
Old 01-12-2014, 11:13 PM   #732
CFK
Member#: 261915
92 Legacy Turbo SS
Moss Green
92 Legacy SS
Modifications:
Engine
- EJ22T (240 000 Kms)
- RobTune ECU
- TD05-16G (Used)
- JDM Greytop 440cc's (Cleaned & Flowed)
- Delta 220 Cams (Torque)
- MSD Coilpack
- Aurora 8mm Wires
- Ceramic Coated Exhaust
- 07 WRX TMIC W/ Disected Perrin Y-Pipe
- De-Snorkeled, K&N, Turbo Silencer Delete
- Winton Motors BOV Adapter
- 2 Catch Cans
- 3" TBE. Megan DP, Custom No-Cat Mid & Sheep Dog Muffler
- Hallman Pro MBC
- Innovate LC-1 WB Controller
- Walbro 255 Fuel Pump
- Forge 007 Diverter Valve
Very happy with that considering there all used stock components, minus the RobTune of coarse
AWD DynaPack located at Blitzkrieg Autowerks in Vancouver.
CFK is offline   Reply With Quote
Old 05-26-2014, 09:42 PM   #733
swifter
Member#: 265274
2006 STI
Does anyone who's had they're car dyno'd or had a pro tune know how accurate the Cobb dyno on the AP is?
swifter is offline   Reply With Quote
Old 05-27-2014, 02:10 AM   #734
420WRX
Member#: 27752
2004 WRX+Ver.8 EJ207
My software dyno seemed accurate between what I saw for stock WRX before my swap then the gains I got on the awd dyno matched almost exactly with the software runs post swap too.
How accurate it is really depends on knowing the right weight. I wasted time driving around for a bit till I got the gas at exactly 25% and then I made my pretty passenger stand on the side of the strip risking insult about her weight.. All just to keep things the same and even then I know there was a bit of a weight change with the motor swap.
420WRX is offline   Reply With Quote
I-Club/NASIOC: BC Member's Car Pics Happy_Days Vancouver Impreza Club Forum -- VIC 7965 07-19-2016 06:09 PM
Need Members' Help - Salvage Vehicle Keenan Southern California Impreza Club Forum -- SCIC 5 06-09-2008 05:42 PM
New High Score on our Dyno 415.8 whp WHITE GF8 Proven Power Bragging 7 08-12-2005 02:05 AM
2002 Headwaters Club Rally Stage Scores jmullan Motorsports 0 05-13-2002 03:46 PM
Dyno results posted from NW i-club Dyno Day! sponaugle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 06-04-2001 10:30 PM
