Old 04-24-2013, 03:55 PM   #1076
tuxtattoo
Member#: 79032
2002 Impreza WRX
I found that Lowe's and Home Depot had the cans the cheapest in my area ~$6 a can (for black).
Personally, I'd just peel it off and start again. If the first picture is what you got with your first coat, that's part of your problem. The first coat is WAY too thick.
Also, not knowing the weather conditions you were dipping in (was it cold/super humid?), could have impacted the drying as well. 30-45 minutes is also a really long time to wait between coats. If you were following anything the back of the can said, ignore it.
As others stated, keeping the cans nice and warm and shaken up really helps with a nice even mist.
My method is typically as follows:
  1. Make sure the piece is clean and dry. Rubbing alchohol works great most of the time.
  2. Get one of the
    Rustoleum pistol gripRustoleum pistol grip
    . Lowes/Home Depot also have them.
    This oneThis one
    is not the one you want.
  3. Place the item up high enough so you can get side/upward angle for the edges. At least knee high should be enough.
  4. Shake the can really well (and make sure it's at least room temp. I like to sit the cans in a bucket or sink of hot water before hand (especially on cold days). If it's cold, toss 'em back in between coat.
  5. When spraying, keep the can around 4-5" away. Do not follow the directions on the can or you'll have an textured orange peel effect.
  6. Test your spray on cardboard to make sure it's even and not splattering and blobbing.
  7. Spray a nice even coat keeping your wrist locked. Pay attention to your stroke and see if you are pulling up or down at the end of your stroke. Up puts you at risk for orange peel texture. Down you risk thick blobs and bubbles, etc. You always want to keep the can at the same distance through the stroke.
  8. Don't stop your stroke in the middle of your item, you'll notice a thicker vertical blob when you do.
  9. For your first coat you want a nice ~50% coverage. You don't want to thick or you'll end up with an uneven finish (as you've seen).
  10. I typically wait 10-15 minutes between coats unless it's cold and I can't bring it indoors.
  11. When possible, move the items inside to dry if you are outside. Wind, bugs, grass, will always pick up and blow crap on your drying dip (at least for me it does). Or your neighbor will decide he absolutely must mow his monkey humping grass 5' from where you are working.
  12. Shake the can really well between coats. I like to give it a good 10 second shake every 60 seconds or so. Test your spray pattern again before jumping back in.
  13. Apply the second coat about like the first coat. Thin and even. You'll proabably be ~75% transparency.
  14. Third coat, I go a little heavier, but not overdoing it.
  15. 4th coat, I usually do a bit heavier than the 3rd. This is usually plenty for most applications to provide a nice smooth and durable finish.
  16. 5th coat+ if your item will be subject to heavier abuse (grills, wheels, etc).
I hope this helps.
tuxtattoo is offline   Reply With Quote
Old 01-16-2014, 10:16 AM   #1077
WRXgabeSTi
Member#: 239606
03' Bugeye Stage 2
SWP 250k+
This thread needs a bump.
WRXgabeSTi is offline   Reply With Quote
Old 01-16-2014, 10:39 AM   #1078
urmomlovesbbc
Member#: 378904
Gotta dip my BBS in white
urmomlovesbbc is offline   Reply With Quote
Old 01-16-2014, 11:18 PM   #1079
Atv821
Member#: 378973
2002 Wrx
Thumbs up
Ive got experience dipping all sorts of cars. Ive dipped several bmw and my genesis coupe. Stuff is amazing if applied correctly. Make sure you do your homework before doing the job.
Atv821 is offline   Reply With Quote
Old 10-14-2014, 01:17 PM   #1080
nfisheremti
Member#: 69459
2015 2.0 hatch
crystal white
i have a question, sorry if its already been covered somewhere in the last 44 pages....
what about wheel mounting and balancing? can i spray my rims, then mount and balance the tires? i suspect that won't work, but has anyone done it?
nfisheremti is offline   Reply With Quote
Old 10-14-2014, 09:41 PM   #1081
Geerolla
Member#: 264827
2011 2.5i 5D
I would be afraid of the process screwing up the dip. I just got a new set of winters put on and am doing the dip now for that reason.
Sent from my UAV using Disposition Matrix 2.0
Geerolla is offline   Reply With Quote
Old 10-14-2014, 10:58 PM   #1082
Zombaru
Member#: 280577
2015 WRX Base
Crystal White Pearl
If it does they sell a patch/repair kit that allows you to repair the dip without having to remove it all and start again from square 1.
Zombaru is offline   Reply With Quote
Old 10-14-2014, 11:41 PM   #1083
Soobiecabra
Member#: 259527
2011 WRX Sedan
Custom Cobra Plasti-Dip
I have had tire put on my wheels that are dipped. Discount Tire did a pretty good job and didn't mess it up, there was a few small tears that I fixed.
If you are doing a standard color and have leftover you will be fine. Just have some Xylene on standby. When you get the tire mounted you'll need to lightly rub a little bit of Xylene over the areas that are damaged. Once that is dry touch it up with your plastidip.
The purpose of using the Xylene (thinner) over the damaged areas is to reliquify the plastidip and make sure it is bonded to the wheel before you spray the touck up.
Soobiecabra is offline   Reply With Quote
Old 10-14-2014, 11:43 PM   #1084
gc8c4dd
Member#: 380960
I usually buy from dipyourcar.com....home depot's stuff have no UV protection...doing my car to world rally blue tomorrow.
gc8c4dd is offline   Reply With Quote
Old 10-15-2014, 10:34 AM   #1085
sumone
Member#: 367961
2014 wrx 5 door
swp
Dipped the wheels pink for breast cancer month.
Also the fog light trim and side piece is dipped... I may be pealing them soon though.
sumone is offline   Reply With Quote
Old 10-15-2014, 07:52 PM   #1086
Suubiewrx2014
Member#: 376021
Where did you order that pink from? Looks great! I really wish I bought my subaru in white ;(
Sent from my iPhone using NASIOC
Suubiewrx2014 is offline   Reply With Quote
Old 10-16-2014, 09:05 AM   #1087
dysect
Member#: 393537
https://www.dipyourcar.com/ has every color they make. they also have pearl and others
I did my 15 wheels in a vintage gold matte. Looks pretty good i think.
dysect is offline   Reply With Quote
Old 10-16-2014, 12:36 PM   #1088
sumone
Member#: 367961
2014 wrx 5 door
swp
yep I ordered it form dip your car. They had a sale on the pink for October so I picked some up... Thinking about doing orange next.
Old 10-19-2014, 08:49 PM   #1089
Bluewrx06
Member#: 316328
2006 Wrx
Rally blue
I dip mine vintage gold. Looks great but it says I don't have permission to upload a picture??
Sent from my iPad using NASIOC
Bluewrx06 is offline   Reply With Quote
Old 10-20-2014, 09:40 AM   #1090
nickonometry
Member#: 365610
2005 Forester 2.5X
light gold
Dipped my two-toned forester camo green. Nice little winter color:
nickonometry is offline   Reply With Quote
Old 10-25-2014, 11:08 PM   #1091
Geerolla
Member#: 264827
2011 2.5i 5D
Dipped my stockers for use as a winter set! Not quite cold enough to put them on yet.
Old 01-16-2015, 11:08 AM   #1092
shoesandsocks
Member#: 383434
My car completely plastidipped
shoesandsocks is offline   Reply With Quote
Old 01-17-2015, 02:16 PM   #1093
colemrogers
Member#: 406784
2002 wrx
Has anyone heard if dyc is coming out with new shinier colors. My friends said he heard that and I wanted some more input.
colemrogers is offline   Reply With Quote
Old 01-18-2015, 09:14 PM   #1094
BeeVelaDee
Member#: 410581
2013 WRX sedan
Ice Silver Metallic
How does it do in low and frozen temps?
BeeVelaDee is offline   Reply With Quote
Old 01-19-2015, 10:14 AM   #1095
defix
Member#: 304994
Is there any way to get the plastidip to come out more evenly? :| ive done my centre dash bit on my 06 and its come out all bumpy :|
defix is offline   Reply With Quote
Old 01-20-2015, 10:58 AM   #1096
Geerolla
Member#: 264827
2011 2.5i 5D
Multiple (at least 4+) THIN coats.
Old 01-20-2015, 11:05 AM   #1097
nickonometry
Member#: 365610
2005 Forester 2.5X
light gold
I live in Maine, my car is fully dipped (see my photo above). Our asverage temp this winter has been about 15 degrees, we've hit lows of -20. I haven't had any issue whatsoever with my dip. My roomate has had his car dipped for almost 2 years now in Maine, through 2 winters, no problems whatsoever either. We never wash our cars.
Old 01-21-2015, 12:07 PM   #1098
goob_os101
Member#: 173185
2005 Saabaru
High gloss future product from Plasti Dip:
goob_os101 is offline   Reply With Quote
Old 01-21-2015, 09:37 PM   #1099
BraveSTi
Member#: 262030
One Of The Dumbest Products Eva----
BraveSTi is offline   Reply With Quote
Old 01-22-2015, 01:42 AM   #1100
vinylscratchp0n3
Member#: 382386
1998 Legacy GT 5MT
I've done my scoop, grille, roof rack, front lip, and rear turn signals with black dip. (Don't worry, they're still legal. They're still visible from 100+ yards away in daylight, like Texas law requires. I just hated the amber but can't afford the JDM GT-B smoked tail lights at the moment) I still need to do the side skirts, rear skirt, and the bumper guard when it warms up/isn't rainy again. The all black accents look so much better than the stock mismatched black and dark grey accents, to me at least. I'm thinking about dipping the wheels in vintage gold, too.
vinylscratchp0n3 is offline   Reply With Quote
WTB Plasti wheel well covers EJ22t Kid Private 'Wanted' Classifieds 3 01-21-2009 06:46 PM
Decided to Suede & Plasti badfish1134 North West Impreza Club Forum -- NWIC 22 10-30-2008 07:11 PM
Plasti-Kote 5604 - Silverthorne match.... -Kevlar- Interior & Exterior Modification 3 05-09-2008 01:46 PM
repainting optical drives, where can I buy Plasti-kote online? captaind Off-Topic 2 10-21-2006 05:36 PM
Is the WRX OEM front spoiler plasti or fiberglass? thejean Interior & Exterior Modification 5 02-04-2003 02:47 PM
