Old 01-16-2014, 09:50 PM   #226
Paidfor
Member#: 267815
Be in awe
dont hate .)
Yeah.......launchin is not possible with these settings cuz of (like you pointed out)....all you've got is 25 ft lbs lol
Soon tho........hopefully we will be able to.
Paidfor is offline   Reply With Quote
Old 01-17-2014, 04:27 PM   #227
BuckwildWRX
Member#: 372900
Will this work on An 02
BuckwildWRX is offline   Reply With Quote
Old 01-18-2014, 02:38 PM   #228
Nemesis_STI
Member#: 325545
2006 STI
Monitor your IAT with the ign on. Un pin or un plug your IAT sensor ad check the read out. It should say -44 (mine says -0) if I'd does then yes it could work.
-Justin
Nemesis_STI is offline   Reply With Quote
Old 01-18-2014, 11:27 PM   #229
BuckwildWRX
Member#: 372900
Is there a specific type of relay I need to get or just a 5 pin relay? And as far as 12volt ignition source can it be any I'm nervous about tapping into the injectors. I'm planning on doing this to a 2002 wrx.
Old 01-19-2014, 11:03 AM   #230
Nemesis_STI
Member#: 325545
2006 STI
I didn't use a relay, I used a momentary push button, normally closed circuit.
-Justin
Old 01-20-2014, 07:14 AM   #231
Nemesis_STI
Member#: 325545
2006 STI
Any one know how the oem speedo gets its signal? is it straight off the tranny or does it get conditioned from the ecu? (<--- probably) I was thinking if we could interrupt that signal could we fool the ecu into thinking we are out of the vehical speed threshold for the idle ignition comp table?
-Justin
Old 01-29-2014, 02:28 PM   #232
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
-Justin
I've heard of a speedohealer being used so it's possible.
Old 02-02-2014, 12:34 PM   #233
SharpTuning
Member#: 333363
-Justin
Idle mode determination is more complex than a vehicle speed switch.
SharpTuning is offline   Reply With Quote
Old 02-02-2014, 12:39 PM   #234
SharpTuning
Member#: 333363
Originally Posted by Paidfor View Post
Id almost settle for a hack to use the stock limiter for LC for smoothness and just disable the limiter completely as soon as the clutch is let out. ...But then were still left with how to lock onto said throttle table during LC. Dammit.....I know a few Gurus that prolly know something lol
Hope they let us know something.
They all use the stock limiter, and all disable on the clutch switch.
I know why the LC is slower on MerpMod
Old 02-03-2014, 09:36 AM   #235
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^^^Is there a way for us regular folks( no code writing capabilities) to speed it up?
The stock limiter is waayyy faster than the LC limiter!!
Please enlighten me Mr Guru
Old 02-03-2014, 01:38 PM   #236
SharpTuning
Member#: 333363
Its common sense really. Support the developer(s) and provide constructive feedback.
Old 02-03-2014, 04:22 PM   #237
Paidfor
Member#: 267815
Be in awe
dont hate .)
Pmd you with some feedback...
Since you asked .)
Now tell me how much you want....make me a GOOD LC patch....and take my money
Please ....haha
Old 05-30-2014, 01:14 AM   #238
JMlegacy
Member#: 341649
Did anyone get this to work on an auto? I saw a video of a guy launching an auto legacy 2.0 GT, tires and all!
JMlegacy is online now   Reply With Quote
Old 05-30-2014, 12:38 PM   #239
dr20t
Member#: 311246
Nope couldn't get it going / working properly at all. But I think this relates specifically to my setup due to the very large timing it runs at the revs/ load I was stalling if up to (2500rpm, 1.40 g/rev load, 48 degrees total timing)
So the max timing retard I can run in the temp compensation table is -45, so never really got it firing
Even changing base / total timing in that zone to 30 degrees (so total timing on full retard with switch pressed was -15 degrees), it still wouldn't work
That 5eat 2.0 GT has stock vf38 twin scroll which is super fast spooling from factory (2400rpm full boost and peak torque), so no need for antilag
Hell even with my bog stock 5eat box and a full house 2871r setup with 0.63 rear making 250awkw I could launch at 3400rpm and 12psi - so no need for antilag
With larger turbos and low load though with the auto, you need something. I think my something is gonna be nos
Mick
dr20t is offline   Reply With Quote
Old 06-04-2014, 12:36 PM   #240
JMlegacy
Member#: 341649
NAAUSS
Btw, How do you launch your vehicle? Do you floor it? I have problem getting mine to rev past 2K while brake torquing, but i haven't floored it yet. Am not sure if it is safe to do so?
Old 06-16-2014, 09:43 AM   #241
xisco
Member#: 386730
looks easy to do
xisco is offline   Reply With Quote
Old 12-26-2014, 02:38 PM   #242
swifter
Member#: 265274
2006 STI
Gonna wake up kind of an old thread... Did this.... AWESOME! I found it really works quite well, haven't played with it a ton yet but the rolling antilag is very fun!! I've been trying to think up different ways of activating it, and different ways of using it for autocross. If anyone has any good setups post it up! I'm thinking of hooking it up to the clutch to engage similar as 2 step launch control. And or possibly the brake so you keep it floored as you brake into a corner and it'll stay at full boost... But definitely need an egt gauge before trying that out!
swifter is offline   Reply With Quote
Old 01-05-2015, 01:18 AM   #243
JMlegacy
Member#: 341649
http://www.romraider.com/forum/viewt...106973#p106973
I have an idea for the auto guys, but it's ECU hacking:
IF brake is pressed and throttle is WOT, then apply timing to get -17 degrees total timing, until u release the brake pedal.
Once pedal released the original timing mapping is applied.
I assume the ECU has access to the brake switch? If not, it must have for the e-Brake.
Old 01-05-2015, 11:16 AM   #244
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Your idea should be very easy to implement.
Also for those of you with a USDM 06 wrx I will have this hack built into the rom with no need for a button. Watch the romraider thread I made for anti lag for details.
Porting to a different merpmod build is also possible for those with a current merpmod build.
Sent from my iPad using NASIOC
Old 01-30-2015, 08:49 PM   #245
JMlegacy
Member#: 341649
Bump...
Old 02-08-2015, 02:00 PM   #246
JMlegacy
Member#: 341649
Just to say that On my legacy GT the MAF wires are as follows:
when facing the connector like so:
1. Power (THICK Yellow/Blue)
2. Ground (Black/Green)
3. MAF Signal (Red/Blue)
4. Temp Signal (Yellow/Blue) - cut this one
5. Ground (Yellow/Green)
I actually did mine at the ECU part of the loom. So far it's not working out either because i'm automatic, but will update with different settings
Old 04-10-2015, 02:21 AM   #247
martin028
Member#: 401669
2004 WRX Wagon
JBP
Found this thread and I would love to try it on my 04 wrx. I am already invested in an AP and will continue to use it for various reasons, so I need to tune using AccessTuner to make this work.
The tables I see are the intake timing compensation (intake temp), and intake timing compensation (intake temp) activation (min. load).
Would the -40 degree Celsius column be the value I would want to edit and log to get as close to 17 degrees of timing pulled? The table also only specifies that it is ignition timing correction, but does not say from TDC or BDC or where the correction is applied in the cycle. Does that make a difference?
Would I also have to modify the activation load (default 0.60g/rev)?
AccessTuner and ECUFlash are different animals, but the concepts should be the same right?
Matt
martin028 is offline   Reply With Quote
Old 05-16-2015, 03:17 PM   #248
martin028
Member#: 401669
2004 WRX Wagon
JBP
Anyone? Bueller?
Old 05-16-2015, 04:16 PM   #249
JMlegacy
Member#: 341649
even the -20 would be fine, as long as where u live you won't see those temps
Old 05-17-2015, 07:45 AM   #250
martin028
Member#: 401669
2004 WRX Wagon
JBP
Thank you, anything I should do with activation load and what timing would I put in to reach ~-17degrees?
