Welcome to the North American Subaru Impreza Owners Club Monday September 1, 2014
Old 12-26-2013, 04:55 PM   #151
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Is it just me, or does this car seem to be a bit of a problem child for Subaru?
averagewhiteboy is offline   Reply With Quote
Old 12-26-2013, 08:24 PM   #152
79letour
Member#: 302570
2013 XV
DGM!
Mine was a problem.
79letour is offline   Reply With Quote
Old 12-26-2013, 09:10 PM   #153
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Not really. Overall, the 2012+ Impreza has been very reliable:
http://www.truedelta.com/Subaru-Impreza/reliability-252
Old 12-26-2013, 09:26 PM   #154
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
There just seems to be lots of random little issues. None of which SOA is overly trying to fix.
Old 12-26-2013, 09:59 PM   #155
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
You wouldn't feel so bad if you had previously owned a VW TDI or GTI. Trust me, our reliability issues just don't compare. And if you think SOA is indifferent, then you've never dealt with VWoA.
Old 12-26-2013, 10:20 PM   #156
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
haha My only new cars have been a Chevy, a Honda, and this Subaru. The Cobalt SS was a known piece of ****, and the Si was a beast. This is somewhere in the middle. haha
Old 12-26-2013, 11:15 PM   #157
DNA Performance
Member#: 372528
2013 Impreza Sport
Yeah, my bad, I meant camshaft.
DNA Performance is offline   Reply With Quote
Old 01-01-2014, 05:06 PM   #158
aquariaguy
Member#: 312013
Mine has been having trouble starting in cold temperatures too. After the second or third try it fires up.
aquariaguy is offline   Reply With Quote
Old 01-01-2014, 08:01 PM   #159
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
How cold are you talking about?
It is well known that the OEM battery provided in our cars is disappointingly weak in terms of Cold Cranking Amps (CCA). Some people on this forum are replacing the OEM battery proactively, and not waiting for it to fail.
My car (and OEM battery) is 1.5 years old with 23k miles on it. It hasn't failed to start my car yet, but it does crank slowly when it gets cold. I'm hoping it makes it through this winter, but we'll have to wait and see. I would hate to replace it this early, but will if necessary.
Old 01-02-2014, 01:36 AM   #160
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Indeed. The stock battery is iffy at best below freezing. I'm trying to nurture it through this winter, but a new one is in it's future.
Old 01-02-2014, 06:18 AM   #161
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Block heater helps immensely
Old 01-02-2014, 07:33 AM   #162
grubincan
Member#: 300961
-28C ( -18F ) this morning, turned over within a couple of seconds.
Everything was cold (even the shocks), a block heater or a battery warmer might have helped a bit, but there seems to be nothing inherently wrong with the model.
Mine is two years old (and Canadian).
grubincan is offline   Reply With Quote
Old 01-02-2014, 08:47 AM   #163
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Meh, if/when I determine that my OEM battery is inadequate, I'll install a Diehard Platinum battery and be done with it.
Old 01-02-2014, 08:58 AM   #164
KC
Member#: 442
2013 Crosstrek XV
00 Honda S2000
^^^ this. People expect to have to just turn the key to START and have it fire within a second. No, you keep the key turned until it kicks over, sometimes for up to 10 seconds (per the owners manual).
Do not operate the starter motor continuously for more than 10 seconds. If the engine fails to start after operating the starter for 5 to 10 seconds, wait for 10 seconds or more before trying again.
Admittedly, many cars today do only require one to turn to START and immediately release and the computer takes care of the rest. My G8 was like that.... all you had to do was turn the key to START and release the key, the computer then took over the rest to start the car.
No Subarus are like that. You have to hold the key and crank it until it starts and then release.
--kC
KC is offline   Reply With Quote
Old 01-02-2014, 09:18 AM   #165
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Even at -25f it helps a lot more than just the battery. But if you don't see this kind of temps it is moot point
Old 01-12-2014, 12:37 PM   #166
mrcoolio
Member#: 352732
Default Hard start on 2012 Impreza
I am having the same issue. Periodically the car will turn over for a long time before starting. No ryme or reason as to why. Happens in warm weather or cold. Does not matter if car was sitting all night or just started. This is obviously a common problem. My 13 year old honda civic seems to be more reliable when it comes to starting.
mrcoolio is offline   Reply With Quote
Old 01-12-2014, 01:25 PM   #167
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Keep your foot off the gas pedal when starting the car otherwise it will be hard to start.
G-Omaha is online now   Reply With Quote
Old 01-12-2014, 09:39 PM   #168
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
My foot has never touched the gas pedal when starting. That has no effect in this. Next.
Old 01-18-2014, 12:19 AM   #169
snuck
Member#: 379063
First post here.
I've had a wee bit of rough starting, but otherwise has actually been pretty reliable even at -29.
From what I understand the FB20 engines have tighter tolerances and incur more friction on start.
That and yeah... would like to replace the battery some time
snuck is offline   Reply With Quote
Old 01-18-2014, 07:22 AM   #170
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Welcome to the forum.
I'm sure the FB20 has tight tolerances, as does any modern engine that is designed to use 0W-20 oil. But I'm not aware of the FB20 having more friction on start-up than any other modern engine. Why would that be? Because of the boxer design?
Old 01-19-2014, 11:02 PM   #171
snuck
Member#: 379063
Maybe. I always thought it was because of the tighter tolerances of the engine, but yes, if that's so then all 0W20 engines ought to be rough to start... Though maybe Subaru's engines are just 'extra tight' ha ha ha.
Old 02-01-2014, 08:20 PM   #172
mrcoolio
Member#: 352732
Default software update for hard start
Brought my 2012 Impreza to the dealership. They seemed aware of the issue. They said there was a software update. No charge under warranty. Hopefully this is resolved now.
UPDATE: Problem continues even on warm days. Completely random, sometimes starts fine, other times not.
Old 02-01-2014, 09:08 PM   #173
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
I'm gonna have them check for it when I go in for inspection this week. Did you have to tell them anything in particular, or did they tell you? I have the factory code info saved..
Old 02-02-2014, 04:55 PM   #174
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
So this happened to me the other day for the first time after 2 years and 43000 miles. It actually happened twice in one day. It took about 7-8 seconds of continuous cranking for the engine to turn over. At first I thought maybe it was because of the cold temperatures, but there have been a ton of super cold days this year and it didn't do it during those other days. Anyone find a fix for this issue yet or what causes it?
Update: Just happened again when I tried to start my car a minute ago.
jr0bb5 is offline   Reply With Quote
Old 03-20-2014, 11:16 AM   #175
mrcoolio
Member#: 352732
Update. Problem persists with hard start at random. Update did not help. This is not just on cold days.
going to be like driving for the first time! ThaPuertoRican15 General Community 35 12-27-2010 01:42 PM
going to autox this weekend for the first time... CiViCKiDD General Community 12 03-21-2006 06:15 PM
I'm about to ride a Harley for the first time. Sharkbait Off-Topic 48 12-01-2005 10:23 AM
im going to watch american idol for the first time Protege Menace Off-Topic 5 05-19-2005 10:35 PM
Finally got to drive my WRX for the first time in a while! MGAMAN Alaskan Impreza Club Forum -- AKIC 3 07-24-2003 08:31 PM
