Old 01-25-2014, 07:21 AM   #8001
stlnation
Member#: 321805
2002 Jdm v9 STI
so ive recieved my lastest v9 sti motor. Looks like this motor has rust around the valves and cylinders. Im guessing something didndt get covered well and ocean salt water in the air contamindated the engine and has ruined it. i dunno but im trying to work out getting it sent back now.
stlnation is offline   Reply With Quote
Old 01-25-2014, 10:43 AM   #8002
25rsti
Member#: 166324
Ouch! So sorry dude, Ive been there.
Old 01-25-2014, 11:37 AM   #8003
ShinjiML
Member#: 257231
2011 STI ShinjiTuned
What's with the recent string of bad motors? I received my motor shipped from a Japan military base via 8 flat rate usps boxes and it arrived in better conditions than some of these recent ones. o.O
ShinjiML is offline   Reply With Quote
Old 01-25-2014, 11:59 AM   #8004
scotto4k
Member#: 208515
v7 EJ207 20g'd
Me. Then this guy.... The apocalypse is nigh!!
scotto4k is offline   Reply With Quote
Old 01-25-2014, 12:05 PM   #8005
Nomadgene
Member#: 22923
2002 EJ207 V8 1.5xtr
TWIN-SCROLL Black Bugeye
Subaru Stars
I would imagine it has much to do with the 2011 earthquake and tsunami. The word is out on these motors and though they are still rare, some of the newer vendors are unscrupulous. Be very careful with who you purchase from. Go with a reputable vendor…with a longer track record. Get the motor running within 30 days of receipt before the return warranty runs out.
Nomadgene is offline   Reply With Quote
Old 01-25-2014, 01:06 PM   #8006
scotto4k
Member#: 208515
v7 EJ207 20g'd
^^^ this.
If you can offer the guy delivering it food or drink and inspect the $hit out of it before he even leaves.
Spend at least one whole day on just going over it really well before you do anything. I'm glad I did.
Old 01-26-2014, 05:17 AM   #8007
03WRXer
Member#: 142905
That motor might be OK. I agree. If you can get you money back that's the safest bet, but I had a motor with valves that looked like that and I WD40ed them and cold cranked it, and got perfect compression.
Installed it in my brother in laws car, and it has run perfect for the last year.
Just my 2cents.
The valves rust real easy. Might look worse then it is.
03WRXer is offline   Reply With Quote
Old 01-26-2014, 09:08 AM   #8008
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
WD40 before the first cranking or start attempt, is a good idea.
Old 01-26-2014, 12:32 PM   #8009
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
I'm in the process of finishing my build. If torn apart everything over the last 2yrs so my memory of where everything goes is foggy.
I'm running a MOROSO dual catch can setup and I've run one line from the crank case vent (it has two outputs) and the other to the PCV on the intake manifold.
The 2nd has the two head breathers connected and then to the intake after the catch can. My problem is, where does that extra port on the crank vent go?? Here's a picture of what I mean, it's the light grey piece. Do I just cap it off?
LIQUIDSK8S is offline   Reply With Quote
Old 01-26-2014, 12:52 PM   #8010
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
2 ways to do it for the crankcase catch can if you don't want burn any crankcase vapors through your intake manifold.
1) remove the pcv from your intake manifold and plug it. Run a line from the crank case to your 1st crankcase catchcan port, run the 2nd crankcase catchcan port to a inlet vac source .
2) leave your pcv from your intake manifold alone and run it straight to a inlet vac source . Run a line from the crank case to your 1st crankcase catchcan port, run the 2nd crankcase catchcan port to a inlet vac source .
you can remove the T fitting on the crankcase vent and replace with a single barb, or block one side of the T you aren't using.
FWIW , the Crawford AOS instructions do it the first way, Perrin AOS instructions do it the second way.
Note: its slightly different if the pcv is located IN the crankcase breather T rather than the intake manifold.
Old 01-26-2014, 01:02 PM   #8011
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Originally Posted by fastnoypi View Post
2 ways to do it for the crankcase catch can if you don't want burn any crankcase vapors through your intake manifold. 1) remove the pcv from your intake manifold and plug it. Run a line from the crank case to your 1st crankcase catchcan port, run the 2nd crankcase catchcan port to a inlet vac source . 2) leave your pcv from your intake manifold alone and run it straight to a inlet vac source . Run a line from the crank case to your 1st crankcase catchcan port, run the 2nd crankcase catchcan port to a inlet vac source . you can remove the T fitting on the crankcase vent and replace with a single barb, or block one side of the T you aren't using. FWIW , the Crawford AOS instructions do it the first way, Perrin AOS instructions do it the second way. Note: its slightly different if the pcv is located IN the crankcase breather T rather than the intake manifold.
Ok, so the preference is to just delete the PCV altogether. The MOROSO instructions have you running to the intake manifold though?
For the inlet vac source, could I just T the line for the second catch can that's running to the turbo inlet pipe? So they both share the vac source?
Old 01-26-2014, 01:32 PM   #8012
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
I haven't read the Moroso instructions, but if they run the line to the intake manifold, it will allow oil vapor to be sucked through the intake manifold while driving under vacuum. Its the stock way the pcv is run by the factory to vent crankcase gasses, not an improvement.
Yup, an inlet vac source is an inlet vac source, T as needed.
Old 01-26-2014, 04:15 PM   #8013
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
I haven't read the Moroso instructions, but if they run the line to the intake manifold, it will allow oil vapor to be sucked through the intake manifold while driving under vacuum. Its the stock way the pcv is run by the factory to vent crankcase gasses, not an improvement. Yup, an inlet vac source is an inlet vac source, T as needed.
I was just thinking about this, and it doesn't make sense.
If I use the turbo inlet for my vac source, the gasses in the catch can still end up in the intake manifold. In your layout it goes inlet/turbo/intercooler/manifold. So really unless you vent to atmosphere, it goes into the manifold regardless of where you draw the vacuum.
Old 01-26-2014, 04:34 PM   #8014
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
Ugh. Been putting off my valve cover gaskets LOL. I also saw LIC have metal moon shaped gaskets. Anyone have experience with those? I didn't buy the moon shaped gaskets and was thinking about getting them.
iNfEk is offline   Reply With Quote
Old 01-26-2014, 08:20 PM   #8015
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
EDIT: NVM I figured it out........not working on a car for months can turn you into a idiot. The first pic goes to the line under the turbo. The 2nd pic goes to the coolant tank. In case anyone else ever runs into this issue.
New question, because I'm noticing differences to the EJ257.
I'm reconnecting the coolant lines, but the bottom line on the upper tank has me confused. Here's why.
This line right here comes from below the turbo, connected to the block. I assumed this connected to the tank.
But now I have this part of the coolant line running under the intake manifold. Am I supposed to T these off and connect all three? Or am I missing something? This pipe is directly under the turbo inlet btw.
Old 01-26-2014, 08:31 PM   #8016
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
you're over thinking it. It would be filtered gasses in the catchcan that will eventually end up in the intake manifold.
The goal is to catch heavier stuff that would otherwise cake up and sludge your entire intake track. Thats why a good can will have baffles or other media inside to create alot of surface area to trap as much oil vapor in the can as possible.
you're right that there is a 3rd solution to setup up the crankcase breather to go out to atmosphere. I didn't mention it because on a street setup, most people can't stand the smell.
The air in the crankcase isnt measured, so technically you can just run a tube straight up in the air with a small breather filter. The use of vac from the intake is to relieve the crankcase pressure which builds when in boost.
Old 01-26-2014, 08:56 PM   #8017
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
LOL, i thought you got them done last year! I just did a search for those metal ones, thats some serious $. Anyways, i don't see how the stock ones leak or "shrink" according to their ad, as long as you put enough fujibond and ensure the flat top of the half moon surface is level with the head.
Old 01-26-2014, 09:02 PM   #8018
MCPHERSON
Member#: 344262
I am in the middle I a version 8 swap
The motor had the BPV tube cut and I am in need if a new tube
I went to SUBARU and the WRX and sti have different part numbers for this tube
Which one is a closer fit to the JDM tube ?
MCPHERSON is offline   Reply With Quote
Old 01-26-2014, 09:23 PM   #8019
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
you're over thinking it. It would be filtered gasses in the catchcan that will eventually end up in the intake manifold. The goal is to catch heavier stuff that would otherwise cake up and sludge your entire intake track. Thats why a good can will have baffles or other media inside to create alot of surface area to trap as much oil vapor in the can as possible. you're right that there is a 3rd solution to setup up the crankcase breather to go out to atmosphere. I didn't mention it because on a street setup, most people can't stand the smell. The air in the crankcase isnt measured, so technically you can just run a tube straight up in the air with a small breather filter. The use of vac from the intake is to relieve the crankcase pressure which builds when in boost.
The point I was making is that your method still dumps gasses into the intake manifold via the intake tract.
My setup per MOROSO has the block breather go to the first catch can, it's then filtered and routed back to the intake manifold PCV.
The 2nd catch can takes the two lines from the heads and filters them before sending it to the turbo inlet.
If I were to route the line on the intake manifold to the intake instead (plugging the PCV) then the filtered gasses from the catch can would still go to the intake manifold.
See my point?
Old 01-26-2014, 09:40 PM   #8020
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
See my point?
Forget about the 2nd catch can, its the easy one.
If the moroso method is from the cc block breather, then filtered by the can, and pulled through by the vac on the pvc located on the intake manifold... It will ONLY work when you are cruising out of boost.
In boost the pcv will shut on your intake manifold and you will build positive pressure in your crankcase and crankcase catch can.
Old 01-26-2014, 09:53 PM   #8021
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Originally Posted by MCPHERSON View Post
I am in the middle I a version 8 swap The motor had the BPV tube cut and I am in need if a new tube I went to SUBARU and the WRX and sti have different part numbers for this tube Which one is a closer fit to the JDM tube ?
I think the Sti tube is the closest match due to the similar inter cooler and turbo design.
Gigs90 is offline   Reply With Quote
Old 01-26-2014, 09:56 PM   #8022
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
LMFAO! I got lazy. LOL. don't judge me. Bwahahahahaha
Old 01-26-2014, 10:28 PM   #8023
stlnation
Member#: 321805
2002 Jdm v9 STI
Just my 2cents.
This was the 3rd motor I've received in about a year. The first one spun rod bearing after about 50 miles. Wais took care of me and replaced it. So I brought a tranny from him. The next motor lasted about 6000 miles before it melted a piston. This motor looks terrible inside. It's going back tomorrow. I need the new one here ASAP. My new tuner is moving
Old 01-27-2014, 08:10 AM   #8024
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
Even the USDM Sti had two designs. The V9 I have has the wrx style hex fitting. The newer '05-'07 have a different, tube design.
Do what I did: Begin the PCV replacement in a parking lot close to the dealer, take the old PCV and put it on their counter.
Old 01-27-2014, 05:39 PM   #8025
2JZ
Member#: 291949
Mine are leaking
I havent decided it $50 is reasonable yet...
2JZ is offline   Reply With Quote
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 08:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 05:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 04:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 02:56 AM
