Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 01-26-2014, 04:25 AM   #1
Sti-Lee
Member#: 379815
Default Is it true that 07 sti pulls harder than the 08?
So I test drove a stock 08 hatch in a dealer a week ago. I have driven my friend's 07 before, I feel the 07 pulls way more harder than the 08, my friend's 07 is stock, don't know what map he runs tho. Is it the 07 have stronger pull when the boost comes on?
Sti-Lee is offline   Reply With Quote
Old 01-26-2014, 04:46 AM   #2
3rdsubaru
Member#: 242862
2011 STi Sedan w/nav
Did you have it in Sport# setting?
3rdsubaru is offline   Reply With Quote
Old 01-26-2014, 06:40 AM   #3
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
The cars are very similar in terms of acceleration, power to weight ratio and gearing. One shouldn't "pull way harder" stock for stock than the other unless one has something wrong with it. Like the guy above said, this would be assuming you had the 08 in S# mode.
FCmaniac is offline   Reply With Quote
Old 01-26-2014, 08:30 AM   #4
milab21
Member#: 157833
2007 WRB STI
If he's stock then he runs a stock map, unless he has an accessport or ecu/possible stage 1?
milab21 is offline   Reply With Quote
Old 01-26-2014, 09:23 AM   #5
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Defines "pulls harder."
Old 01-26-2014, 10:20 AM   #6
Back Road Runner
Member#: 60082
2004 Forester STI
Each newer chassis has gotten faster than the previous. As well the newer chassis has typically gotten more modding potential.
Old 01-28-2014, 06:42 PM   #7
Sti-Lee
Member#: 379815
I did as soon as I hit the road, and I felt the throttle response change.
Old 01-28-2014, 06:49 PM   #8
Sti-Lee
Member#: 379815
The 08 did not impress me at all, the boost comes on very smooth, but the 07 I drove previously has blown my mind when the boost comes on, it was like nothing when I flat foot the throttle, and after 4000 rpm, all the sudden the car was like "boom"!
Old 01-28-2014, 06:52 PM   #9
Sti-Lee
Member#: 379815
Oh one thing I didn't mention is when I test drive the 08, after few pulls, the low fuel light is on, is that a factor that limits the power when the sti running on low tank of gasoline?
Old 01-28-2014, 06:54 PM   #10
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Many things could have factored into your faint "hard pull" feeling.
Old 01-28-2014, 07:23 PM   #11
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
No. The car will continue to accelerate normally right up to the point it runs out of gas, sputters and goes BOOM!
One question I have for you. Does your friend's '07 have any aftermarket suspension mods? A stiffer, lower suspension will make a car seem to accelerate harder.
Gallo2011 is offline   Reply With Quote
Old 01-28-2014, 07:58 PM   #12
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
So 2 different cars felt different when you drove them?
Engine tuning that smooths the transition to boost will "feel" slower even if it's not while the "Whomp" in your back when full boost arrives at 4000rpm which make the car "feel" faster.
Unless you ran them side by side or at a track w/ timers you can't be sure which is actually faster.
aerosaaber is offline   Reply With Quote
Old 01-29-2014, 05:21 AM   #13
FCmaniac
Member#: 142029
2013 Forester
Actually, a worn out suspension would cause more weight transfer front to back making it seem to accelerate harder.
Old 01-30-2014, 04:02 AM   #14
Sti-Lee
Member#: 379815
Both cars are all stock include the suspension. The 08 is softer, but I feel it's more stable and nimble on turns.
Maybe I'm too subjective about the power between two cars, there is a half year gap between two test drive, I need to do a back to back test drive on the 07&08 to confirm that thou. Thanks for the discussion guys!
Old 01-30-2014, 08:44 AM   #15
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
You're asking us to explain a feeling which lacks any proper definition whatsoever. This isn't a forum of telepathic mediums. Impression of "pulling harder" is a combination of noise, linear acceleration, pavement, suspension, hormone levels, time of day, blood alcohol content, tyre pressure, and psychological state.
Old 01-30-2014, 09:06 AM   #16
ToneWrx02
Member#: 239095
2002 Wrx
Gas quality can be a huge factor.if its half a year apart test thats most likely the case.
ToneWrx02 is offline   Reply With Quote
Old 01-30-2014, 09:21 AM   #17
GrumpyPanda
Member#: 370190
2003 Fozzy
Silver and plastic
its all in your head.
GrumpyPanda is offline   Reply With Quote
Old 01-30-2014, 09:38 AM   #18
mbfinatic
Member#: 346464
2004 STI
Deleted.
mbfinatic is offline   Reply With Quote
