Old 01-23-2014, 03:45 PM   #20476
Reverend_
Member#: 315019
2016 WRX STI
Hyper Blue
Dijm8, looks fantastic! Love what you've done with the exhaust recently, too!
Reverend_ is offline   Reply With Quote
Old 01-23-2014, 04:11 PM   #20477
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Just replaced the original cabin air filter after one year.
Ew.
averagewhiteboy is offline   Reply With Quote
Old 01-23-2014, 05:22 PM   #20478
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Question for those of you with OEM heated seats.
Do you seem to have these two little "buttons" (how they're shaped and feel) under the rear portion of the lower cushion on the area to the back of your butt? Drivers side only. Doesn't seem to be as noticible on the passenger side. Just curious as to what was going on here. I'm 165lbs, so it's not because I'm fat and squishing the hell out of the seat. haha
Old 01-23-2014, 06:25 PM   #20479
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
AWB, those are thermal cutoff switches. When the seat gets too hot, the HI mode will be disabled, but the LO mode is unaffected.
HI = 55w
LO = 13w
I had to pull the seat out from my car to resolder one of them after I lost HI mode.
Old 01-23-2014, 07:26 PM   #20480
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Ahhhhhh.. Makes sense. Just wanted to make sure my seat wasn't falling apart. haha Thanks!
Old 01-24-2014, 06:23 AM   #20481
TRSAndrew
Member#: 360634
2013 Crosstrek
Orange
I'm investigating what's required to swap from CVT to the 5M. Any help you can provide is appreciated!
http://forums.nasioc.com/forums/show...9#post41335479
TRSAndrew is offline   Reply With Quote
Old 01-24-2014, 06:44 AM   #20482
r0dzilla7
Member#: 344981
2013 imp 5 dr 2.0i
Satin Pearl White
Originally Posted by averagewhiteboy View Post
Question for those of you with OEM heated seats. Do you seem to have these two little "buttons" (how they're shaped and feel) under the rear portion of the lower cushion on the area to the back of your butt? Drivers side only. Doesn't seem to be as noticible on the passenger side. Just curious as to what was going on here. I'm 165lbs, so it's not because I'm fat and squishing the hell out of the seat. haha
Not that I've noticed. They work and feel great and I'm 6'1 200 lbs so weight shouldn't be an issue.
r0dzilla7 is offline   Reply With Quote
Old 01-24-2014, 11:27 PM   #20483
JJusto
Member#: 367091
2012 Subaru Impreza
Dark Grey Metallic
Default 2012 Subaru Impreza 2.0i
Anyone in Southern Cali want to buy full brz catback oem exhaust?
JJusto is offline   Reply With Quote
Old 01-25-2014, 09:41 AM   #20484
TRSAndrew
Member#: 360634
2013 Crosstrek
Orange
How exactly do I get the fog lights to come on with the parking lights (or as DRLs ideally)?
Someone outlined it in this thread but I can't seem to locate it!
Old 01-25-2014, 11:47 AM   #20485
Tha Chakal
Member#: 372100
2013 Premium 5dr CVT
JDMSTA wired his fogs as DRLs, I think the same way as the older WRX. As for independent fogs, Here's flyboy's write up;
http://forums.nasioc.com/forums/show....php?t=2578343
Mine is tied to the ignition, so they work anytime the key is in the on position.
Tha Chakal is offline   Reply With Quote
Old 01-25-2014, 07:59 PM   #20486
Dijm8
Member#: 337144
2012 Impreza Hatch
Ice Silver
Dijm8 is offline   Reply With Quote
Old 01-25-2014, 08:27 PM   #20487
photoman-mark
Member#: 370737
2013 Impreza Base 5D
Dark Gray
^^^^nice!!!
photoman-mark is offline   Reply With Quote
Old 01-26-2014, 08:14 AM   #20488
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Why bother? If you are going to swap to a manual, research the 2014 Forester 6MT, it shares the same bellhousing, and shifts very well for the entry level, much better than the 5MT.
At very least you will have to swap the rear diff to match ratios, and the ECU. Beyond that you will have wiring and sensor differences, displays, interior bits, and now nonfunctional paddles.
BrysImpreza is online now   Reply With Quote
Old 01-26-2014, 10:03 AM   #20489
79letour
Member#: 302570
2013 XV
DGM!
Isnt that 6mt cable operated? So the shift linkage is different. I would think the direct feel of the 5mt would feel better. That said-I really would like a 6mt myself. Or hell- an aussie dual-range would be sweet,as well.
79letour is offline   Reply With Quote
Old 01-26-2014, 10:49 AM   #20490
TRSAndrew
Member#: 360634
2013 Crosstrek
Orange
That plus information in the thread linked helped me decide it's just not worth it.
Old 01-26-2014, 11:12 AM   #20491
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Hey TRSA, which retrofit setup do you recommend that you guys carry(you work for TRS right?) I'm looking for the best output for the price with the least amount of cutting (but I don't mind doing it if I have to to get the best result)
gregorz4 is offline   Reply With Quote
Old 01-26-2014, 01:25 PM   #20492
TRSAndrew
Member#: 360634
2013 Crosstrek
Orange
Yessir I run the Sales/Marketing side of things. The new Mini D2S is the best projector we've ever made. Check it out!
Old 01-26-2014, 03:31 PM   #20493
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
thanks. they are the more squared ones correct?
What's the difference with the round vs new squared projector lights?
Old 01-26-2014, 04:37 PM   #20494
TRSAndrew
Member#: 360634
2013 Crosstrek
Orange
Check out this thread for more info: http://www.hidplanet.com/forums/show...o-Mini-D2S-3-0
Old 01-26-2014, 04:46 PM   #20495
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i have to register to view pics?
Old 01-26-2014, 05:02 PM   #20496
TRSAndrew
Member#: 360634
2013 Crosstrek
Orange
Yes, but you should do that anyways if you're considering a retrofit. That's our forum and the largest related to HIDs/retrofitting.
Old 01-26-2014, 06:21 PM   #20497
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
So what are the square ones about if they have the same output?
Just based on what look of projectors one prefers?
Old 01-26-2014, 07:24 PM   #20498
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I'm not, but I want to see the pics
Old 01-27-2014, 12:51 AM   #20499
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Sooo..
currently coming up on about 7k miles on my Amsoil XL oil, still pretty much full, and I have added about 6oz to keep it at the full dot. question is do I push it to 9k, or change it out...I'm debating changing it because I do have a 2k mile trip planned in 1 week, and would rather be safer than sorry, plus with all the stupidly cold weather for the last 2 months it is probably definitely in the severe service category.
decisions.
Old 01-27-2014, 01:49 AM   #20500
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
Have fun with that. I wanted to do the same with my dad's outback a few years back. The dearlership mechanics basically told me to f off (for good reason). You're looking at a new center diff, probably crankshaft, ECU, not to mention the transmission itself, as well as probably several other components associating it to the engine. You would probably have an easier time trading into whatever you want than swapping parts out to make it.
Dirt Bringer is offline   Reply With Quote
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 09:48 PM
