Old 02-03-2014, 11:03 AM   #326
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Installing New Invidia race Equal Length Headers, I had GrimmSpeed Ceramic coat them. Bolted to a coated GrimmSpeed 44mm ewg uppipe with the new TurboSmart 45mm ewg. This new gate is so much smaller then the og tial 44mm I have on my wrx. Also much smaller the the newer Tial 38 and 44mm gates. This header and uppipe set up replaced a old APS twinscroll EL header to a merged single scroll uppipe.
All Motor work, tuning, suspension/drivetrain,subframes etc was done by me late night after Im done with work.
More pics of turbo PnP work and car on bottom of the last page.
I know these arent great pics but pics non the less.
Ian,
Old 02-03-2014, 11:05 AM   #327
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I want those wheels.
Old 02-03-2014, 11:17 AM   #328
rexworx
Member#: 103232
HAHA thanks They Barely clear my Nissan Sumitomo front brake setup... I hate Spacers, especially if you dont have extended studs, but I did add a 3mm spacer which obviuosly is the larges you should ever go on stock length studs if anything at all...
Old 02-03-2014, 11:37 AM   #329
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Can you rotate the EWG upwards (clockwise) anymore? The dump tube looks like it's at kind of a funny angle. Here's an old shot of my GrimmSpeed/Tial 44mm setup on my 2011 WRX and it's a lot straighter:
The new TurboSmart valves are great though. Definitely the way to go vs. Tial. So much smaller and the locking collar is great vs. bolting on the cover. I'll be slapping a TurboSmart EWG on mine soon too.
Old 02-03-2014, 12:15 PM   #330
rexworx
Member#: 103232
I could but actually had better clearance from the 6spd. A major reason I angled it that was was to get the exhaust coming out of the dump to not be directed at the subframe brace. Also I wanted better access to the turbo drain hose etc while having to remove as little as possible. It works for me but maybe not for others. Just my personal opinion.
Another big reason is Ive seen some cars show false knock when the gate dump is too close to the tranny. Sure I could have clocked it straight or not so much but this is what worked for me.
Theres a few things I need to clean up with the car. Im pulling the motor again soon do to a bad exhaust valve guide. Been running this motor for about 20k miles and it runs like a top. I regularly do compression and leak down just to keep note on how this build hold up etc. Just smokes a lil on start up sometimes. Which is ANNOYING as hell.
Ian,
Old 02-03-2014, 02:00 PM   #331
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Originally Posted by KingPest View Post
Also, as far as a 10cm housing is concerned, I do think it would be nice option to have. However, having such a huge turbine as the TD06H will still help us. If all else fails we can do an EWG.
With the 10cm, you are trading spool for more top end power. Which may be good for some, but not so much for others (such as the ej205).
Fierysun is offline   Reply With Quote
Old 02-03-2014, 05:53 PM   #332
SteamSpeed.com
Member#: 339860
Originally Posted by rexworx View Post
Heres a few pics of some work I did on it few weeks ago.
Before and after of the SteamSpeed STX67. This is one of the prototypes Ive been testing for SteamSpeed. So far I LOVE this turbo. Spools fast, hits hard, and holds more power through the rpm band then most would think. Ive been doing some testing for them and have been running it with out a PnP job for a few months.
All Port and Polish work is done by me.
Garrett/Mitsubishi hybrid consisting of..
STX 67
- Garrett Billet GTX2867R Compressor wheel thats brated at 47lbs/min
- STI stock style compressor housing
- MHI style journal bearing center section made by Kinugawa/Kamak with upgraded high performance bearings.
- STS TD05H 9-blade turbine made from Inconel
- 8 cm^2 hotside
-Billet adjustable wastegate. comes with 1bar "14psi" spring but can be swapped for what ever. "Now Im running the EWG setup"
More pics on top of next page.
Ian,
Nice work on that port job. Based on you feedback, the production STX 67s will have a larger wastegate opening. We can't wait to see your results.
Thanks,
Sam
SteamSpeed.com is offline   Reply With Quote
Old 02-04-2014, 12:48 AM   #333
Back Road Runner
Member#: 60082
2004 Forester STI
That's nice to hear. I like that the feedback goes back through the supplier/manufacturer to improve the product. I like that.
Back Road Runner is offline   Reply With Quote
Old 02-04-2014, 01:19 PM   #334
SteamSpeed.com
Member#: 339860
Default Always improving
We make great efforts to take our experiences as enthusiasts and implement them in our product designs. We know that buyer feedback is valuable and always consider it.
We are looking forward to all the performance results that come from our production release of the Steam STX 67, STX 71, and the STX 20G-R! Keep us posted, those of you that have ordered!
Old 02-07-2014, 06:32 PM   #335
Beard_Of_Moses
Member#: 316926
2004 wrx wagon
Looking forward to bolting up my stx 67 when it gets here. It'll be interesting to see how it does on a 2.0L. I'll post dyno results when it's all said and done.
Beard_Of_Moses is offline   Reply With Quote
Old 02-07-2014, 08:04 PM   #336
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
is there anyway we can get that list of turbos, hp and car posted in the first post?
bluemax189 is offline   Reply With Quote
Old 02-07-2014, 08:20 PM   #337
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here's the list. I can't add it to the first post though.
I'm working on compiling the results into a more easily reviewed list. The main pieces of info will be in the list, as well as a link to the post for the rest of the details. I am omitting posts that don't have enough details or are not in the correct format (ie. BHP instead of WHP). List is sorted by WHP figures. I believe the list is current up through this post. I can keep adding to the list as more results are posted.
Results List:
WHP / WTQ | 1/4 @ MPH | TURBO @ PSI | FUEL | VEHICLE | USERNAME | LINK
434 / 408 | XX.X @ XXX | TD06H 60-1 @ 24psi | 93 | 2006 STI | STi MAN86 | LINK
427 / 413 | XX.X @ XXX | TD06SL2-5371 @ 25psi | E85 | 2002 WRX | xluben | LINK
415 / 425 | XX.X @ XXX | TD06SL2 20G @ 21psi | 93 | 2009 WRX | 20wrx09 | LINK
398 / 388 | XX.X @ XXX | TD06H 20G @ 25psi | Meth | 2004 WRX | mod maniac | LINK
390 / 404 | XX.X @ XXX | TD05H 20G @ 20psi | E85 | 2007 STI | *Ulimited* | LINK
387 / 379 | XX.X @ XXX | TD05H 20G @ 24psi | Meth | 2003 STI | bhpsti | LINK
380 / 390 | XX.X @ XXX | TD05H 20G @ 20psi | 93 | 2007 STI | *Ulimited* | LINK
377 / 374 | 11.7 @ 116 | TD06SL2 20G @ 25psi | E85 | 99 Impreza | Fuji K | LINK
370 / 381 | XX.X @ XXX | TD06SL2 20G @ 19psi | 93 | 2011 WRX | ResidentR | LINK
370 / 370 | XX.X @ XXX | TD05H 18G @ ??psi | ?? | 2007 WRX | RallyImprezive | LINK
357 / 317 | XX.X @ XXX | TD06H 20G @ 27psi | 93 | 2003 STI | ElSpa | LINK
349 / 349 | XX.X @ XXX | TD06SL2 20G @ 19psi | 93 | 2006 STI | powerls | LINK
340 / 351 | XX.X @ XXX | TD05H 20G @ 19psi | 93 | 2013 WRX | Silviaspeck | LINK
324 / 332 | XX.X @ XXX | TD05H 18G @ 18psi | E50 | 2006 WRX | Ferraz | LINK
317 / 344 | XX.X @ XXX | TD06SL2 18G @ 19psi | 92 | 2006 WRX | drmichael | LINK
307 / 333 | XX.X @ XXX | TD05H 16G @ 22psi | 93 | 2008 WRX | chemtek| LINK
Old 02-08-2014, 07:19 AM   #338
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
oh I know, was asking steamspeed. it is the results thread and you posted them up beautifully that they should be on the first post.
Old 02-18-2014, 08:10 AM   #339
Dr. octagon
Member#: 171127
GDA BW 8375 SOLD
Bump.
Decided TD06H 25g 8cm......really wanted 10cm but 10 cm was not available
Bought it new, ported and polished ,anti surge 3 inch cover, billet wheel, and 9 blade exhaust wheel and internal wastegate welded shut.
Should be here this week, I will post pictures.
Ed
Old 02-18-2014, 02:21 PM   #340
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Someone run some times! Numbers are nice to see, but you know... What can the car do? I can't be the only one with the E.T.
Old 02-18-2014, 02:24 PM   #341
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Maybe we can take mine out this summer.
Old 02-18-2014, 02:31 PM   #342
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
We must!
Old 02-18-2014, 06:46 PM   #343
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
2011 forester xt full interior including child car seats kinugawa base td06sl2 20g 8cm with suporting mods e85 and stock trans 4eat auto. Went 12.0 @116mph but this year i have built motor and high stall converter looking for mid 11's full weight if i ever get it all sorted out.
nate_fisher is offline   Reply With Quote
Old 02-18-2014, 08:00 PM   #344
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
amazing times!!!
Old 02-18-2014, 09:07 PM   #345
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
How many passes you make on the stock auto??
Did you blow it up?
Old 02-18-2014, 10:26 PM   #346
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I thought I would plug the kinugawa td06-20g again. Not only did it make great hp 398 with great torque 388 but it also did a 11.758 at 111.55 in the 1/4. Awsome numbers I am very pleased. Now if I can get my fxt build to run like this I will be very happy.
Old 02-19-2014, 10:01 AM   #347
Drifting STI
Member#: 41220
1998 Legacy Wagon
Has anyone fitted a heat shield onto this turbo? Would a Cobb heatshield fit?
Drifting STI is offline   Reply With Quote
Old 02-19-2014, 10:09 AM   #348
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I don't see why you couldn't. The hot side isn't a twin scroll T6
Old 02-19-2014, 10:40 AM   #349
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I put the OEM heat shield on mine. It was already cut for a bellmouth downpipe and I also had to notch it for wastegate arm clearance. Other than that it fits fine. Any aftermarket heat shield should fit.
Old 02-19-2014, 01:11 PM   #350
SteamSpeed.com
Member#: 339860
Results List:
427 / 413 | XX.X @ XXX | STX 71 prototype @ 25psi | E85 | 2002 WRX | xluben | LINK
Thanks for the compiled list! I added it to the first post. We refer to your "TD06SL2-5371" just as our STX 71 prototype FYI. The production STX 71 will be a little bigger than the prototype. Our production order should get shipped out to us this week. xluben's STX 71 prototype has been upgraded to our production spec STX 71, so we are super excited to see his before and after results. Hopefully we will see 450+ WHP on the production STX 71 turbos.
Thanks again,
Sam
