Old 01-31-2014, 08:34 PM   #1
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
Default wagon8r bugeye 272k miles 301 awhp original engine and trans
Had my car tuned last weekend after putting on the vf24.
Now I know that a vf on a bugeye is certainly not new news. But I know that people frown away from tuning these as much after say 150k miles. Not me. I figure it doesn't owe me anything. But no knock, safe afr's and not crazy boost on pump 91, I figure we'll see what she can do!
Car: 2002 WRX wagon 5-sp, 272k miles, been at "stage 2" since 230k
Tuner: Graham Gaylord (Boosted Performance)
Dyno Info: Virtual Dyno
Transmission: Stock 5MT
Peak HP at RPM: 301@ 5993
Peak Torque at RPM: 282 @ 4794
Baseline hp/tq for a stock on same dyno: 165 hp?
Target Boost: 18 psi
Target AFR: ~10.5
Fuel: 91 pump
Engine/Power Modifications:
VF24 turbo, light PnP + ceramic coated hot side
sti pinks cleaned by witchhunter
Walbro 255
AEM CAI
Godspeed turbo inlet hose
GTspec EL headers + uppipe(ceramic coated)
tial 38mm mvs ewg
ebay FMIC
Grimmspeed 3-port EBCS
NGK iridium plugs
HKS 3" downpipe
stock '04 sti exhaust
gimmick lightweight crank pulley
Driveline Modifications: Custom shifter bushings, ACT 13 lb. flywheel freshly replaced OEM replacement Exedy clutch, Stiffer mount mounts and trans mount I forget what kind, I'm thinking they're Subaru p/ns though.
Suspension Modifications: none
Other Modifications: many random things, none of any significance
So anyways, I was happy. I know this is just a virtual dyno, so I'm not taking it as gospel truth, but it gives me a good idea of where the car sits. It's my daily driver, I put on about 18k miles a year (bought it about 3 years ago with 227k) and it's a blast to drive. Certainly not king of the streets, but very surprising. It's a completely stock exterior '02 psm bugeye wagon and the only noticeable things if you know what you're looking for are the EGT and wideband gauges inside, and the hoodscoop delete plate and black FMIC.
My goals for the car when I bought it were:
300 whp
12 sec 1/4 mile
30 mpg
So far I've gotten 30+ mpg on a few trips, my last time at the track was a 13.38 and 13.40 @103 with a horrible clutch, and the 300 whp thing isn't really set in stone, but it was just a nice round target number. So, I may scrape a 12 this season with launch control and my new coilovers (not yet installed) and we'll just call it good from there.
So, as it turns out subarus ARE durable!
nevin95 LSi is offline   Reply With Quote
Old 01-31-2014, 10:10 PM   #2
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
So cool. Congrats.
Old 02-01-2014, 11:13 AM   #3
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
Thanks man!
I had done a compression test about a month ago and it was still 125 psi (very cold) across the board, so I figured we'd be good to give it a whirl!
I stuck my borescope down the cylinders (it's a tiny camera) and I could still see crosshatch all the way up and down the cylinders too. Very impressed.
Old 02-01-2014, 02:40 PM   #4
2000subie
Member#: 207638
2004 WRX
Yellow
I ran 12.1 at 116mph on my stock 205 at 296whp, so you should be able to get mid low 12's pretty easy. I also went 12.6 at 112mph on the same engine at 244whp. So I'd say you've more than likely met your goals!
2000subie is offline   Reply With Quote
Old 02-01-2014, 03:49 PM   #5
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
Well, we'll see. I don't like to assume anything 'til I see the results. Now that I know my powerband, I have a better idea of where to shift though.
I don't get to the track often. Maybe 8 passes a year. So I'm not a seasoned pro and I don't get a lot of practice, but I think the 12 is there with a good launch. My horrible suspension was not helping me either. SOO much squat under acceleration, lots of wasted energy there. I think the coilovers will definitely help me there.
Old 02-01-2014, 05:09 PM   #6
Nomadgene
Member#: 22923
2002 EJ207 V8 1.5xtr
TWIN-SCROLL Black Bugeye
Outstanding…..not nearly enough of these stories in my opinion. My bugeye is the best, most reliable vehicle I've ever owned.
Nomadgene is offline   Reply With Quote
Old 02-01-2014, 05:46 PM   #7
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
It's never left me stranded, has gone where many cars wouldn't dare to look, and loves to play! I certainly can't complain.
Old 02-01-2014, 05:51 PM   #8
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Wow thats good power and props for keeping it running strong for so long.
rexworx is online now   Reply With Quote
Old 02-01-2014, 05:55 PM   #9
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
Yeah, the power is so smooth, I love it!
And I bought it with ~225k on it, so whoever had it before me had taken care of it mechanically very well. I was blessed to find a good one!
Now my goals are:
1. 12 sec 1/4 mile
2. 300whp
3. 30mpg
4. 300,000 miles
Old 02-01-2014, 10:12 PM   #10
SubyLarry
Member#: 289426
2002 Impreza WRX
MBP
You got 30+ mpg? WOW. Even all highway driving, I average 26-27 mpg and my tires filled to 45psi cold.
SubyLarry is offline   Reply With Quote
Old 02-01-2014, 11:27 PM   #11
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
Yep, and that was on the vf, but untuned. The bigger turbine housing made a difference for sure. This was on a 60-62 mph cruise, but it did it a couple of times for me! Everyday driving is more in the 24-26 neighborhood, and less now with warming it up everyday, but it treats me pretty well in the fuel department.
My good mileage was with my sti wheels and 215/45r17 bfg summer tires at 40 psi, too though. I know my stock 16" wheels and winterforce tires couldn't hit 30 mpg, too much drag.
I also noticed a +1 mpg increase when I made the hood scoop delete after going FMIC. Drag eats mileage!
If I had money to burn I would go through every bearing in the car and have it ceramic treated, and do lots of things to get the mileage up. Maybe my next goal should be 35 mpg! hahah
Old 02-02-2014, 10:33 AM   #12
Honest Bob
Member#: 94698
2005 30R Wagon
The 205's are very reliable if the owner keeps them filled with oil. I've got a rotated 30r on my 05 with 140k. No where near the amount of miles you have but I have seen two other local 205's with over 300k on them. I think one of them burned up a valve but otherwise solid.
Honest Bob is offline   Reply With Quote
Old 02-02-2014, 03:28 PM   #13
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
There's another in the iowa Subaru club that has a few more miles than mine, I think it's an '03. But I have seen more than a few subies go for more than 300k. Hoping this one will do the same! And I've thought about a burnt valve too, but I guess the best I can do is keep a good tune on it and hope for the best. Stuff wears out, life is hard!
If this engine would go bad, I'd probably just take it out and rebuilt it anyways.
Old 02-02-2014, 05:44 PM   #14
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Nice to see someone else using a VF24. My friend had one on his car for probably 300k miles. I'm not sure if it's still on the car as he sold it a few months ago. But it was the stock block and he was the 2nd owner of the turbo. Pretty impressive combo.
Had another friend running a VF23 for awhile too. There are certainly "better" turbo options out there, but it's simply cool to see people running some old-school setups.
Scooby921 is offline   Reply With Quote
Old 02-02-2014, 06:12 PM   #15
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
Yeah, it's a super smooth setup. I love how the power just builds and builds. Not the king of the streets, but definitely a fun car to drive. Great midrange.
Old 02-04-2014, 03:23 PM   #16
mattyboost
Member#: 380738
2005 fxt
wow. must've took great care of her
mattyboost is offline   Reply With Quote
Old 02-05-2014, 03:46 AM   #17
17s
Member#: 363276
This car really must have been babied most of its life. Respect.
17s is offline   Reply With Quote
Old 02-05-2014, 09:53 PM   #18
BraveSTi
Member#: 262030
That is outstanding….NUFF respect!
BraveSTi is offline   Reply With Quote
Old 02-05-2014, 11:29 PM   #19
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
Very nice! Nice to see you keep it going and using it!
Old 02-08-2014, 04:50 PM   #20
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
Well, cars are meant to be driven! It's a great winter car too.
It bugs me when cars are thought to be "junk" just because they get to 100k miles though. And some ARE junk at 100k, but If they are taken care of, they will give you miles of smiles!
Old 02-09-2014, 04:06 PM   #21
wrx2383
Member#: 380100
Thanks for posting....I have 165xxx on mine and it will no longer be my daily driver. I wanted to start tinkering with mine, but was nervous with the mileage. Posts like this make me a bit more comfortable. I've been pretty much stock for those miles and would like to think I take good care of the car.
wrx2383 is offline   Reply With Quote
Old 02-09-2014, 05:22 PM   #22
nonameasian
Member#: 380119
2008 Sti
very nice. congrats!
nonameasian is offline   Reply With Quote
