Old 12-14-2013, 01:57 PM   #1
WRXin04
Member#: 52374
2013 WRX Hatch
Default Yimi Sport Tuned 2013 VF52 WRX - 91Octane - 314whp/336wtq
Shop: Yimi Sport Tuning
Tuner: Paul Leung
Dyno Type: Dynojet
Temp: 60F
Humidity:15%
Boost: 18.8PSI tapering to 14PSI
Fuel: Shell 91 Octane
Target AFR: 10.6
Peak HP: 314WHP
Peak Torque: 336WTQ
Transmission: Stock 5 speed/Stock Clutch
Gear: 3rd
Engine Management: Cobb V3 Accessport
Relevant Engine/Power Modifications:
- Process West Top Mount Intercooler
- Tial MV-S 38mm External Wastegate
- Grimmspeed External Wastegate Up Pipe
- Grimmspeed EBCS
- Grimmspeed Internal Wastegate Bracket
- Injector Dynamics 1000cc Fuel Injectors
- Injector Dynamics PnP Adapters - USCAR to Denso
- Forge Bypass Valve - Black
- DW 65c Fuel Pump
- NGK Iridium Spark Plugs - One Step Colder
- AEM Cold Air Intake
- Ark Grip Catback Exhaust
- Invidia Divorced Downpipe (Catless) w/ 2 Bungs
- GrimmSpeed Turbo Heat Shield
Dyno Sheet:
IMG_0001 by T_Forde, on Flickr
Photo of the car for fun
1412717_10202293000513712_1355766635_o by T_Forde, on Flickr
Car feels great! The guys at Yimi went the extra mile take care of me. Both Pauls and the entire Yimi crew are excellent!
Full build here - http://forums.nasioc.com/forums/show....php?t=2513235
WRXin04 is offline   Reply With Quote
Old 12-14-2013, 04:23 PM   #2
K1WRC
Member#: 64511
2003 WRX sedan WRB
VF36 EJ207
That's a healthy WRX! Lookin good
K1WRC is offline   Reply With Quote
Old 12-15-2013, 04:14 AM   #3
wuuusaa
Member#: 92894
2015 Wrx
I'm kind of curious as to why it didn't hold more boost at higher rpms with all your mods?? Either way nice numbers, any plans for E85?
wuuusaa is offline   Reply With Quote
Old 12-15-2013, 07:32 AM   #4
BroBroBroBroBro
Member#: 338211
2011 wrx cobb 20G
im just wondering if you had 93 how much more could you squeeze out?
this looks really good though the way it is, but i know people have made more. At this point the car has so much money in it just for a small gain over stock injectors.
It doesnt really taper that much at redline as a regular stage 2 so i think thats pretty damn good. How much more power did you make with ewg and injectors? or was this all done at once?
BroBroBroBroBro is offline   Reply With Quote
Old 12-16-2013, 01:02 PM   #5
WRXin04
Member#: 52374
2013 WRX Hatch
Thanks! Its a ton of fun!
When these turbos are out of their efficiency range, more boost usually yields LESS or equal power. After a certain point your just blowing extremely hot air. If E85 was available in my area that's what I would be running. Hopefully its coming soon!
Everything was done all at once. Paul was saying the external wastegate definitely prevented the power from tapering so quickly over an internally gated setup.
Old 12-16-2013, 01:05 PM   #6
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
YIMI sport FTW
bmxhotsauce is offline   Reply With Quote
Old 12-16-2013, 04:41 PM   #7
gfreed1
Member#: 272788
2011 WRX 1.5XTR
DGM 380AWHP 380TQ
Nice looking ride - I have the same setup and on 93 pump im pushing 323WHP and 351WTQ. I had my tuner (Jorge, IAG) tune it down. First tune was 335WHP and 362WTQ and I was concerned about the tranny. The power feels great but I need more after a year on this setup.
I just bought a stage 2 clutch and I am going to purchase blast plates from Moore Performance, do fuel system and E-85. Maybe 1.5XTR
Car looks good man!
gfreed1 is offline   Reply With Quote
Old 12-16-2013, 05:12 PM   #8
WRXin04
Member#: 52374
2013 WRX Hatch
Car looks good man!
Thanks man! I have similar plans for this car. California 91 really just bums me out My future turbo setup will really depend on the availability of E85 when that time comes, but it will include a clutch, inlet, TGV deletes and an equal length header. Good luck with your build!
Old 12-17-2013, 03:30 PM   #9
BroBroBroBroBro
Member#: 338211
2011 wrx cobb 20G
I added an EWG and a frontmount with stock injectors and thats where i left off. it still tapers heavy towards redline and my IDC are very high, over 105 at WOT...but the taper keeps it safe. My next mod is ID 1000 and im sitting here looking at my used invidia headers.
best thing is comparing results on the same dyno. ill have 3 overlays to look at as i progress. although im paying for tuning twice the retune was pretty cheap compared to the initial stage 2 tune.
Old 02-07-2014, 12:10 PM   #10
extransam
Member#: 287109
04 WRX 18G Hybrid
Absolutely beautiful car... great #s too.
Are you still on stock clutch? That is impressive if so.
extransam is offline   Reply With Quote
Old 02-07-2014, 05:38 PM   #11
WRXin04
Member#: 52374
2013 WRX Hatch
Thanks! Yes, still on stock clutch and holding strong. My research shows the stock clutch will hold until about 400WTQ if treated nicely.
Old 02-07-2014, 05:58 PM   #12
Smdavis27
Member#: 219455
2009 WRX Sedan
It sure will, i did 420ft-lbs and it held it for 20k miles till i decided to go to a bigger turbo and switched to an hdss
Smdavis27 is offline   Reply With Quote
Old 02-08-2014, 09:54 PM   #13
extransam
Member#: 287109
04 WRX 18G Hybrid
Wow when did they upgrade the stocker? 09?
Because GDs go out at about 300ftlbs...
Old 02-09-2014, 12:49 PM   #14
ckyguy68
Member#: 316296
2006 STIROID
[email protected] on 29psi
Depends alot on the driver. I've seen 40k mile stock clutches hold 350+ wtq.
ckyguy68 is offline   Reply With Quote
Old 02-09-2014, 07:52 PM   #15
Ghostlystang
Member#: 338515
2013 WRX 6spd swap'd
305/345 ([email protected])
Nice numbers especially on 91!
Ghostlystang is offline   Reply With Quote
