Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 02-01-2014, 07:38 PM   #101
Tsappin
Member#: 364564
2013 Wrx premium
Swp
Originally Posted by Tsappin View Post
Hi, I have a 2013 wrx and was looking for a directech sheet for it. Does anyone here have access to get this sheet?
never mind I got the wiring information I needed.
Tsappin is offline   Reply With Quote
Old 02-07-2014, 05:01 PM   #102
musicfreak190
Member#: 380933
2013 WRX STi
So... Basically I can avoid the Manual Transmission Mode by bypassing the clutch normally.. and then wiring the NSS wire (from the ECU wires?) to the hood pin input on the remote start.
This will trick the remote start into thinking the hood is closed.. (actually just the car in neutral) and can start it with help of the clutch bypass?
Please if anyone can confirm.
musicfreak190 is offline   Reply With Quote
Old 02-10-2014, 01:19 AM   #103
blessthekellen
Member#: 273859
MY98
WRX
Yes that is what it means.
What I do for my manual transmission starters in subarus is hook up the hood pin input as well as the tach wire to the Ecu (this means I don't have to wire into the engine bay at all)
As well I hook up the ebrake wire still to the ebrake input on the starter brain. Reason I do this is just for another safety feature meaning the ebrake MUST be engaged in order to remote start.
Vehicle in neutral. Ebrake up. Will start.
Vehicle in gear. Ebrake up. Won't start.
Vehicle in neutral. Ebrake down. Won't start.
Just as a precaution in case for some reason the hoodpin input fails. Not very common but over the past 5 years of installing I have had brains fail where they think the hood is either always open or always closed no matter what the situation.
Hope this helps.
blessthekellen is offline   Reply With Quote
Old 02-10-2014, 11:55 AM   #104
musicfreak190
Member#: 380933
2013 WRX STi
Hope this helps.
That is perfect... I want it just like that..
Could I bother you to clarify on this?
"What I do for my manual transmission starters in subarus is hook up the hood pin input as well as the tach wire to the Ecu (this means I don't have to wire into the engine bay at all)"
So the hood pin input on the starter gets connected to the (NSS and Tach Wire) ?
I apologize for the newbness.. Don't worry I don't plan on even attempting this for a few months until I have zero doubts.
Old 03-17-2015, 08:34 PM   #105
Rezz
Member#: 415888
Chapter/Region: HIIC
2008 IMPREZA WRX
i have 08 wrx
I was wondering if there is any diference between a turbo timer and a remote starter. If there is, what are they?
If someone can help me out with this i would appreciate it.
Rezz is offline   Reply With Quote
Old 03-17-2015, 08:43 PM   #106
acrazydood
Member#: 306459
2012 Impreza WRX STi
Dark Gray Metallic
Originally Posted by Rezz View Post
i have 08 wrx
The only function of a turbo timer is to keep the car running after taking the key out to give the turbo time to cool down before shutting the engine off.
A remote start will allow you to start and stop you're engine remotely with a key fob or even a phone, depending on the setup you get. Many remote starts will also have a turbo timer function in place as well.
I have a viper system, and if I want to use the turbo timer function, all I have to do is press a button to activate it. I can then take out the key and lock the car and it will shut itself off in 3 minutes. I think that's what I have it set to anyway, it can be programmed with a few different delays.
acrazydood is online now   Reply With Quote
Old 03-17-2015, 08:45 PM   #107
Rezz
Member#: 415888
2008 IMPREZA WRX
Thank you.
What by pass systems would you recommend, for installing a remote start on a manual transmission
Old 03-17-2015, 08:51 PM   #108
acrazydood
Member#: 306459
Dark Gray Metallic
I have the "Directed Electronics Universal Immobilizer Bypass" P/N: 556UW
It works great for me, I can't quite remember how I had to do the ring around the key. I might have just tapped into the one that was there. There's probably a couple ways to do it.
Since you're installing it on a manual just make sure the neutral wire is set up correctly so you don't have any big accidents.
Were you asking about the immobilizer bypass or just a general install on a manual?
Old 03-23-2015, 07:55 PM   #109
12wrx1
Member#: 386873
any way to have remote start while keeping the stock immobilizer???
12wrx1 is offline   Reply With Quote
Old 03-23-2015, 08:59 PM   #110
tilegend
Member#: 295565
you're not removing the factory immobilizer,
a bypass unit is only going to send signal when you activate remote start.
tilegend is offline   Reply With Quote
***liteSPEC 08+ WRX STI HB Titanium Exhaust System GROUP BUY Starting at $750*** liteSPEC Vendor 'Group Buy' Classifieds 177 02-20-2013 07:51 PM
FS : MN: Perrin Cold Air Intake 08+ WRX/STI and spare foam filter. hotrodrex MWSOC Private Classifieds 2 02-04-2012 10:07 AM
Invidia Q300 Catback for 08 STI, AEM CAI for 08 WRX/STI, and Element Tuning for 02+! WorldOne NWIC Vendor Classifieds 9 03-25-2011 11:11 AM
2004 STi Remote Start, Keyless entry inop,alarm activates Murphdog Car Audio, Video & Security 5 12-30-2009 10:48 AM
vf48, 08 STi TMIC, LGT/08+ WRX/STI downpipe, 08 injectors vhalin Engine/Power/Exhaust 23 12-09-2008 10:07 PM
