Old 01-30-2013, 11:40 AM   #1
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Default Borg Warner EFR9180- 2006 WRX Wagon
I edited this post and somehow double posted- mods please delete either one.
Event: Dyno Tune
Ambient Temp: 50
Elevation: 5400'
Weather: cloudy
Tires: Bridgestone RE090's- then again on BFG G force drag radials
Car: 2006 WRX Limited Wagon
Tuner: Myself
Dyno Info: Dynojet
Transmission: 2005 STi 6MT with rallispec long gear set
Gear: 3rd
Peak HP at RPM: 823 at 6700
Peak Torque at RPM: 667 at 6200
Baseline hp/tq for a stock STi: 245-255hp/250-260tq
Target Boost: 33
Target AFR: 11.3
Fuel: E70 (winter blend)
Engine/Power Modifications:
AEM EMS V1
2005 EJ257 Block sleeved by Benson
CP Pistons 99.5mm (moly coated skirts, ceramic crowns)
Carrillo Pro H beam rods, Carrillo bolts
Heat treated oem crank
King bearings
2006 Sti AVCS heads, ported
GSC Stage 2 cams (272, AVCS)
BC +1mm intake/exhaust valves
BC springs, titanium retainers
ARP L19 Studs
08 Sti oil pump, 11mm
TGV deletes
AP Fuel rails
Aeromotive FPR
ID2200cc injectors
Integrated Engineering Surge tank with Dual bosch 044 pumps
Cosworth Intake manifold (reverse mount)
Treadstone fmic core
Full Race Twinscroll T4 rotated turbo kit
BorgWarner EFR 9180 EWG 1.05 T4
Finally got to put the EFR through it's paces. I had previously run the S300SX 91-79 .91 AR on the car and was pretty happy with it.
I am AMAZED that a 94lb/min turbo is spooling 400-500rpm sooner than the older 82lb/min turbo.
On the first trip to the dyno last week I ran my 2007 STi RE090 tires which have good tread but are very dry. The car made 805/636 SAE at 33psi, but I suspected the tires were spinning. Here's a graph of those pulls:
And a graph vs the old 91-79- The 91-79 was at 34psi.
I decided to try the dyno again yesterday, this time with my drag radials. The results were that the car held traction better to about 6500rpm, then let go hard. The tune and boost were untouched from the previous dyno.
Now, SAE numbers are great for bragging rights, but we are at 5400' and our correction factor is pretty high. Here is the uncorrected graph, which in my opinion is still a lot of power for this altitude, at only 33psi ( I want to run 37-38 but need traction). A stage 2 STi only makes 250 uncorrected on this dyno.
Someone want to help me embed these?
https://www.youtube.com/watch?v=ncnswSPEq4M
https://www.youtube.com/watch?v=4u0JHvsxEZc
low quality phone vid of the 823 pull
https://www.youtube.com/watch?v=CViAUFZeBwk
06rexwagon is offline   Reply With Quote
Old 02-07-2014, 07:41 PM   #2
Shatley02
Member#: 250619
update bump
Shatley02 is offline   Reply With Quote
Old 02-07-2014, 09:52 PM   #3
Widebody Spec C
Member#: 361215
06 Wrx Sti Spec C
Very nice...wish I had the funds to do a build like this
Widebody Spec C is offline   Reply With Quote
Old 02-07-2014, 11:15 PM   #4
06rexwagon
Member#: 114730
[email protected]
Update
Decided to dial in the new AEM EMS and turn it up a little more. Car really liked that extra 3 psi of boost!
New numbers:
For the purists, uncorrected numbers:
All on winter blend E70 from Valero.
Old 02-08-2014, 04:54 PM   #5
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
Simply stupendous!
How does the efr compare to the old sx for drivability?
nevin95 LSi is offline   Reply With Quote
Old 02-08-2014, 08:13 PM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
So when you coming up here?
Old 02-08-2014, 08:16 PM   #7
06rexwagon
Member#: 114730
[email protected]
You worried?
Old 02-08-2014, 08:23 PM   #8
06rexwagon
Member#: 114730
[email protected]
Originally Posted by nevin95 LSi View Post
Simply stupendous!
Night and day difference. The efr is so much more responsive and spools at least 500rpm sooner.
Old 02-08-2014, 11:54 PM   #9
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Originally Posted by 06rexwagon View Post
You worried?
Lol no, not at all.
come and play!
Old 02-09-2014, 12:04 AM   #10
06rexwagon
Member#: 114730
[email protected]
Lol no, not at all.
come and play!
Haha I know. So far though.
Old 02-09-2014, 12:14 AM   #11
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Come enjoy the great outdoors!
Old 02-09-2014, 12:14 PM   #12
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Why don't you just scale the graph the same on both axis? Nice pickup in power.
project_skyline is offline   Reply With Quote
Old 02-09-2014, 12:17 PM   #13
06rexwagon
Member#: 114730
[email protected]
That was bugging me too so last time I went by the shop I pulled the runfiles and did just that.
Old 02-09-2014, 12:29 PM   #14
idratherbesurfing
Member#: 282972
2006 Sti
cgm
Incredible man! 900 from a subaru. Can you get another 100hp some how? haha
idratherbesurfing is offline   Reply With Quote
Old 02-09-2014, 12:34 PM   #15
06rexwagon
Member#: 114730
[email protected]
Our correction factor here is high, 17% that day- because we live at 5400'. Uncorrected was 772 which is still a lot for a dyno that stock sti's dyno around 200-210 uncorrected on.
Old 02-10-2014, 12:35 AM   #16
Red Rose
Member#: 334801
This numbers are insane. How does the car drive though? Sure it's an STi but you are putting 900 hp onto the chassis of an economy car.
Red Rose is offline   Reply With Quote
Old 02-10-2014, 01:05 PM   #17
street carp
Member#: 216768
2016 STI
HYPER BLUE
i gotta get me one of those EFR turbos. one day....
street carp is offline   Reply With Quote
