Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 02-07-2013, 10:33 PM   #51
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
Originally Posted by Paul View Post
Have you looked at the BC I-beans? They can be had for cheap new after some searching.
I did a build for a customer and we ended up using a BC hbeam with the 625+ rod bolts. The BC stuff is nice, I wont hesitate to use their rods because they're quality and very cost effective!
I have full confidence they'll be able to handle his GT3582R twinscroll full-race setup.
Flat 4 Motorsport is offline   Reply With Quote
Old 02-08-2013, 07:05 AM   #52
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
See! Another success story with H beams!
suba03ru is offline   Reply With Quote
Old 02-08-2013, 12:42 PM   #53
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Originally Posted by suba03ru View Post
I have and I can get a great deal on them. I just keep reading things that say H beams are plenty strong then I see I beams are the way to go. Ah! Why do. have so many rods on my mind. . . . . . . Any takers on that one? Lol.
I wouldnt get too caught up in the H vs I beam. Go off power rating and your power goal. The BC I Beams are rated around 250-300hp per cylinder which would give you plenty of head room in the future. For 600$ I think its worth the couple hundred over a cheaper H beam...or $50-100 over the H tuff
Old 02-08-2013, 01:03 PM   #54
Paul
Member#: 56203
00 RSTI Coupe
dbl post..
Old 02-09-2013, 10:01 AM   #55
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Hmmmm also a good point. I think I'm ordering some I beams.
Old 02-10-2013, 02:26 PM   #56
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Sunday is wiring day.
Old 02-13-2013, 09:19 PM   #57
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Got a 2.0 block out of a running car if anyone needs one.
Old 02-26-2013, 05:54 PM   #58
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Short block sold and rota svn's ordered.
Old 04-09-2013, 09:20 PM   #59
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Been doing a ton of little stuff lately. Rewiring the wiring harness, deleting old plugs and sensor wires no longer being used. Doing some painting and cleaning. Stripped the sound deadening material and all items not being used from the interior.
Old 01-20-2014, 06:38 PM   #60
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Bump me back from the dead. Over the last year a ton of things have changed for me, not so much the car. Wife drained my account and slept with the neighbor to become my ex wife. Moved to Oklahoma. Machine shop dropped off the face of the earth for 10 months. Ugh.
Anyway! Car is in the garage and the build is back on. Stay tuned.
Old 02-10-2014, 03:16 PM   #61
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Build is picking back up. Got a few things for sale in the classifieds.
Old 02-13-2014, 04:21 PM   #62
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Vision is shifting slightly. I'm looking into a custom V-Mount setup.
Old 02-13-2014, 06:46 PM   #63
some dude
Member#: 100300
06 WRX
CGM
Did the impact and PB blaster get the cam gears off?
That was a question from a little back in the thread.
I'm sorry to hear about your troubles
some dude is offline   Reply With Quote
Old 02-13-2014, 06:58 PM   #64
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Nope. Had to weld a socket and clamp a timing belt around it. Then used a giant breaker bar.
Old 02-17-2014, 05:36 PM   #65
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
A move in the middle of a build will throw a monkey wrench into the project.
Old 02-18-2014, 01:28 AM   #66
tyrel.boyce
Member#: 270178
2002 Subaru WRB
380HP stock motor HTA68
Love the wheels.
tyrel.boyce is offline   Reply With Quote
Old 02-18-2014, 08:18 AM   #67
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Originally Posted by tyrel.boyce View Post
Love the wheels.
Thanks. I do too. They look proper on these cars.
Old 05-12-2014, 08:49 AM   #68
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Spare tire well subwoofer removed and 10lbs of sound deadening was stuck to the metal, dry ice was no match, so...... lets yank it out all together.
Gigantic hole framed with 1"x1" aluminium stock.
Sheet of aluminium shapped, cut, and drilled. Ready to be riveted in.
Riveted, and fuel system componenets placed.
Old 05-12-2014, 08:52 AM   #69
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
I purchased a spare fuel hanger assembly to attempt setting it up for bulkhead fittings as seen in the "Fuel System" thread.
Existing hanger assembly.
Top plate painted to match the paint scheme. Bulkhead fittings installed and reassembled with a Walbro to feed the surge tank.
Old 05-12-2014, 08:54 AM   #70
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Had to take advantage of the beautiful day and get the long travel Rhino out and about.
Old 05-12-2014, 07:35 PM   #71
Serkan
Member#: 180514
2004 Sti
Did you weight the factory trunk floor you cut out ?
Do you think you saved any weight ? (excluding spare tire, jack etc)
Project look great so far.
Serkan is offline   Reply With Quote
Old 05-12-2014, 08:39 PM   #72
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
I did not, however coated in all that sound deadening and additional dynamat Crap that was in there from the sub woofer easily weighed four times that of the aluminum frame and sheet. I can say it's definitely a weight savings, how much exactly, I don't know.
Old 05-13-2014, 08:59 AM   #73
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Evap system yanked last night. Just need a breather filter for the one vent hose.
Old 05-13-2014, 10:05 AM   #74
Razgeiz
Member#: 358782
2013 STi
Just stumbled upon this build lools great! Sucks about the troubles between but hey life is life. What's the rough time frame on the whole thing getting done?
Razgeiz is offline   Reply With Quote
Old 05-13-2014, 11:13 AM   #75
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Thanks. Yea, such is life though. No worries. Well, I've got a little girl due on July 4th (AMERICA!!!) so hoping for late summer/fall time frame for completion. But as all in depth projects go I'm sure it'll be after that.
