Old 02-09-2014, 10:21 AM   #1
tcpip4lyfe
Member#: 355361
2004 WRX
Default Thrust Bearing way too tight. What do?
I'm putting together an EJ20. Crank has been ground 10-10 and I ordered .25 oversized king bearings. Everything has been spot on clearance wise so far except for the thrust bearing sidewall clearance. When I drop in the crank and torque down the case, the crank won't even move because the thrust bearing is right up against the back of the crank with 0 clearance.
What do?
tcpip4lyfe is offline   Reply With Quote
Old 02-09-2014, 10:35 AM   #2
DisoDisp
Member#: 187648
2007 WRX
By oversize I assume you mean +0.025mm
Get looser bearings.
You may need to mix and match to get proper clearances.
Eg 1 shell .std and one 0.025mm oversize
DisoDisp is offline   Reply With Quote
Old 02-09-2014, 10:36 AM   #3
sidewayz
Member#: 5810
2001 S366 2.5RS
1000g sand paper, spray wd40 on the paper and figure 8 the thrust bearing on the paper lightly.
sidewayz is offline   Reply With Quote
Old 02-09-2014, 10:37 AM   #4
tcpip4lyfe
Member#: 355361
2004 WRX
Just on the crank side I assume?
Old 02-09-2014, 10:39 AM   #5
sidewayz
Member#: 5810
2001 S366 2.5RS
Both sides are crank side. Google thrust bearing sanding
Old 02-09-2014, 10:46 AM   #6
tcpip4lyfe
Member#: 355361
2004 WRX
I guess the halves that are against the crank would have been a better description. Not the halves that are against the main seal.
Old 02-09-2014, 11:10 AM   #7
Barney145
Member#: 376219
1977 5.4L MGB
I think most Subaru undersize main brgs have an oversize thrust, .1mm if I remember but not sure on that. The crank needs to be ground there also if this is the case with your bearings. Sand the brgs? No, have the crank properly sized. It's a pita to grind thrust surfaces oversize, but not too bad on a Suby because they are steel cranks and the surface area is pretty small. I've ground cranks for 30 plus years so am familiar with the process.
Barney145 is offline   Reply With Quote
Old 02-10-2014, 04:30 PM   #8
Barney145
Member#: 376219
1977 5.4L MGB
I checked my bearing catalog, the .25mm undersize main does have a .1mm (.004") oversize thrust. Depending on if you have a center or rear thrust location, standard width of the center main brg is .864", rear main .904". If yours measure approximately .004" wider than whichever one of these you have, you need to have the crank ground to match. It's also best to measure the width of the thrust as it is installed in the case, sometimes the block will expand them slightly and change the measurement.
Old 03-05-2014, 08:05 AM   #9
tcpip4lyfe
Member#: 355361
2004 WRX
You were right on this. Over sized king bearings have a +.1mm thrust surface. Crank should have been ground to match. Live and learn. I got fed up with going round and round with the machine shop so I just ended up getting a new crank and bearings. Exactly what I should have done in the first place.
Old 03-05-2014, 08:50 AM   #10
Barney145
Member#: 376219
1977 5.4L MGB
See, sometimes old guys know what they're talking about. What were we talking about again??
Old 03-05-2014, 06:05 PM   #11
sidewayz
Member#: 5810
2001 S366 2.5RS
Barney why do you say not to sand thrust bearings? I know a lot of old timers do it to get end play right.
Old 03-05-2014, 06:12 PM   #12
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
Im 46 and I have sanded plenty of thrust. Have you ever measured clearance all the way around the thrust? Its far from equal.
fastblueufo is offline   Reply With Quote
Old 03-05-2014, 06:38 PM   #13
Barney145
Member#: 376219
1977 5.4L MGB
Engines with separate thrust washers can be surface ground (or sanded if you don't care about accuracy) on the backside of the bearing to increase clearance. I've done that for years but I'm not machining the actual bearing surface. If there is a lack of thrust clearance there is probably a cap alignment issue or the bearing is oversize and the crank needs to be ground to match. Sanding on a thrust will get you clearance, but the surface will not be square with the crank and you'll probably have a point loading situation. Of course this is in reality not a problem as a thrust does not have any constant load on it in the first place, that's why it is not a critical clearance. Most engines require a minimum of .002" to a max of .006" and they routinely have more than that without a problem.
