Old 02-10-2014, 02:23 PM   #1
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
I was experiencing some lag issues with my vf37(I have a V8 motor) and heard that exhaust wrap can reduce lag and possibly give you more power. Hotter air moves faster and keeps the turbo spooled. Here are some virtual dyno results done on the same stretch of road with temperature and barometric pressure changed accordingly. I did this to show the real gains from $100 worth of wrap. Again keep in mind I had no heatshields on my headers or turbo before I started this.
So I took a log of my current setup which was no wrap or heatshield on header, uppipe or the turbo/dp. That is my first and lowest log/dyno. Saved as "no wrap"
Next I wrapped my header and uppipe using dei titatium wrap. That log is labeled "Header wrap"
Yesterday I put on the dei turbo blanket(part number 15003) and a modified td04 heat shield. That log is labeled "Turbo wrap"
As you can see the lag was greatly reduced as full boost was achieved 400rpms sooner. Not to mention the power gains which I am assuming came from the now non-heatsoaked TMIC. I plan to wrap the two foot section after the turbo on the dp later today.
JulianDelphiki is offline   Reply With Quote
Old 02-10-2014, 03:30 PM   #2
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
Lag was greatly reduced because you started the last pull way earlier.
Also you have different weights and temps in the different logs.
Also I don't think I'm the only one that thinks nearly 50whp from some wrap and heat shields is even remotely realistic lol
I think maybe 5-10whp would be quite good, if not even optimistic, and about 100-200rpm worth of spool. But 50? lol
VladiWrX is offline   Reply With Quote
Old 02-10-2014, 03:59 PM   #3
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
How the hell do you have lag issues with a stock sized twin scroll turbo?
freddy121389 is offline   Reply With Quote
Old 02-10-2014, 04:45 PM   #4
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
-Correct, I did start the last run sooner. The largest change was in the 1st and 2nd runs though and that was started at the same rpm.
-The weights were changed because on one run my 100lb gf was with me.
-Again the temps and barometric pressure were changed because the runs were done days apart(I thought I mentioned something about that in my first post)
I am just showing the data I collected. Believe what you chose, however the reason I started wrapping was because I had zero shielding on the car....just exposed pipes. I felt those gains.
Old 02-10-2014, 04:47 PM   #5
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
And done.
Old 02-13-2014, 01:55 PM   #6
zDusza
Member#: 378920
Thanks for sharing these results, I've always heard wraps and shields were a good thing to have. It's nice hearing from someone else that they work well.
zDusza is offline   Reply With Quote
Old 02-13-2014, 05:32 PM   #7
subiFKNpowers
Member#: 361942
06 TR VF39/E85
Graphite & Carbonfiber
Nice man... what type of wrap did you choose? i got the lava heat wrap and lava turbo blanket for my vf39. The turbo blanket dramatically dropped under hood temps. I havent had time to do the wrap on the down pipe.
subiFKNpowers is offline   Reply With Quote
Old 02-13-2014, 05:38 PM   #8
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
Dei titanium wrap. It's much easier to work with. Also thanks for the kind words.
