Welcome to the North American Subaru Impreza Owners Club Friday December 26, 2014
Old 10-19-2012, 02:01 AM   #51
black_subie730
Member#: 193074
2002 WRX SW
have an 02 wrx wagon that i only have 1 remote for, the sticker on the back is coming of the only visible number that i can see is on the FCC ID all thats left is UA111 and on the serial no is B107.. now my question is what is the rest of the numbers so i can by another remote or what remotes can i buy? anything specific? thanks in advance.
black_subie730 is offline   Reply With Quote
Old 10-19-2012, 12:39 PM   #52
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Replacement remotes thru the dealer will be the teardrop design. If you want to keep with the kind you have now, you will have to find someone that has some leftover or a used on.
RexyGirl is offline   Reply With Quote
Old 10-19-2012, 12:40 PM   #53
RexyGirl
Member#: 63616
with mods :)
Replacement remotes thru the dealer will be the teardrop design. If you want to keep with the kind you have now, you will have to find someone that has some leftover or a used one.
Old 10-19-2012, 01:46 PM   #54
black_subie730
Member#: 193074
2002 WRX SW
^ so any oblong type will work as long as its the 2 button ones? the fcc id or serial number doesnt matter if its not the same?thanks
Old 10-19-2012, 05:13 PM   #55
RexyGirl
Member#: 63616
with mods :)
There are two types of teardrop remotes.
One that is the replacement for your remote and the one for the newer vehicles. From my experience, they are not interchangable, which means you have to get the one that does not have the 8 programming numbers (not letters) inside the remote.
I wouldn't worry about the FCC number....
Old 10-19-2012, 07:07 PM   #56
black_subie730
Member#: 193074
2002 WRX SW
im going for the old ones like the one that came with my car so the old oblong style thats what im getting ill update once i have it..one is from a legacy and the other from a forester..thanks
Old 11-22-2012, 12:01 PM   #57
kokoshoe
Member#: 197452
2002 Impreza WRX
Sedona Red Pearl
I did exactly what rexygirl said and programmed two previously used remotes that I bought from NASIOC and eBay. It took maybe a minute total. I didn't do any of the punching eight digits or anything, and the alarm never went off. The horn simply chirped once. Works perfectly. Thanks rexygirl. Btw I have an '02 wrx. One of the new (to me) remotes has the gray buttons, the other has the orange and blue buttons.
kokoshoe is offline   Reply With Quote
Old 11-26-2012, 06:05 PM   #58
RexyGirl
Member#: 63616
with mods :)
You're welcome!
The grey button remote is the older style of the orange/blue button remote. Basically, they are the same exact thing...Subaru just started to make them colorful.
There is no difference in them
Glad you could find the older style....they are becoming rare
Old 12-13-2012, 10:06 PM   #59
Garick
Member#: 318416
I just used this sequence on my 06 WRX which I found here.
http://forums.nasioc.com/forums/show....php?t=2372138
1) Make sure everything is shut (same as other instruction).
2) Get in, sit down, shut door (same as other instruction).
3) Open and shut door (same as other)
4) Put key in Ignition and turn key from "lock" to "on" 10 times, and finish in "lock" (slightly different from described)
- no tones or flashing lights occur as described
5) Open and shut door
- a faint tone is heard
6) Enter numbers as directed. Push lock the number of times that equals the value, then unlock between each digit.
- a tone is heard for each press
7) After <unlock> of last digit of the first sequence, hit unlock an additional time.
- tone flutters
8) Reenter sequence.
- tone for each press
9) for additional remotes or to push other codes out skip to 9a)
10) Open and shut door
- long tone
11) Remove ignition key
9a) Open and shut door
9b) Enter first sequence as described above
9c) After <unlock> of last digit of the first sequence, hit unlock an additional time.
9d) Reenter sequence.
9e) Continue to step 10 or 9a
This worked great...I'm pretty sure I did not press unlock an extra time after the first set of numbers though. The tone is a faint beeping. The locks did not lock or unlock by themselves at any time. The remote did not work immediately. It randomly started to work shortly (minute or less) after during frantic button pushing.
I got two teardrop style remotes from ebay. One had a single 8 digit code and programmed successfully. The other had an 8 digit code and also another code containing letters and numbers, this one did not work. yrmv.
Garick is offline   Reply With Quote
Old 07-12-2013, 03:04 AM   #60
NorCalH2OAddict
Member#: 362102
Sorry to bump this old thread. I'm afraid I'm having trouble getting into the "program mode" to program my new 2006 Subaru Impreza key FOB (tear drop shaped one purchased from amazon). I unlock the door, hop in, put the key in the ignition, turn on off 10 times in <15 seconds.... and nothing happens. The car's manual suggests this should work, but it doesn't seem to. I've tried it probably 20 times trying to go faster, slower, and every thing else i can think of. I have not tried disconnecting and reconnecting the battery to reset my alarm yet. Should I do this next? Any thoughts on where I might be going wrong would be greatly appreciated! Thanks.
NorCalH2OAddict is offline   Reply With Quote
Old 07-12-2013, 02:07 PM   #61
RexyGirl
Member#: 63616
with mods :)
Reset the system by disconnecting the battery. This will take it out of valet mode.
Also, just keep turning the key to the "ON" position until you hear the beep. Sometimes its 10-12 times....if after 15 times it doesn't sound, remove the key and open and close the drivers side door and try again.
Old 07-12-2013, 02:13 PM   #62
420WRX
Member#: 27752
2004 WRX+Ver.8 EJ207
Originally Posted by RexyGirl View Post
Reset the system by disconnecting the battery. Also, just keep turning the key to the "ON" position until you hear the beep.
These two points are why I came back and made a modified version of the how-to..
Once I realized that I could bounce the key back n' forth really quick without counting it was much easier.
420WRX is offline   Reply With Quote
Old 02-12-2014, 12:23 PM   #63
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
It's worth noting that 90's models with the dealer-installed accessory keyless/security system uses a different method to program. There are 4 "slots" for programming, and all 4 must be filled.
1.) turn key on
2.) hold security program button down until the alarm chirps. This is located in the drivers front footwell area.
3.) press a button on the remote (this fills one slot)
4.) press a button on each other remote until a total of 4 are programmed. If you only have one remote, this needs to be programmed into all 4 slots.
5.) turn ignition off and verify operation of all remotes.
t3hWIT is offline   Reply With Quote
Old 02-12-2014, 06:15 PM   #64
420WRX
Member#: 27752
1.) turn key on
Pretty sure that was covered in the posts already? I know I've seen it mentioned plenty.
It's not 'crucial' to fill all 4 slots, you only 'need' to register a new fob once, but leaving the other slots with a code means it's a little easier for a code sequencer to 'guess' a code that unlocks your car. Which is pretty moot because it's far easier to sniff the code and play it back.
Even if you upgrade to a fancy unit with a code that advances they have ways to figure out the advance with multiple scans so even that's not really much security.
After stealing my own car from my mechanic on a weekend after he forgot to hide my keys in the agreed upon location, using only a spare valet key with no fobs, I don't have much respect for the stock alarm at all really.
Can anyone cut and program an Acura key? C-grunt South West Impreza Club Forum -- SWIC 10 04-29-2010 07:03 AM
I am looking for an 05 key fob higgins14 Private 'Wanted' Classifieds 0 04-24-2008 10:48 AM
Programing key fob Sawyerscooby Car Audio, Video & Security 3 04-11-2008 11:59 PM
programming key fob www.rex Car Audio, Video & Security 8 03-30-2008 02:00 AM
If I program a 2nd key fob will the original still work?? ScoobyWag03 Newbies & FAQs 5 05-06-2007 04:02 PM
