Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 02-12-2014, 03:24 PM   #26
Shooter_McGavin
Member#: 363789
Originally Posted by rob View Post
You should not run that engine with anything but the ECU it originally came with. It has a higher CR than any other ej20G motor.
-Rob
Well I mean run it with a V3/4 STI 75 ej20k ecu since its a late 20g, not a v1/2 20g.
Shooter_McGavin is offline   Reply With Quote
Old 02-13-2014, 07:20 PM   #27
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
I wouldn't suggest it. Compression and you need the yellow injectors.
i_c_the_light is offline   Reply With Quote
Old 02-14-2014, 08:04 AM   #28
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
And a different MAF sensor too.
Marnix is offline   Reply With Quote
Old 02-14-2014, 01:25 PM   #29
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
And different MAP sensor
And different TPS
And different boost control solenoid
And intake temp sensor (I think?)
And waste spark ignition
rob is offline   Reply With Quote
Old 02-14-2014, 02:21 PM   #30
Shooter_McGavin
Member#: 363789
Mmmmkay so what you're saying is I should probably just leave it as is lol.
Old 02-14-2014, 02:54 PM   #31
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Well, if we want to get technical about it...I already did say that
-Rob
Old 02-20-2014, 01:59 PM   #32
Shooter_McGavin
Member#: 363789
So I found out the turbo is a td04 which would mean that this motor is a late EJ20G out of a WRX wagon. The WRX sedans had a td05 right?
Old 02-20-2014, 07:18 PM   #33
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
All wrx wagons got the td04. Only early G sedans got td05.
Old 02-22-2014, 10:02 PM   #34
klapasch
Member#: 377772
1992 Legacy RS EDM
ej20gnw1ba got this one on my car, and its not on the list, any idea what it is? Open or closed?
klapasch is offline   Reply With Quote
Old 02-22-2014, 11:17 PM   #35
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Open.
Old 02-22-2014, 11:45 PM   #36
klapasch
Member#: 377772
1992 Legacy RS EDM
Originally Posted by i_c_the_light View Post
Open.
Thanks, I was really hopeing it was closed thougth hahaha
Old 02-23-2014, 07:14 PM   #37
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
To be perfectly honest, I haven't a ****ing clue.
Old 02-27-2014, 09:31 AM   #38
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
It's a 1993-1994 open deck engine.
FS : Grimmspeed Intake Manifold w/ extras, ID 1000cc bigboy Engine/Power/Exhaust 17 07-17-2010 03:39 PM
Anyone with SBC-id and PM-id use the RPM Boost function?? Need Help!! smiles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-16-2002 11:20 AM
Blitz SBC-ID and power meter id installed DreamWalker Interior & Exterior Modification 0 10-31-2001 01:39 PM
Blitz SBC-iD PWR LSS settings & How to connect to Power Meter id? cmb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-01-2001 09:15 PM
what do you guys think about the Blitz SBC-id and Power meter-id? illmatic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-26-2001 12:02 AM
