Old 08-31-2013, 01:23 AM   #151
subarurx yo
Member#: 366313
87 RX ej22e p1 complete swap, all stock, no tune, td-04l, 3-4psi, 14.8 ET at 90mph
It was very reliable with stock injectors and no management, but I'm No longer running this setup, now has ej22e sb, 205 head's, havent drove yet
subarurx yo is offline   Reply With Quote
Old 12-12-2013, 01:11 PM   #152
thorne
Member#: 130063
2003 WRX
Silb
Originally Posted by i_c_the_light View Post
Reddevil and his antics got my attention about the engine. YOU sealed the deal by putting DOHC heads on it.
I'm going one further and attaching two turbochargers.
NICE!!! how are you dealing with the power steering issue? I had a chance to get a twin turbo manifold at one point and passed it up
thorne is offline   Reply With Quote
Old 12-13-2013, 03:02 AM   #153
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
RHD JDM y0! It's taken a backseat because I've decided to get married first. Still working out electrical stuff on paper though.
i_c_the_light is offline   Reply With Quote
Old 12-19-2013, 04:13 PM   #154
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Question should I use the Ej22 injectors or EJ25? I think the EJ22's flow slightly less, but I ask because I want to send out the injectors to be cleaned and flow tested.. my EJ25 injectors have 256K on them.
SubaruImpreza_power is offline   Reply With Quote
Old 12-20-2013, 04:04 AM   #155
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Neither! It boils down to what you're using as an ECU. Match them to the ECU.
Old 02-07-2014, 07:54 PM   #156
nasiocjunkie
Member#: 80864
I'll have the tuna.
No crust.
Originally Posted by squarebush View Post
Paige - 1998 Legacy L wagon| all ej22e | [email protected] |stock injector | n/a | n/a
Finished up my turbo a few weeks ago. It was a long time coming, I spent over a year and a half being disappointed by a lack of progress and incorrect parts until one day I stumbled on a local craigslist ad where some one was selling their entire legacy-> to turbo set up for $400!
So everything bolted up and I have lots of spare parts from when I was piecing everything together myself.
Specs:
stock ej22e with 260k miles I just put in after hydro-locking my original.
Blox racing 6:1 rrfpr
walbro 255
subachad uppipe and downpipe to replace the custom uppipe built to the wrong spec
2006 wrx Td04 w/ 3psi wastegate
jdm slanty intercooler
bosch recirc valve, hopefully replace it with something not plastic
full 3inch stainless exhaust after the downpipe with highflow cat
Custom intake pieced together from siliconeintakes.com
few things I want to add soon:
diy parallel fuel lines
some sort of fuel management. greddy ultimate or make my ms2 into a piggyback
bigger injectors
msd coilpack
Also want to get it on the dyno soon. I'm still running 3 psi but I want to jump it up to 5 soon and get those dyno numbers.
What kind of air/fuel ratio with stock ej22e injectors @ 3psi? I know of someone running a td04 with stock ej22e @ 5psi hitting 10.5ish.
nasiocjunkie is offline   Reply With Quote
Old 02-12-2014, 03:01 PM   #157
wheelerboy12
Member#: 381487
I'm hoping to join this club this summer!
Ej22e block
STI rods
Forged pistons
Acl bearings
25d heads
Upgraded valve springs
P&P
Delta cams
25d intake manifold
STI 560 cc injectors
06 STI vf39 turbo
Custom up and down pipe, full 3 inch straight pipe.
Custom FMIC
External wastegate
Emanage ultimate
Light weight pulleys
Light weight fly wheel
STI 6 speed
Upgraded clutch
Other things im forgetting
Shooting for 350-400 awhp.
Should be interesting.
wheelerboy12 is offline   Reply With Quote
Old 02-12-2014, 05:33 PM   #158
nasiocjunkie
Member#: 80864
I'll have the tuna.
No crust.
Goodbluck with that. You're better off doing a complete wrx or sti swap. Know of someone that built his ej22e to support a 20g and had issues here and there stalling at a complete stop.
Old 02-14-2014, 06:30 AM   #159
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
BS.
That someone had a leak in the intake piping. Only reason why it would stall out.
Old 02-15-2014, 10:02 AM   #160
squarebush
Member#: 173656
BS.
not true... you can have issues with lots of things. A common one i have seen is if you try to combine a lightweight pulley and a lightweight flywheel sometimes the deceleration of the engine is too quick for fueling to kick back on.
squarebush is offline   Reply With Quote
Old 02-15-2014, 10:36 PM   #161
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
So you're saying that everybody who turbocharges their ej22e will have this exact same problem? As if there isn't some cause for the problem that can be fixed.
geronimo81 is offline   Reply With Quote
Old 02-16-2014, 11:52 AM   #162
squarebush
Member#: 173656
Mine are kind of lean.. I don't really have management other then the rrfpr which I think I should change the plate in. I think it is the 6:1 so the 8:1 would probably be a better bet or even the 10:1. I think over that you might go too rich which will hurt power.
here is the graph with the AFR at the bottom
Originally Posted by blue wrench View Post
BTW, can you tell me what front bumper that is?
1998 Subaru legacy L wagon bumper....? I did add a customized grill and 1996 legacy 1 piece headlights (now using JDM's)
Old 02-20-2014, 01:57 PM   #163
amoore131
Member#: 222708
Ej22e block
STI rods
Forged pistons
Acl bearings
25d heads
P&P
Delta cams
25d intake manifold
06 STI vf39 turbo
Custom FMIC
External wastegate
Emanage ultimate
STI 6 speed
Upgraded clutch
Good luck with that. Stock heads are too restrictive and a vf39 threshold is a good bit below 350.
amoore131 is offline   Reply With Quote
Old 02-20-2014, 09:31 PM   #164
CoesWagon
Member#: 362361
I dont know about that...
Here's some inspiration from a similar build! 350 or so at first now 507hp...: http://www.sl-i.net/FORUM/viewtopic....a2515bf7b8e947
CoesWagon is offline   Reply With Quote
Old 02-20-2014, 10:57 PM   #165
thorne
Member#: 130063
2003 WRX
Silb
To be honest I think had I stopped at 350WHP and not pushed my Airfuels as lean as i did It would have lasted longer, BUT I'm damn hard on my car. I did this as a cheap way to get my car running. It just so happened to hold up to boost well.
Your biggest issue imho is tuning , My advantage was being a 20/22 I had 03 ecu
Old 02-21-2014, 12:07 AM   #166
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Do you know what the **** you're on about?
Old 02-21-2014, 12:10 AM   #167
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
You had an early 22e? The rods wouldn't have given you too much more as it is.
Old 02-21-2014, 11:38 AM   #168
thorne
Member#: 130063
2003 WRX
Silb
I must respectfully disagree. We rebuilt the engine with a factory style rebuild kit. During that time we had the EJ205 rod and a ej22e rod by each other and you would be surprised how similar they were in design.
I bet a EJ22e + Pistons could hold 400ish with proper tune and e85.
Old 02-21-2014, 06:08 PM   #169
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Only one way to find out...
Old 02-27-2014, 08:12 AM   #170
thorne
Member#: 130063
2003 WRX
Silb
Not enough money for 2 projects . honestly I think its a cheap solution for 2.0 guys who spin a bearing.
Old 02-27-2014, 05:56 PM   #171
amoore131
Member#: 222708
Okay first, I misread and thought he would be running ej22 heads. And second, yes you will never see 350 whp on a measly vf39 without e85 or race gas and I'm really just throwing that out there.
http://forums.nasioc.com/forums/show....php?t=1084275
Old 02-27-2014, 07:14 PM   #172
CoesWagon
Member#: 362361
Cool
I wasn't picking at you. I figured you misread it.
I shared the link to give the other poster some ideas of what a semi-similar build could do. That's all.
Btw-like what you've done with your wagon and thanks for you pics on Suziemk's thread.
I'm planning on taking that info and doing the same as you and he did to my 99 Wagon. (MAP EJ222)
Old 02-27-2014, 07:37 PM   #173
amoore131
Member#: 222708
No problem. His build is sick though. And thanks, I love a boosted 2.2
Old 03-20-2014, 08:05 PM   #174
susiemk
Member#: 108691
Nice numbers for such low boost running lean, You need a 8:1 fmu to run safely on a maf car.
Some folks say no fmu is required on maf cars but as you can see even 6:1 is a bit too lean for a reliable long lasting engine.
Check out my parts list on rs25 where I outline turbo kits for map EJ222s based on my own OBS wagon which has been boosted since 2004 & is still running strong with a best 1/4 mile time of 12.8Xs - stock longblock, no e/m, single port!
susiemk is offline   Reply With Quote
Old 03-20-2014, 09:26 PM   #175
susiemk
Member#: 108691
BTW 13.5 AFRS is way to lean. your risking damage at that afr
+1
Afrs of mid 13's are ok n/a But a cracked piston or blown hg is possible with some boost.
boosting on an ej22 shortblock not a ej22t sime Normally Aspirated with bolt-on Forced Induction Powertrain 10 09-11-2014 06:05 PM
Whose boosting an EJ22 NA? Turbo GC4 Normally Aspirated with bolt-on Forced Induction Powertrain 5 09-11-2014 04:07 PM
New EBCS Pro From PERRIN - Boost Control Solenoid PERRIN Vendor Announcements 19 09-16-2010 07:35 PM
FS : Defi Racer Boost and EGT gauges Faster_Gun Interior/Dressup/Audio & Security 7 06-09-2010 09:37 PM
Less boost. higher atmospheric temp? COBB AP2 joosky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-07-2010 03:38 PM
