Old 02-19-2014, 08:31 PM   #351
k-dogg
Member#: 115961
2005 Wide STi Wagon
WR BLUE
Originally Posted by spoolinsti05 View Post
Just what I herd man. I didn't say it did. I said I thought!
As far as searching shouldn't it be here on the first page or do you not care to sell them that much?
Lol pretty sure there are two clips in the first post. One a GD, and one a GR.
k-dogg is offline   Reply With Quote
Old 02-20-2014, 10:40 AM   #352
gtasti
Member#: 152036
2004 Sti
Anyone want to buy my v1 kb header setup for ewg and ti wrapped
gtasti is offline   Reply With Quote
Old 02-20-2014, 10:47 AM   #353
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Makes sense, I didn't stop to think about flow like that. I was thinking the other day about how O2 could possibly disrupt the airflow or kinda make the tube smaller by displacing some of it. But this makes sense now as to why you put it there.
Originally Posted by KillerBMotorsport View Post
When you visualize gas flowing through a tube, picture it as water. You launch a slug of water into a bent tube and it flows mostly along the outside of the bend. Gasses do the same thing; highest velocity/energy is off center favoring the outside of a bend. Even when there are two bends with a short straight between them the energy continues to travel off-center. So, to make a short story long... placing the sensor on the inside of the bends causes the least flow disruption/turbulence while still providing proper feedback. An inconvenience, yes. An uncompromising approach for maximum performance, definitely.
bswilmington is offline   Reply With Quote
Old 02-20-2014, 11:02 AM   #354
wrxhard
Member#: 108091
Uncompromising performance. Tis the killer b way!!!!
WINNING!
wrxhard is offline   Reply With Quote
Old 02-20-2014, 12:59 PM   #355
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
That is true but also back pressure and ability to fill the said area also plays a huge factor on the flow path.
Remember the garden house theory? Well I can change my hose configuration all day long. If my pump doesn't provide the pressure it will only flow so much.
I can re configure the nozzle to pick how I want it to release the pressure. But it won't increase flow unless I have the pump to match it.
My theory is back pressure play hand in hand. It's a love hate kinda relationship.
Old 02-20-2014, 03:36 PM   #356
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
When you can find heads/cams/valves big enough to make our header a bottleneck let me know. The highest HP car these have been on exceeded 1K whp (a land-speed junky) and they have not proven to be a hindrance.
Anything and everything is a bottleneck at some point. So far, we've not seen that level.
KillerBMotorsport is online now   Reply With Quote
Old 02-20-2014, 09:37 PM   #357
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Since it's not a bottleneck at 1000hp doesn't that mean it can be downsized for the average 300-400whp car and achieve more spool gains?
Old 02-20-2014, 10:17 PM   #358
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
An improvement in VE is an improvement in VE.
Of all the plots floating around out there I know of only a couple that show reduced spool (by 100-200RPMs tops) and those themselves have discrepancies since the pulls were started at different RPMs, different, different weather conditions, different tunes, etc. I've not seen a single plot where the only variables were the header, showing a loss in spool.
Old 02-20-2014, 10:26 PM   #359
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
If it merged at the turbo housing that alone would be enough.
Old 02-21-2014, 05:51 AM   #360
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Then you have no means of properly regulating boost. Your cyl to cyl backpressure would be horribly inconsistent as the flow out of the WG varies depending on which primary is most aligned with the WG port. It also doesn't give enough room to angle the WG port in the direction of flow, or place it close to the port. Both of which give better flow and responsiveness of regulation. Another downside of a 'T' WG port is that the crappy flow characteristics usually mean you need to run a bigger WG. A bigger WG add turbulence and reduces boost modulation vs a smaller WG. And even another point, is putting the WG too close to the turbine can have an adverse effect because it can create turbulence as the pulses are entering the volute, there is a sweet spot for WG angle and placement.
Old 02-21-2014, 10:09 AM   #361
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Sure you would just would need the Ewg in the turbine house where it should be to begin with. Good day. The birds are out over here!
Old 02-21-2014, 11:22 AM   #362
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
And you will see performance degrade with it in the housing vs not. I look forward to your next nonsensical comment.
Old 02-21-2014, 11:56 AM   #363
martynj
Member#: 188947
Originally Posted by Junior2JZ View Post
I was able to finally tune my 6466 setup in my 2012 STI this past weekend using the KB header.... Speachless.. My 6466 in 4th gear makes 20psi by 4100rpm
Car also put down 622whp on 33psi on the mustang dyno, a 2013 stg2 + tmic wrx I tuned directly before made 265-270whp/290ftlbs maxing out the fuel system just to give an idea of how the dyno reads.
What size MAF tube are you running on that and is it mounted in the cold or hot side ?
martynj is offline   Reply With Quote
Old 02-21-2014, 12:11 PM   #364
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Whys that?
Old 02-21-2014, 12:12 PM   #365
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Petty sure it's speed density
Old 02-21-2014, 01:01 PM   #366
Airboy
Member#: 72829
2006 WRX
2015 WRX
Is this stock gearing? [email protected] is closer to 5th gear.
Airboy is offline   Reply With Quote
Old 02-21-2014, 04:05 PM   #367
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Proof is in the pudding so they say!
Old 02-21-2014, 10:14 PM   #368
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Tires play a factor in gearing as well. Taller tires longer gearing.
Old 02-21-2014, 11:10 PM   #369
creative wrx
Member#: 141754
04 stock wrx ;)
z31 project, passat dd
Car was dynoed on his stock wheel and tire setup.
I want to say he was doing his pulls in 4th but dont remember fully. Either way it was fun listening to that monster spool up and scream to red line.
creative wrx is offline   Reply With Quote
Old 02-22-2014, 12:47 AM   #370
Airboy
Member#: 72829
2006 WRX
2015 WRX
The ECU doesn't know if tire sizes have changed. The screenshot looks to be a data log from the ECU.
Then it would have been in 5th gear, which has a ratio of ~49.5rpm/mph
Old 02-22-2014, 09:32 AM   #371
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Unless it has mini tubs I doubt it has large enough tires lol amateur
Old 02-22-2014, 09:48 AM   #372
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
IF anyone looks like the amateur here it is you..by far. I suggest you stop posting nonsense before killerbee continues to give us a show disproving every single thing you post for the most part.
Shortpersonbk is offline   Reply With Quote
Old 02-22-2014, 10:31 AM   #373
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
For the most part you have no say in what's been said. You're just a tag along. So keep that bench warm for you team.
Old 02-22-2014, 10:57 AM   #374
manitou
Member#: 193757
2006 XTI Limited
Hmm, It doesn't add up to stock tires and 4th gear!
If the speed sensor signal was corrected it would know. You could get close with a 27" tall tire.
Hey troll boy, you better adjust your meds. What are you doing in this thread anyway? You didn't even have a clue as to the existence of these headers, then you jump in here with BS babble to just clutter up the thread and others. Don't you have a job or something else maybe useful that you could be doing?
Old 02-22-2014, 11:02 AM   #375
Shortpersonbk
Member#: 319017
15 Prius
At least as a tag along who keeps the bench warm I get to watch killerbee and others wipe your "knowledge" all over the board.
Killer B Motorsport Header - Prototype Testing KillerBMotorsport Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 183 11-27-2012 09:10 AM
Killer B Motorsport - HOLY HEADER / Up-Pipe Released! KillerBMotorsport Vendor Announcements 52 03-17-2011 02:34 PM
Killer B Motorsport HOLY HEADER Group Buy KillerBMotorsport Vendor 'Group Buy' Classifieds 35 06-25-2010 02:18 PM
Vf48 Turbo (18g killer?) w/ WRX Install Results P&L Motorsports Inc. Engine/Power/Exhaust 5 03-25-2008 06:41 PM
