Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
Old 12-13-2010, 01:20 AM   #1
Stevenvirginia
Member#: 225624
1996 Legacy L
Audi TT Nimbus Grey
Default Anybody installed an MSD 8239 Ignition coil on their Subie?
96 Legacy with a 2.2. I'd like to know which wires go where. Its a 3 wire input plug. Msd says the center is +12 and the outer are -12 triggers. Other than that I would just be guessing. Thanks for any input.
http://www.amazon.com/gp/product/B00068OKZ2/ref=oss_producthttp://www.amazon.com/gp/product/B00068OKZ2/ref=oss_product
Stevenvirginia is offline   Reply With Quote
Old 12-16-2010, 05:21 PM   #2
Navi271
Member#: 203099
1995 Legacy Wagon
Winter Green Metallic
Yeah you're right.
subie connector, read right to left 1, 2, 3.
pin 1 is for cyl numbers 1 and 2
pin 2 is "12v signal in"
pin 3 is for cyl numbers 3 and 4
The MSD connector reads left to right tho, opposite to the subie one.
I think the wires colors are the same as mine. Here's a pic over on sl-i.net
I thought I got it right the first time, but first start up on my car it backfired! So try the wiring thats in the pic. If it's not right switch around the 2 outer wires, then it should work. The center wire on the subie connector always goes the center wire on the msd connector.
Navi271 is offline   Reply With Quote
Old 12-16-2010, 05:30 PM   #3
Stevenvirginia
Member#: 225624
1996 Legacy L
Audi TT Nimbus Grey
Thanks! How did you mount yours, did you just use 2 of the mounting holes? Did you need to use different coil boots or did the factory ones work. Last question, how was the pizza?
Old 03-03-2011, 09:46 PM   #4
loose Subie
Member#: 262067
Where did you get that black plug that goes to the msd box
loose Subie is offline   Reply With Quote
Old 03-04-2011, 10:06 PM   #5
Navi271
Member#: 203099
1995 Legacy Wagon
HAha! sadly that was someone else's picture, I think I'm going to make some pizza now tho...
Anyways, you need some extended bolts, they are M6 x 2" bolts. You'll only need 2, because the msd coil is taller and a little longer than the subaru coil so only 2 bolts line up.
Here's the thread from sl-i.net I used to make sure I had everything I needed:
http://sl-i.net/FORUM/viewtopic.php?f=39&t=11704
Old 03-26-2011, 04:59 PM   #6
J.McDonald Knives
Member#: 184412
1989 Jeep Wrangler
Cherry Red
I just did the conversion and clipped off my old harness and tied directly into the stock harness wires. When doing it with the 8239 the wires are as follows:
Subaru > MSD Harness
Yellow - Green
Black - Black
Red - Blue
And that keeps the plug on the same side but the MSD logo will be on the back side. The bolt size you need is M6 x 45mm or 50mm and you only need 2. Since mine is a DOHC I went with the wires for a 98 Legacy and you don't need to mod them.
J.McDonald Knives is offline   Reply With Quote
Old 01-24-2014, 11:36 PM   #7
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Where do you get that black plug for the MSD?
SubaruImpreza_power is offline   Reply With Quote
Old 01-25-2014, 12:24 AM   #8
J.McDonald Knives
Member#: 184412
1989 Jeep Wrangler
Cherry Red
Its the flat pin connector from a 96-00 Dodge Neon. You can find one at a junk yard or from Napa.
Old 02-13-2014, 10:13 PM   #9
PA-Outback2000
Member#: 161832
2000 Outback Limited
Any performance/results/power input?
PA-Outback2000 is offline   Reply With Quote
Old 02-14-2014, 01:37 AM   #10
J.McDonald Knives
Member#: 184412
1989 Jeep Wrangler
Cherry Red
Yes there was a noticeable smoothness in the idle and I got a little better gas mileage. I'm sure on a dyno it would show the gain and probably show a smoother graph. Its a higher voltage which means stronger spark which equates to better fuel burn. Its like going from a regular distributor with separate coil to HEI ignition.
Old 02-24-2014, 02:19 PM   #11
alter_
Member#: 328383
yeah this doesn't seem to work on an ej20k
alter_ is offline   Reply With Quote
Old 02-25-2014, 12:18 AM   #12
PA-Outback2000
Member#: 161832
I have a voltage regulator/grounding kit on my car already. I think I felt that type of gain after installing the grounding kit. Felt like there was a "wall" from 4500-redline before the install. Then it felt like there wasn't I e after the install. I also saw a small mpg increase.
Would the MSD add to what I've already felt?
Old 02-25-2014, 07:34 AM   #13
J.McDonald Knives
Member#: 184412
1989 Jeep Wrangler
Cherry Red
Yes it will because its 8k more volts to the plugs which means better fuel burn.
Old 03-17-2014, 08:42 PM   #14
Stu_baru
Member#: 229054
1996 Impreza L
Default Plugs?
So I have a ej22e single port with 8239 msd. i've tried swapping the outer wires for the splice, i've used phase II plug wires with stock ngks plugs (bk9re or w/e). It misfires either way. Did you regap or replace your plugs?
Stu_baru is offline   Reply With Quote
Old 03-22-2014, 01:48 PM   #15
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Will this be ok for plat plugs?
Old 04-03-2014, 08:01 PM   #16
subaruimprezaobs
Member#: 385526
1999 Outback Sport
I tried retrofitting the Accel Neon coil to my Phase II EJ22. It burned my ignition coil fuse under the dash so I ended up keeping the stock coil. I ordered plugs and wires from hhttp://www.weaponxperformance.com/
The car is louder and smoother as confirmed by my peers. Here's a pic of the wires.
subaruimprezaobs is offline   Reply With Quote
Old 07-18-2014, 12:06 AM   #17
SJOGUN
Member#: 358689
I was thinking about trying this on my 20k, what was the issue with the new coil msd or neon?
Sent from my DROID BIONIC using NASIOC mobile app
SJOGUN is offline   Reply With Quote
Old 12-13-2014, 07:28 PM   #18
Erocket
Member#: 402305
I just picked up a neon coil and connector from a junkyard. Made sure to get a flat pin connector, coil looked fairly new. Installation was easy on my 98 obs ej22e. Plug wires already matched coil fine.
Soldered wires
Sub yellow - neon black
Sub blue - neon blue
Sub red - neon green
I only have 1 bolt holding it on the manifold, 22e intake mounts must be diff than some others. Fired right up. Idle is slightly smoother, biggest difference I noticed is it eliminated the stumble/hesitation from a start accelerating. Will keep an eye on the gas mileage next couple weeks. Will be getting an MSD coil in the future, but for $25 it works good.
Erocket is offline   Reply With Quote
Old 12-14-2014, 08:39 AM   #19
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Anybody recently replace their clutch and/or flywheel on their Subie lately? Newera09 New England Impreza Club Forum -- NESIC 6 11-01-2009 10:58 PM
anybody have a pic with eibach springs on their suby ineedparts Interior & Exterior Modification 12 02-18-2007 12:38 PM
Anyone ever install an MSD ignition? Blugin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-23-2003 11:45 AM
('93-'01) Anyone have a problem with their ignition coil on MY99 IMPREZIV Impreza Forum 2 04-18-2001 01:37 PM
Has anybody installed an STI shifter? Patrick Olsen Legacy Forum 0 05-13-2000 02:51 PM
