Old 09-01-2013, 02:42 AM   #51
IceWilly
Member#: 126081
2005 Sti
GT: IceWilly
Yes, that it was. Stuff was serious, and made me feel like an autozone chump with my inferior product.
IceWilly is online now   Reply With Quote
Old 09-01-2013, 12:15 PM   #52
Blktrax
Member#: 220971
2002 WRX 213K Mi.
Original Motor and Turbo
I've had really good luck with this if you can find a supply.
https://shoponline.wurthusa.com/wurt...log/group.jsp/
This product represents the latest breakthrough in penetrating lubricant technology. By combining rapid freezing action with an advanced, rust eating formula, seized or rusted parts are easily released. Shrinkage of sprayed parts quickly breaks open micro fine fissures allowing the lubricant to easily penetrate through the toughest rust. The innovative rust eating technology then dissolves rust making the job a snap and future maintenance easier as well.
Blktrax is offline   Reply With Quote
Old 09-02-2013, 05:02 PM   #53
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
I recommend getting a new bolt and bushing. You might as well swap out to a better set of lateral link bushings but that's just me. When installing the new one, be liberal with anti-seize, you just need it at the points where it makes contact with the bushing sleeves and the nut.
kenliu84 is offline   Reply With Quote
Old 09-03-2013, 06:54 AM   #54
Jeffreynn
Member#: 367203
Well i am just trying to get, this factor arranged and not actually substitute the bushing. I understand that is not not going to help me later on, when i do need to substitute the bushing.
Jeffreynn is offline   Reply With Quote
Old 09-03-2013, 08:42 AM   #55
if you guys want to try some really good cheap rust buster......get
1qt acetone
1qt dexron atf
1 old motor oil bottle
pour 1/2qt acetone in the old motor oil bottle
pour 1/2qt dexron atf into old motor oil bottle
pour 1/2qt acetone into remaining dexron atf
yeild = 2qt rust buster delux
**** works
it IS a bit flamable so beware using a torch around it
but it works better that all but the best of the rest and costs very little if you find cheap acetone
Old 09-03-2013, 09:07 AM   #56
atomicfire
Member#: 136296
2005 STi
Hint: remove the inboard lateral link bolts first, then when you remove the nut from the ourboard side you can remove the lateral link and long hub bolt as one piece. Once it's out, get the three arm press and use it to press the bushing and bolt out together.
http://forums.nasioc.com/forums/show....php?t=2409546
atomicfire is offline   Reply With Quote
Old 11-16-2013, 07:01 PM   #57
dagger108
Member#: 337743
2002 WRX Wagon
WRC Blue
Comments generally seem to be oriented to removing bolts. I've got the links and arms removed and powder coated, with new TiC bushings installed. All are mounted again accept for the rear driver's side. The exhaust is in the way. I recall pushing the exhaust to get the bolt out, and have tried pushing it a lot to get it back in, but unsuccessfully. Any suggestions?
dagger108 is offline   Reply With Quote
Old 11-16-2013, 07:29 PM   #58
jlukowski
Member#: 292477
2005 WRX STi
Maybe undo the catback exhaust hangers and let the exhaust drop a bit to allow you to encourage the bolt to go where it needs to. Then put the exhaust back up when you are done.
jlukowski is offline   Reply With Quote
Old 11-16-2013, 08:15 PM   #59
dagger108
Member#: 337743
2002 WRX Wagon
WRC Blue
(slaps forehead with palm)
Had thought about it from the standpoint of trying to push the exhaust higher, but not of moving it down or laterally.
Old 11-26-2013, 03:48 AM   #60
dagger108
Member#: 337743
2002 WRX Wagon
WRC Blue
Dropping the exhaust definitely works, and makes it easy. Also easiest to start by removing the bolted hanger on the outside rear of the muffler.
Old 03-02-2014, 08:49 PM   #61
99screwbaru
Member#: 332912
2002 stage 2 wrx
rally blue
hahaha the stories of the nightmares people are having with this damn bolt is funny, i like the taco picture too.....snapped the head of the lateral link bolt trying to remove it while doing rear axles in my 2002 wrx sedan --__-- tomorrow i think I'm just going to remove the whole knuckle and get it on a work bench and burn out the bushings i have new bushings and bolt then i should be a o.k. and be able to FINISH my rear axle job, pissed i had to go a nibble bibbly and dick with this snapped bolt when all i wanted to do was a simple rear axle job
99screwbaru is offline   Reply With Quote
Old 03-03-2014, 03:48 PM   #62
dagger108
Member#: 337743
2002 WRX Wagon
WRC Blue
Default Burning can be fun
I found it quicker to take a drill and drill the rubber out, or at least enough so that the bushing caves in. Cutting off the shoulder of the rubber bushing with a utility knife helps the bushing slide out easier as well
$0.02
Old 03-03-2014, 03:52 PM   #63
99screwbaru
Member#: 332912
2002 stage 2 wrx
rally blue
$0.02
reallly? I've heard nightmare stories of people taking 4 days to drill this bolt out haha ,, I'm going to try and cut the bushing out I've already half burned it out before my benzo torch ran out
Old 03-04-2014, 12:45 AM   #64
dagger108
Member#: 337743
2002 WRX Wagon
WRC Blue
Most of the multi-day experiences I recall were of the bolt through the knuckle. After a couple dozen F/R in the last year, it is one thing I have gotten halfway proficient at.
Old 01-01-2015, 04:25 AM   #65
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Dragging this up from the dead as, after a long time not wrenching on a scoob, I'm finally dealing with an older, salted and rusted car. Call me new car SoCal spoiled!
Anyway, does this bolt tend to seize at the knuckle or at the bushing? We were able to remove the front lat link(and nut) but the rear is going nowhere. Can't get the bolt to rotate. So I was wondering if it might be seized at the bushing or at the knuckle. Can these seize at the knuckle? I'm worried that if we cut the head off the bolt, we still have to deal with it being seized in the knuckle. What have your experiences been with where the bolt actually seizes to?
Toe bolts are also seized. And don't get me started on the various bolts that sheared off while trying to remove them from the chassis. Like the big 19mm bolts that hold the ALK(transverse link bushing) to the chassis.
Arnie is offline   Reply With Quote
Old 01-01-2015, 10:21 AM   #66
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
The bolt seizes to the bushing-sleeve.
Big-E is offline   Reply With Quote
Old 01-01-2015, 12:15 PM   #67
lemming
Member#: 250066
'06 Forester XT
'03 Rustang V6T, '13 GT
I've had one seize itself to the hub, too. That one was fun.
lemming is offline   Reply With Quote
Old 01-01-2015, 12:22 PM   #68
kenliu84
Member#: 107618
2006 OBP WRX Wagon
I would soak the crap out of all contact surfaces with rust penetrant for now while you figure things out.
In my experience, I've had the bolt seize to the bushing sleeve. I had an impact gun and it was having a hard time getting the built to turn because it was fighting against the friction between the bushing and the housing of the rear lateral link.
I am guessing that based on my experience and you saying you can't rotate the bolt, then it is seized to the knuckle. Good luck!
Sent from my VS985 4G using NASIOC mobile app
Old 01-01-2015, 02:46 PM   #69
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Jesus, haven't seen you since the stone age!
The bolt tends to always seize to the bushing's inner core and often will seize to the knuckle as well. Hose everything down a couple of days ahead of time in Kroil (if you don't own it, buy it, you're going to need it). At this point, if both the outer and inner end of the rear lateral link are stuck, your best bet might be to cut the lateral link in half so you can free each end individually. Lateral links are pretty damned cheap. If you can save yourself 8 hours of work for $30, you probably ought to.
williaty is online now   Reply With Quote
Old 01-01-2015, 06:47 PM   #70
yep...cut the link...its usually worth it in the end if its a rust belt car
Old 02-18-2015, 01:07 AM   #71
bzoli
Member#: 181759
2004 WRX Wagon
The fastest one
I'm in the same shoes... just bought a can of kroil and started to soak it, I really hope that I can save the lateral links as I have already bought the group n bushings.
I couldnt even remove the nuts let alone pulling out the bolt from the bushings.
The good thing is that you can buy all bolts and nuts from Subaru ($110 if you replace all hardware - just sum'd up all PN's today) incase you have to cut it.
bzoli is offline   Reply With Quote
Old 05-15-2015, 06:46 PM   #72
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
thanks Scott and Ty! Finally stopping by to see what is up here. Miss this place!
I miss my Kroil, been using it for 15 years. Haven't looked for it out here but I doubt they have it.
Old 05-15-2015, 09:07 PM   #73
pm me your addy.
you WILL have Kroil....if amazon will ship it to that addy, that is
Old 05-15-2015, 11:20 PM   #74
RavensFan7
Member#: 346388
2001 Ej205 Impreza L
SRP
Default Lateral Link Bolt
I just pulled rear knuckles off a 2001 forester, at a junkyard, for my rear disc conversion. I've read this thread a while ago, so I knew what I was getting into.....but damn, I thought I'd be able to spin those lateral link bolts out.
Nope.
3 different days, and 5 different cars.
The final day and car, I went back with a sawzall and cut EVERYTHING. It was the only way.
RavensFan7 is offline   Reply With Quote
Old 09-12-2015, 03:09 AM   #75
timbo66
Member#: 429262
I'm lucky that the forward lateral link inside bolt/nut was in good condition on my MY06. However one of the reasons I got this car cheap was that the link is bent and the part of the subframe (crossmember) that the inside attaches to is bent towards the vehicle front. So with the lateral link fully horizontal, the bolt hits the CV joint (axle?) as it comes out.
Looks like i will have to work out how to rotate the subframe attachment area back to it's original position so I can get the bolt out.
timbo66 is offline   Reply With Quote
Outer lateral link bolt scoobyimprza Brakes, Steering & Suspension 20 07-13-2005 10:06 PM
Inner Front Lateral Link Bolt Removal Boxologist Brakes, Steering & Suspension 6 06-04-2005 06:36 PM
04 STI Lateral link bolts - stuck!! V8VENOM Brakes, Steering & Suspension 7 10-21-2004 08:13 PM
Can't get lateral link bolt off kaneda3 Brakes, Steering & Suspension 19 06-03-2004 08:34 AM
Outer lateral link bolt scoobyimprza Mid Atlantic Impreza Club -- MAIC 4 04-28-2004 06:33 PM
