Old 03-03-2014, 02:53 PM   #1
ScubaruImpreza05
Member#: 74041
2006 2012 Weee-strom
SV650 For sale
Question 06 2.5i Power Steering pump dying; what fits it?
So as the title says, my Power Steering pump is dying a slow painful death. Started with a weird clunk on a very cold morning a month ago, and has slowly turned into a whine and heavier steering wheel.
So, I'm gonna try to grab a cheapie from a part out, but I don't often see part outs on here for 2006 2.5i's, so was wondering what other Subaru models/years fit the 06-07 Impreza 2.5i's?
Thanks for any help!
ScubaruImpreza05 is offline   Reply With Quote
Old 03-03-2014, 03:14 PM   #2
pakeharugger
Member#: 131920
2006 Impreza 2.5i
Have you tried just replacing the O ring on the top? The whining sound may be air in the system. I replaced the top O ring and topped off the fluid, the whining went away, that was at 70K miles, I now have 97K miles. It was a cheap $.50 ring from Ace hardware.
http://forums.nasioc.com/forums/show....php?t=2268246 post #5
I need to find the correct size, the old O ring was completely stretched and the new one was a snug fit.
http://www.iwsti.com/forums/warranty...ng-o-ring.html
Edit:
Check this out
http://forums.nasioc.com/forums/show....php?t=1897783 Read the whole thing.
http://forums.nasioc.com/forums/show...28&postcount=7 the O ring is in the top inlet nozzle and it's only held in place by a 10mm bolt. Be careful with spills, I would put a lot of paper towels around the pump before you start working on it.
pakeharugger is offline   Reply With Quote
Old 03-03-2014, 04:26 PM   #3
ScubaruImpreza05
Member#: 74041
SV650 For sale
Thanks, I will check that out!
Old 03-04-2014, 09:56 AM   #4
ScubaruImpreza05
Member#: 74041
SV650 For sale
Anyone possibly know the correct O-ring size for the 06 pump? The only way I am getting to the store is with my car so I can't exactly just remove the inlet and o-ring and go to the store...
In one of the threads posted above, they stated 11mm ID x14mm OD x2mm as a good size....however everything is in fractions when I look. Any ideas?
Old 03-04-2014, 07:39 PM   #5
WRXFanDave
Member#: 151245
2006 WRX Wagon
WRXFanDave is offline   Reply With Quote
Old 03-05-2014, 04:04 PM   #6
ScubaruImpreza05
Member#: 74041
SV650 For sale
Well I actually ended up buying 2 o-ring kits from my local Harbor freight and one of them seemed to fit fine. No whine or moaning while driving now, however the power steering still isn't right. could either be some bubbles stuck in the line or the pump is actually just outright failing. Basically it seems fine until im turning and i hit a big bump, then the steerwing wheel has mini convulsions as it tries to keep up with the force working against the pump.
Old 03-10-2014, 04:30 PM   #7
pakeharugger
Member#: 131920
2006 Impreza 2.5i
Did you bleed any air out of the system?
Check this out.
http://forums.nasioc.com/forums/show...3&postcount=17
Old 04-15-2014, 04:56 PM   #8
Gorge
Member#: 97449
2007 WRX
I have the same issue too. Replaced the o-ring, put some silicone goop around the head of the bolt to ensure that no air will come in, replaced the front 2 clamps with the screw type, and I'm getting clunking. The PS doesn't whine anymore, but I definitely do get a clunk and convulsions.
I have enough fluid in the system, and I tried to burp the air out. Since I don't have the whine, is it a matter of bleeding/flushing the PS fluid or should I be thinking about replacing the hoses because there's a possible leak somewhere?
Gorge is offline   Reply With Quote
Old 04-17-2014, 11:28 AM   #9
Gorge
Member#: 97449
2007 WRX
Bump!
Old 02-19-2015, 11:27 AM   #10
kingsalami
Member#: 206257
2009 WRX 5-door
I finally found the right O rings for this...
These should work for all 2014 & older Subie flat four motors:
Subaru P/N 34439FG000
Honda P/N 91345-RDA-A01
kingsalami is offline   Reply With Quote
