Old 03-08-2012, 07:30 AM   #51
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I bet the failure is the seal that separates the high pressure side from the low pressure side.
This thread might help some of you http://forums.nasioc.com/forums/show....php?t=2127419
ciper is offline   Reply With Quote
Old 11-19-2013, 01:06 PM   #52
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Bump to help Clint so he doesn't have to find this.
Old 03-03-2014, 07:33 AM   #53
ilarson007
Member#: 340470
2002 Impreza WRX
Platinum Silver
I didn't read through every post in this thread; sue me. What is meant by "the steering feels funny?" When I drive down the road, my steering feels like something in the suspension is completely shifting, especially when I change lanes and go over the crest in the road. Is this something that can be caused by this blown out PS pump?
(No, I wouldn't have blown it doing snow donuts... I do have to make 3pt and u-turns once in awhile.)
ilarson007 is offline   Reply With Quote
Old 03-03-2014, 07:53 AM   #54
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
That cold be many different things. I wouldn't suspect a blown power steering pump right away though. Very first thing I would check is for snow/mud on the inside of your wheels. A surprisingly small amount of debris on the wheels can screw up the balance very easy and make it feel like your front end is about to puke itself all over the highway. If you rule debris out, I would have your wheels rebalanced anyways.
After that, if you still have problems, you're going to want to check tie-rods and ball joints. Make sure your sway bar and endlinks are all intact. Good luck.
tibug is online now   Reply With Quote
Old 03-03-2014, 08:04 AM   #55
ilarson007
Member#: 340470
2002 Impreza WRX
Platinum Silver
Well, I have jacked up the car and pushed/pulled on all four wheels, and the all feel very solid. I did this to rule out wheel bearings, but wouldn't one think that a broken swaybar or endlink would surface during this test? I wasn't gentle with them either. It almost is like whatever it is is something that takes a high amount of force to shift - like the sideload experienced when changing lanes. I don't believe there is any debris on my wheels. Not 100%, but close.
Old 03-03-2014, 07:06 PM   #56
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
Perhaps, but a broken swaybar/endlink is much easier to diagnose just by looking under the car. It's probably not your problem, but it's always good to rule out the really easy stuff first.
Another thing you can do instead of/before getting your wheels balanced is rotate the tires (front to rear, rear to front) and see if there is any change. If no, then either all of your wheels are out of balance, or the problem is not in your wheels.
Could also be a steering rack issue. Just throwing that out there...
Good luck.
Old 03-04-2014, 07:28 AM   #57
ilarson007
Member#: 340470
2002 Impreza WRX
Platinum Silver
Good luck.
Yeah, the steering feels stiffer I guess then it should (especially at lower speeds), but is still pretty unresponsive, imo. However, the power steering is at least still working to some degree; the PS belt snapped one time on me and I felt what no PS was like. Way easier to handle than that.
I'm not sure, but I think something in the PS system is leaking. However, I've periodically checked the fluid, and it seems to be staying at the same level. IDK. It's just kind of scary to drive at highway speeds because the car is getting pulled around.
Old 03-05-2014, 07:36 PM   #58
ilarson007
Member#: 340470
2002 Impreza WRX
Platinum Silver
Idk if this will help but. When I'm driving, the steering changes direction that it pulls. Like, it'll pull hard right, then weak left, then hard left, then weak right, etc.
The official "I like the GTR, and I don't give a **** what OT thinks" thread. Strider Off-Topic 181 05-13-2015 10:18 AM
The official "I drove through some snow, and now my car shakes" thread Turn in Concepts Brakes, Steering & Suspension 48 07-09-2014 10:19 PM
The "I got bored and did ____ to my car today" Thread DraconisWRX Rocky Mountains Impreza Club Forum -- RMIC 3099 02-22-2012 10:52 PM
*The Official, "I won it in a raffle, but don't need it, so now it's for sale thread TRooper SCIC Private Classifieds 9 08-12-2008 12:13 AM
The Official "Is Jiffy to good for NASIOC now that he has a girlfriend" Thread DILLIGAF Racing Mid Atlantic Impreza Club -- MAIC 42 05-31-2004 05:39 PM
