Old 08-21-2013, 03:19 PM   #576
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
Originally Posted by KensImpreza View Post
I do'nt see an FAQ for Tire Pressure, went with a 17 inch rim on my 08 2.5i and I do not know what to best set my tires at since the numbers on the pillar don't really apply since it is no longer a 205/55R16. I now have 225/45R17 Hankook Ventus V12 evo's on my larger rims with a max psi of 50. Everything I have found in some threads most people run slightly over 33/32 or around 40psi for all four tires. Could someone give me some input or advice on which threads to check out? Thanks!
IMO, which is based on much experience with this at Autocross, is for spirited driving run about 3-4 lbs higher than what is listed on the pillar for spirited driving. Maintain the bias for front to rear, that is based of the weight at each end of the car. Try this and watch your tread-wear. Wear in the middle, reduce pressure, on the edges increase. I run 255's on my STi now, which had 225's stock, and I have had no problems.
prochucker is offline   Reply With Quote
Old 08-21-2013, 03:45 PM   #577
cmiovino
Member#: 134005
2004 WRX Premium
I agree to maintain the bias front to rear. When I run stock pressures, I get wear on the outside edges of the tires, mainly in the front. Toe is at zero and camber is 1-2 degrees.
My tires wear evenly if I run near 50 for those Hankooks. Each tire is different. The stock door pressures are for the stock tires.
Try 47/43. My tires are 205/55/16... so even that comes to play. You might be able to go lower with the smaller sidewalls and have a comfortable ride and normal wear too.
I experimented in autocross with chalk and found the high 40's netted me better times and less sidewall roll. These tires have a very soft sidewall.
Old 08-21-2013, 04:28 PM   #578
KensImpreza
Member#: 201077
2015 WRX
I agree, I had never put much thought into the tire pressure with the different tire and wheel, but did notice the outside edges wearing on the tires. I just had an alignment two days ago so everything is within specifications.
So you have used the same Hankook's and were using around 50psi?
Okay I will see what works. I am going on vacation to Cape Cod and wanted to make sure they would be at the best for driving longer distances.
Thank you bother prochucker and cmiovino for your input and help!
KensImpreza is offline   Reply With Quote
Old 09-21-2013, 07:18 PM   #579
WRXRallyFan
Member#: 367779
'03 WRX 5d Yellow
'14 WRX 5d Ltd SWP
Great article
WRXRallyFan is offline   Reply With Quote
Old 09-23-2013, 05:28 PM   #580
jiannelli32193
Member#: 325826
2011 Impreza WRX
Default 2011 wrx running sluggish
Bone stock. just curious if its normal or not for my 2011 wrx hatchback to be running sluggish on some days. i live on long island, in New york, and lately the temperatures have been varying from 60-70 degrees farenheit. this is usually when the car runs sluggish off the line. but once it cools down below 60 degrees at night, the car runs how it should..will my car run differently on different days depending on the temperature/humidity? or does that all stop once i start modding and get a tune?
appreciate the help
jiannelli32193 is offline   Reply With Quote
Old 09-23-2013, 08:52 PM   #581
TheWRXinMe
Member#: 364877
2013 WRX Hatch
Yes outside temperature will definitely affect performance.... I would say if you have 30+ deg swings in temp from day to night you will easily feel the difference.
The question is, by sluggish do you mean it feels like you have less power or does it feel choppy?? You will definitely feel as if you have less power in high heat... And it feels dramatically different in 90-100+ temperatures...
TheWRXinMe is offline   Reply With Quote
Old 11-12-2013, 01:20 PM   #582
sam11rs
Member#: 366563
2001 impreza rs
unabomer knows his stuff
sam11rs is offline   Reply With Quote
Old 11-17-2013, 04:58 PM   #583
SwedeChariot
Member#: 373853
WalMart synthetic? That seems like a hot tip.
SwedeChariot is offline   Reply With Quote
Old 12-14-2013, 01:45 PM   #584
jsti23
Member#: 219536
Dude.. Unabomber you are the shizz! Thank you thank you thank you for dedicating (part of) your life to helping newbs like me!
jsti23 is offline   Reply With Quote
Old 12-15-2013, 03:52 AM   #585
Gam30vR
Member#: 289486
03 WRX
I'm drunk (not driving) and yeah uni! I re read your stuff all the time. Changed my life.
Gam30vR is online now   Reply With Quote
Old 12-20-2013, 08:54 PM   #586
fastwrxrme
Member#: 358042
2005 Impreza WRX/STI
So much awesome information. Thanks for putting this together uni
fastwrxrme is offline   Reply With Quote
Old 12-21-2013, 05:07 PM   #587
Heel_Toe_Hero
Member#: 364056
Nice to see a lot of the common stuff all in one place
Heel_Toe_Hero is offline   Reply With Quote
Old 12-21-2013, 09:37 PM   #588
DOHBOYWRX
Member#: 314698
2005 WRX
White "Phatbotti Tuned"
Amazing!!!!
DOHBOYWRX is offline   Reply With Quote
Old 12-21-2013, 10:32 PM   #589
pbwixson
Member#: 376694
Nice work!
pbwixson is offline   Reply With Quote
Old 01-15-2014, 11:16 PM   #590
Sacramento
Member#: 372886
Great list, fantastic resource!
Sacramento is offline   Reply With Quote
Old 01-20-2014, 11:35 PM   #591
newphow
Member#: 348251
2003 subaru wrx
sonic yellow/black
i ****ing love you...
newphow is offline   Reply With Quote
Old 02-03-2014, 11:29 AM   #592
Japereira88
Member#: 333334
2012 WRX LTD Silver
Hybrid 337/337 @19psi
Default newbie here
hi all, just wanted to say ive recently joined the forums here and am looking forward to learning from all of you! have a general sense here but am looking to learn a lot, more in depth, and be able to do all the work on my '12 wrx. so far ive put in small mods, just a short throw, CB exhaust, and V2 accessport. im in love with these cars!
Japereira88 is offline   Reply With Quote
Old 03-06-2014, 08:18 PM   #593
Ilovemyboxer
Member#: 379336
08 Wrx
swp
The best thread ever
Ilovemyboxer is offline   Reply With Quote
Old 03-09-2014, 04:12 PM   #594
wrenchindagears
Member#: 384055
impressive!
wrenchindagears is offline   Reply With Quote
Old 03-12-2014, 09:13 AM   #595
AyB88
Member#: 317054
2002 WRX Wagon
Just want to say THANK YOU FOR THIS!!
AyB88 is offline   Reply With Quote
Old 03-23-2014, 11:41 AM   #596
houndking
Member#: 349683
2008 Impreza WRX STI
I know I'm late to the party, but this is a great post. I can't wait to get home from deployment and back to my wrx.
houndking is offline   Reply With Quote
Old 03-23-2014, 02:10 PM   #597
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You live in the same city as I do. If you ever need anything, send me a private message and I got you.
Our FB group: https://www.facebook.com/groups/167422053337548/
Our NASIOC hangout: http://forums.nasioc.com/forums/show....php?t=2393486
Old 04-15-2014, 09:37 PM   #598
Azz
Member#: 214660
2005 Impreza STi
Tons of excellent info!!
Azz is offline   Reply With Quote
Old 04-27-2014, 05:18 PM   #599
TMH
Member#: 238046
This is great--thank you!!
TMH is offline   Reply With Quote
Old 05-20-2014, 06:53 PM   #600
Lionscage
Member#: 391392
1999 JDM WRX RA Ltd.
Sonic Blue (74F)
Very cool info!
Lionscage is offline   Reply With Quote
How do I go about getting the Unabomber's Manifesto published? Unabomber Off-Topic 42 01-20-2009 08:05 AM
Unabomber's Manifesto grambo Newbies & FAQs 8 10-26-2006 01:41 PM
