Old 01-08-2014, 01:28 PM   #651
New88
Member#: 344130
2013 WRX Hatch
Thanks for the writeup Dave. I am completely new here, and just read this entire thing, as well as Unabomber's FAQ's. It seems a LOT of posters here spouting off about how horrible BOVs are, didn't even take the time to read anything!
I do have one question though, that I haven't seen addressed anywhere where BOVs/BPVs are being discussed, is that the BPV takes the air from between the compressor and the engine, and dumps it before the compressor, after the MAF sensor.
The piping leading up to the compressor does not have any type of backflow prevention (is open to the atmosphere at the filter), so when the air enters (from the BPV), it has 2 choices: go to the compressor, which is now only running on momentum, or go to the atmosphere. Air will take the path of least resistance and flow mostly toward the atmosphere, and back out apast the MAF sensor (so that already metered air idea doesn't hold much girth with me, at the moment).
Has anyone looked at this? I am a marine systems designer/engineer, and have drawn up a diagram of the system to ask a few coworkers. The most benefit we can see, would be from recirculating the air, as that the air has already been through the intercooler, and cools some more as it joins again into the intake (expansive cooling), thus cooling the compressor/making it slightly more efficient.
Sorry for the long post, and reviving an ancient thread, but I haven't seen anybody address this.
New88 is offline   Reply With Quote
Old 01-24-2014, 04:08 PM   #652
mephistomarius
Member#: 330895
2002 Impreza wrx
blaze yellow
love my go fast bits 50/50 blow off valve, lol its been on my car since 02!
mephistomarius is offline   Reply With Quote
Old 01-24-2014, 04:26 PM   #653
AFP520
Member#: 102932
2014 STI Sedan
Air was never the problem with a BOV. It's the fuel. You cannot tune/modify the ECU to account for vented air, so the car will always inject that extra fuel and you will get the rich spike for under a second.
I believe a speed density system changes the whole way injection works and that's why you can go either recirc/vented without issue.
AFP520 is offline   Reply With Quote
Old 01-27-2014, 02:43 PM   #654
asticklerr
Member#: 369974
This might have already been answered, but I want to be 100% sure. I just bought the Perrin recirculating BOV for my 2012 WRX, and I was just wondering if I need a tune, or if theres anything I should do. And if anyone else has this BOV, what setting are you running on it? Softer, or harder? lol Thanks!
asticklerr is offline   Reply With Quote
Old 03-03-2014, 10:44 PM   #655
iknowanoah
Member#: 307228
04 wrx wagon
no bov sleepin
iknowanoah is offline   Reply With Quote
Old 03-07-2014, 07:18 PM   #656
jwassil7
Member#: 383902
2006 2.5i impreza
can i ask what running rich means?
jwassil7 is offline   Reply With Quote
Old 03-08-2014, 02:28 PM   #657
Omega9120
Member#: 383120
Love it, great post.
Omega9120 is offline   Reply With Quote
Old 03-09-2014, 09:16 PM   #658
ndprsha
Member#: 384091
Default Thanks for the write up
Thanks for the write up on this
ndprsha is offline   Reply With Quote
Old 03-28-2014, 01:26 PM   #659
Senio
Member#: 275651
2005 STI
Originally Posted by Davenow View Post
See, I know its a confusing message.
They are and they arent. There are ups and downs. If you are worried about performance, and dont NEED the noise, its best to just stick with stock.
It all comes down to
What are you looking to do? Like how much boost, what kind of setup
What are you looking for? Noise?
DID YOU BUY A QUALITY VALVE?
If so
DID YOU ADJUST IT PROPERLY?
Its not that they are "fine" its that they are nowhere near as bad as people like to make them out to be. And that 99% of the time when someone is making them out to be bad, they are making statements that just arent true, and ignoring the larger problem of leaks.
rich wont hurt you. its a split second and its not that rich. LEAKS will hurt you. Less power, and can kill the turbo over time.
How come people have nightmares of being rich for a second ? Dont formula 1 cars change maps to run rich at certain times in a race to make more power ? not trying to be a jerk just like to know as much as i can.
Senio is offline   Reply With Quote
Old 03-28-2014, 01:26 PM   #660
Senio
Member#: 275651
2005 STI
more fuel than air. i believe.
Old 03-29-2014, 10:20 AM   #661
xEJ20x
Member#: 49362
2013 DGM STI
Cobb Stg 2
Correct.
"Perfect stoichiometry" is a ratio of 14.7 air to 1 fuel.
Anything above 14.7 is considered lean and below 14.7 considered rich.
Originally Posted by Garrett Turbos
For Example:
15.0:1 = Lean
14.7:1 = Stoichiometric
13.0:1 = Rich
Turbo cars run happier on the rich side of AFR, within reason.
xEJ20x is offline   Reply With Quote
Old 03-29-2014, 08:52 PM   #662
JDMasfcuk
Member#: 322540
TP Stage 2
I have a 2012 wrx tuned TP Stage 1 with a forge performance recirc valve. I noticed that that idle after installing it now drops much lower than before then picks up. It almost always happens when the car is given a little bit of gas then released. Little help!
JDMasfcuk is offline   Reply With Quote
Old 03-29-2014, 09:14 PM   #663
user1029
Member#: 57064
2008 STi IAG built
HTA86, Meth, 272s, Cos IM
it's leakin
user1029 is offline   Reply With Quote
Old 03-29-2014, 09:21 PM   #664
JDMasfcuk
Member#: 322540
TP Stage 2
Originally Posted by user1029 View Post
it's leakin
Positive? What's the best test to do? I'm guessing a spray bottle around the area where it bolts right up to the intercooler?
Old 04-05-2014, 09:46 AM   #665
sxesubaru
Member#: 386598
2004 Impreza WRX STI
Definitely a good read.
sxesubaru is offline   Reply With Quote
Old 04-13-2014, 04:57 AM   #666
Dguzzardo22
Member#: 387593
Thanks !!
Dguzzardo22 is offline   Reply With Quote
Old 04-14-2014, 03:48 PM   #667
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 627/484 2015 BRZ
Are there any pros and cons to running a full recirc or just going atmospheric with speed density? Other than a simpler piping configuration. ...and noise. ?
as in, does one do the job more efficiently than the other?
again, SD... not MAF.
A Fatal Ode is offline   Reply With Quote
Old 04-22-2014, 06:36 AM   #668
scylar
Member#: 369585
Good write up.
scylar is offline   Reply With Quote
Old 04-24-2014, 07:22 PM   #669
endeeeejay
Member#: 386655
2008 Impreza WRX STI
WHITE
Thanks for the write-up... taking notes.
endeeeejay is offline   Reply With Quote
Old 04-24-2014, 11:05 PM   #670
kryptea
Member#: 388765
2012 STI sedan
DMG
great FAQ!!!
kryptea is offline   Reply With Quote
Old 05-02-2014, 08:12 PM   #671
BobbyDUBRX13
Member#: 378890
Anyone have thoughts on the GFB respons hybrid BOV? and right now I just have the sf intake cat back exhaust and running a stage 1 map on the AP.. I'm planning on replacing the tmic with a process west TMIC and I think this valve would be the best so I can set it up as a 100% recirculating or maybe do a 20% atmospheric and 80% recirculating what do you guys think
BobbyDUBRX13 is offline   Reply With Quote
Old 05-11-2014, 12:42 AM   #672
Rob_STI_PNW
Member#: 387796
2015 WRX
RED
i think if you are deadset on a BOV get a full recirc one until you get a bigger turbo like Cobb XLE...
Rob_STI_PNW is offline   Reply With Quote
Old 05-11-2014, 01:14 AM   #673
Rogue_P
Member#: 371737
2003 **** Your
Fake Parts
TiAL for me every time.
Rogue_P is offline   Reply With Quote
Old 05-20-2014, 06:54 PM   #674
Lionscage
Member#: 391392
1999 JDM WRX RA Ltd.
Sonic Blue (74F)
Just the info I needed, thanks!
Lionscage is offline   Reply With Quote
Old 05-21-2014, 01:05 AM   #675
Next_Gen
Member#: 304811
2006 WRX
RED
So I have a 2006 WRX with a cobb access port stage 1 install, I don't have a BOV and I am considering adding one. Any tips, good/bad experiences that you can share with a young person.
Next_Gen is offline   Reply With Quote
General Subie Newbie FAQ. Lets answer a few common questions and dispell some myths. Defiant Autospeed Newbies & FAQs 59 08-18-2015 03:36 PM
2.0L or 2.5L what are the ups and downs thewannab2002 Newbies & FAQs 28 05-27-2010 12:18 AM
The ups and downs of life MGXsport Off-Topic 14 09-10-2007 10:03 PM
S-AFC ups and downs y2k02scoob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-16-2003 05:21 PM
What are the ups and downs of a dog box- any brand? GT2WRX Transmission (AT/MT) & Driveline 23 08-06-2002 08:30 PM
