Old 03-11-2014, 01:35 AM   #1
Kirby10
Member#: 300139
2010 STi
Spark Silver
Default Would a bad front O2 sesnsor cause stumbling/hesitatiom
My car is a 2010 STI and was tuned by a great tuner. Car was tuned at 32k and is now at 60k. It was running great until all of a sudden it hesitated and stumbled badly at or above 3,000rpms please help
Kirby10 is offline   Reply With Quote
Old 03-11-2014, 01:44 AM   #2
Kirby10
Member#: 300139
2010 STi
Spark Silver
Bump please help
Old 03-11-2014, 01:45 AM   #3
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
Could be - but it depends on the driving circumstances. If it stays in closed loop, then yes it would cause stumbling. If you're getting on it enough to throw it into open loop, as per the tune, then it could be something else. The front AFR sensor isn't used for open loop fueling adjustments.
BeastianSTI is offline   Reply With Quote
Old 03-11-2014, 02:14 AM   #4
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
Any codes?
If no codes... ask this "great tuner" of yours.
DHRDAN is offline   Reply With Quote
Old 03-11-2014, 04:46 AM   #5
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Do not bump after 12 minutes at 1am. Let people read and respond. Common sense is talk to your great tuner.
Old 03-11-2014, 11:40 AM   #6
ShawDizzle
Member#: 118902
08 WRX Premium Sdn
Yes it can but a lot of things can. You should be throwing a code for a bad o2. It could be going bad but not totally crapped out yet.
Also, what do you mean by stumble? Was it a stumbling as you were beginning to boost or was it a hard stumble almost like a fuel cut?
ShawDizzle is offline   Reply With Quote
