Old 03-11-2014, 12:02 AM   #1
Sonorarex
Member#: 383070
Default Question about bov block off plate
Iv been told the blocking the bov port on the intercooler is beneficial and can net up to a 35hp gain. Is there any truth to this?
Sonorarex is offline   Reply With Quote
Old 03-11-2014, 12:05 AM   #2
shagfagon
Member#: 337836
2002 WRX Wagon
If that were the case don't you think subaru would have done that for you?
Whoever told you that literally has absolutely no idea what they are talking about and you should never go to that person for any advice about anything automobile related, ever.
shagfagon is offline   Reply With Quote
Old 03-11-2014, 12:31 AM   #3
Sonorarex
Member#: 383070
The article that stated this was instant that by placing a plate you will keep all of the boost pressure created by your turbo going through your intake manifold. I do appreciate the advice before I took any foolish steps. I also have just received my new grimmspeed intercooler and was wondering if there is any need to install an air oil separator along with it
Old 03-11-2014, 12:31 AM   #4
Sonorarex
Member#: 383070
I believe it was a post on club Wrx
Old 03-11-2014, 01:13 AM   #5
shagfagon
Member#: 337836
2002 WRX Wagon
You need to read up on boost control and regulation. All of the "boost" goes through your manifold. The regulation of boost is controlled by your boost controller and waste gate, not the bpv/bov.
The excess "boost" flows through the bov/bpv when the throttle plate snaps shut (when you shift or lift off the throttle quickly)
If this boost was not diverted back into the intake or out into the atmosphere, (hence using a solid plate) the air would flow backwards and smash into the compressor wheel, rapidly stopping it or reversing its direction. This is horrific for the bearings and can accelerate wear by an extreme amount.
If you want more boost, which you can't safely do that without tuning and adding more fuel, you can:
1. Go to a tuner
2. Get an manual boost controller and raise your boost to the moon and then blow your motor
3. Go to a tuner
Old 03-11-2014, 01:56 AM   #6
lookylookitzadam
Member#: 348254
2013 WRX
Bypass valve is essentially blocked off during a wot pull anyway.... A plate is a surefire way to get compressor surge though.
lookylookitzadam is offline   Reply With Quote
Old 03-11-2014, 04:40 AM   #7
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
No. Just no.
Do yourself a favor and pick up a book.
Old 03-11-2014, 05:34 AM   #8
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
And what is up with everyone asking about an AOS recently? That's gotta be the third or fourth time it's come up in the past week!
Old 03-11-2014, 08:12 AM   #9
SpamBot
Member#: 287534
Well, there you have it! If it's on the internet, it must be true!
Don't read the article about the aliens probing your anus while you're asleep.
SpamBot is offline   Reply With Quote
