Old 03-18-2014, 05:07 PM   #1
kevin corn
Member#: 347958
1999 OBS
Default Baja block and '98 legacy GT heads
Any out there know if DOHC heads from a '98 Legacy GT will work with a 2006 Baja block?
kevin corn is offline   Reply With Quote
Old 03-19-2014, 10:07 AM   #2
JoshP
Member#: 94350
Yes..
JoshP is offline   Reply With Quote
Old 03-19-2014, 01:57 PM   #3
77Targa
Member#: 369118
The thing to be mindful of is the cylinder head volume and squish area as the legacy GT heads most likely are the smaller volume heads that will end up with a compression bump. I am building a ej20 turbo with the same heads and ended using thicker head gasket to reduce compression a bit for the turbo.
77Targa is offline   Reply With Quote
Old 03-19-2014, 08:15 PM   #4
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Yes, but will they work with your intake manifold, sensors and ECM is the bigger question........
What car is this going into? EGR, no EGR?
Old 03-19-2014, 09:07 PM   #5
subaroket
Member#: 122690
More information is needed. Which pistons will you use? Which manifold and ECU?
subaroket is offline   Reply With Quote
Old 03-20-2014, 06:49 AM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Which Baja engine? The N/A EJ25 or the turbo EJ25?
Old 03-20-2014, 12:23 PM   #7
kevin corn
Member#: 347958
1999 OBS
It's a 2006 N/A Baja block. I have a 96 impreza coupe that has a '98 Legacy GT 2.5 DOHC motor, but it threw a rod. I use the car for racing in Rallycross. It is using the stock 2.2 ECU and intake.
