Welcome to the North American Subaru Impreza Owners Club Saturday August 23, 2014
Old 09-04-2013, 01:04 PM   #151
tersplat
Member#: 337888
2003 WRX Wagon
World Rally Blue
sweet, thanks!
tersplat is offline   Reply With Quote
Old 09-05-2013, 03:54 PM   #152
rapa
Member#: 230077
Originally Posted by Hawken View Post
Rapa you're spot on.
Started first crank..
Swapping C16 to C15 is the way to go for an ADM to JDM swap. (I also found a few incorrect references to D16 to D15.)
Now to sort out the power steering and exhaust, then go for a drive...
FYI, Loosening the turbo bolts still didn't give enough clearance to get the motor in, I ended up removing the 2 bottom studs and replacing them with bolts.
Glad I could help someone =]
took me a lot of hours of search and trials...
rapa is offline   Reply With Quote
Old 09-21-2013, 07:24 PM   #153
Hawken
Member#: 316735
2000 WRX with EJ207
Dark blue
OK, another question for the experienced...
Everythings running sweet. I've modified the splitter so all the intercooler gets air, sorted the exhaust, got the aircon working etc. I'm happy withe the power increase but It's always nice to get a little more.
So now It's time to start fiddling.
The only problem is I can't get the ECU to go into programing mode.
I've connected the 2 green plugs and shorted the 2 pins of the white plug under the dash but the fans don't cycle and my Tactrix cable wont download the ROM.
I can get logging data fine and the cable itself will log, so it's not a problem there.
Are there any other wiring changes that need to be made?
Hawken is offline   Reply With Quote
Old 09-22-2013, 10:32 AM   #154
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
I don't touch the white plugs. Just connect the 2 green connectors.
25rsti is offline   Reply With Quote
Old 09-22-2013, 08:26 PM   #155
Hawken
Member#: 316735
2000 WRX with EJ207
Dark blue
Mmmmm
Tried that too. Still no joy.
Old 09-23-2013, 06:26 PM   #156
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
Are you turning the key and hitting the button quick enough to work aka fans cycle etc?
Old 09-23-2013, 09:06 PM   #157
Hawken
Member#: 316735
2000 WRX with EJ207
Dark blue
Yeah have tried a few different combinations.
Just to clarify.
My impression is that even if you don't have anything to read the ECU, if you have the plugs connected and turn the ignition on the fans should still cycle.
For reading the ECU the trick is to start the software before the fans switch off.
Old 09-26-2013, 10:42 PM   #158
APriestOfGix
Member#: 280305
2003 JDM v9 STi WRX
How is everyone's EJ207's doing?
I took my car out to auto-x at Subiefest and have what sounds like a stuck idler (getting a nice squeal) even though they are all brand new. The timing cover is coming off this weekend to see what's up, but wondering if anyone else has heard of this?
APriestOfGix is offline   Reply With Quote
Old 10-26-2013, 03:40 AM   #159
Fehnix
Member#: 300587
02 wrx wagon ej207
I want more power lol I'm wondering how much I can get out of the stock twinscroll.
Fehnix is offline   Reply With Quote
Old 10-26-2013, 07:57 AM   #160
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
I only drive mine about 1-2 times a month for a few miles. Love it every time.
Old 10-26-2013, 12:05 PM   #161
Fehnix
Member#: 300587
02 wrx wagon ej207
Must be nice. I'm forced to commute to school 4 days a week :/
Old 01-30-2014, 08:40 PM   #162
Florin1
Member#: 163625
91 Legacy SS
Bumping this thread since the OP seems to be gone. Have an AVCS question.
After reading the thread, I got a bit confused on what I need to do wiring wise. I bought a jdm engine harness, and I also bought an avcs harness like OP had from another member that has been prepped. My car is an 02 wrx manual. I'm following the ds1 write up but now I'm wondering if I'm doing too much. Last night I got as far as page one. The one on moving pins 4 5 10 11. I also added 6" pigtails to pin 2 3 9 14 15. These are not yet soldered to anything. I'm worried about pin 14 because it says shield common ground. Not sure what that means. So my question is, do I need to follow the ds1 instructions all the way, or do I not, since I have the harness.
Florin1 is offline   Reply With Quote
Old 02-18-2014, 08:28 AM   #163
bipolarnrute
Member#: 340737
I don't remember the ds1 instructions mentioning anything about soldering. You should just be relocating pins and adding in your harness.
bipolarnrute is offline   Reply With Quote
Old 03-14-2014, 02:00 PM   #164
APriestOfGix
Member#: 280305
2003 JDM v9 STi WRX
You will need to re-locate 4 pins, and add 2 additional. I ended up going with the IA Performance AVCS wiring harness, and it was SUPER simple. I highly recommend it, just plug and play.
Old 03-20-2014, 06:10 PM   #165
PHruska
Member#: 214589
2002 wrx wagon
I scrounged mine out of the full JDM harness. There is already a fully functional shielded harness in there if you know where to look. lots of messy wiring to sift through to get to it though. then it was just move a few and plug in. super easy.
PHruska is offline   Reply With Quote
Old 07-01-2014, 08:24 PM   #166
rgibs041
Member#: 361761
2002 wrx wagon
aspen white
My v7 comes tomorrow. Anyone in the east bay, Bay Area willing to help with the avcs wiring next week? I got two buddies helping with the motor install I just want to make sure the wiring gets done correctly. I would greatly appreciate any help!
Thanks guys
rgibs041 is offline   Reply With Quote
2005 STI into 2002 Bugeye Swap psychorunner Subaru Conversions 20 03-08-2012 08:28 PM
My STI swap into 02 Bugeye Tweeder Member's Car Gallery 19 06-04-2011 03:13 AM
JDM V7 ej207 into my 05 WRX CamTunedSti Built Motor Discussion 6 11-10-2010 04:40 PM
I have some questions regarding - Version 7 v7 EJ207 into USDM 2004 STi STepeci Subaru Conversions 8 09-18-2009 07:26 PM
dash/interior swaps into 02 bugeye? ricky05 Interior & Exterior Modification 4 01-25-2007 04:03 AM
