Old 12-05-2013, 08:25 PM   #76
Amac
Member#: 146329
2000 RayneKillswitch
w/k3 Aeras
Sweet thanks for the help man.
Amac is offline   Reply With Quote
Old 03-16-2014, 01:05 AM   #77
Clinically_ill
Member#: 356436
Ok, I have a question about this. Ive been considering doing this for a while now with a staggered wheel set up.
If we are still running a 5 speed Subaru transmission does this lower the stress on it? I don't want a 6 speed I like the gearing in my 4.44 5MT I want to do this and pick up a 4.44 R180. The wheels I want are also dual drilled so I can run my 5x100 hubs on the front and do 5x114 in the rear for the fatter axles.
FYI, I'll have 350whp when my motor build is complete
Clinically_ill is offline   Reply With Quote
Old 03-17-2014, 01:57 PM   #78
Clinically_ill
Member#: 356436
Anybody know if this will boost the power handling of the 5MT because it will be less stressed?
Old 03-18-2014, 07:00 PM   #79
Andrewxxcarlson
Member#: 316415
2006 WRX
Subscribed
Old 03-18-2014, 07:32 PM   #80
ToneWrx02
Member#: 239095
2002 Wrx
You think that coilovers that are subaru specific are setup for awd? Hell no.
Most people think you just slap them on and ready to go, but to get real gains you need to tune/adjust the settings on the coilovers.
Good coilovers are adjustable and can be made to work with whatever type of driving you are into.
Pfft. Its like middle school up in here.
ToneWrx02 is offline   Reply With Quote
Old 03-18-2014, 08:52 PM   #81
Clinically_ill
Member#: 356436
^ yes, & sway bars can be played with to get the right feel. Anyways, I'm not worried about that, I want to know if the 5MT will be less stressed from going to RWD. I want to keep my 4.44 5MT & swap in a 4.44 R180 with a nice LSD.
Old 03-19-2014, 07:43 AM   #82
ToneWrx02
Member#: 239095
2002 Wrx
Yes. It will be tons more reliable since it will have alot less moving parts and break traction easier then taking all the load and stress on the hears
Old 03-19-2014, 05:59 PM   #83
Clinically_ill
Member#: 356436
Awesome here is a good thread for guys to read
http://www.rs25.com/forums/f9/t20699...up-thread.html
and an email I got from PPG:
"When putting the spool in, it will reduce some of the load on the gearbox, but will add a bit of extra stress to the rear diff and axles.
I could supply you a Torsen style LSD made by PPG or I would recommend a Kaaz LSD. They work a bit better than a Torsen style one. Our Canadian distributor Magnus Motorsport usually stock these and at least could access them.
Personally, if your budget allows I would go for larger axles. The oem ones are not the best to begin with.
I would also advise in asking Magnus Motorsport for a price on the spool as they would probably be able to do a better price than me as they are a distributor."
Old 03-19-2014, 06:05 PM   #84
Clinically_ill
Member#: 356436
Sounds sweet, so I think after I tune my car up this summer, I'm going to tackle this project next winter & do it right (removing the front diff & sealing it up). Probably get an R180 & drop a Kaaz LSD in it aswell as a Perrin cover with the heat sinks, PPG spool, the wheels I want which are dual drilled (5x100&114 so I only have to change the rear hubs), bigger axles, carbon driveshaft & some good tires. Should be sick... Suspension tuning to follow
Old 03-21-2014, 01:34 AM   #85
Clinically_ill
Member#: 356436
So, what is the weak part of the axles? Is it simply the bars??, where do they snap?
I'm wondering if just doing these would be good enough for 350rwhp?
http://www.driveshaftshop.com/import...le-bar-upgrade
From the site:
"Subaru 2004 WRX STi Rear Axle Bar Upgrade. The STi is a very stout car from the factory, the inner and outer CV's are made from a Japanese spec material very close to our 4130 chromoly, but the center bars are made from a brittle lower grade material. What we have made is a custom set of aerospace grade center bars that will fit your stock inner and outer CV. This kit comes with both axle bars, boots, clamps and grease.
Please Note: This axle bar upgrade is for the 2004 STi ONLY. If you have a 2005-2007 STi, see part# SBR2
I'm wondering, if I get an R180 4.44 rear diff that come off an older JDM RA, I'll need the 04 STi axles to use with this kit because they are for 5x100 hubs?
That kit is much cheaper than something like this:
http://www.driveshaftshop.com/import...-5-front-axles
Old 03-22-2014, 11:04 PM   #86
Clinically_ill
Member#: 356436
lol, I feel like I'm walking alone in the desert sun... ... ...
Old 03-23-2014, 10:47 PM   #87
Clinically_ill
Member#: 356436
Old 04-24-2014, 10:01 PM   #88
PRwrxCoastie
Member#: 326771
2002 Wrx
Alright so ive read through the whole thread and i know this may have been answered already or not but for the r160 what is the power level they start falling apart? i want to do this but as everyone else i dont want to spend that much on broken parts so far all i have is 16g 16lbs and sometimes 18lbs if i feel like it, big tmic, dp and up and a conservative tune by me...no power numbers but i wouldnt say im past 250whp so is the r160 sufficient for that power level? or should i just stick to AWD and keep drifting in my dreams? I have really no interest in becoming the next drift king or impressing anyone i just really want to make the car a little bit more fun...AWD is kinda boring when its not snowing
PRwrxCoastie is offline   Reply With Quote
Old 04-24-2014, 10:30 PM   #89
Paidfor
Member#: 267815
Be in awe
dont hate .)
Your gonna kill that little 160......cram the R180 in there and youll be ok to 400ish......maybe lol
Im goin RWD also but kinda for different reasons .)
I expect my 180 to last a few passes before she scatters all over the highway haha
Old 04-24-2014, 11:00 PM   #90
SexyWRXy43
Member#: 311562
You can get an svx r200 and you should be good for much more power, although you might need a different driveshaft and possibly axels from the svx. I don't remember specifics but it has been done.
SexyWRXy43 is offline   Reply With Quote
Old 04-24-2014, 11:03 PM   #91
PRwrxCoastie
Member#: 326771
2002 Wrx
Hey thanks for the reply!! So im guessing you already have an STI...So r180 is better but i have to get the axles and hubs and everything for it which is gonna be expensive though and im guessing im gonna have to use the rear brembos too...oh well i guess i'll just stick to awd and drift in forza...real life sucks sometimes hahaha but to everyone else who is doing RWD conversion you guys rock!!!!! BIg ups to those who have the knowledge and skills!! I just might do it some day with the r160 and kill that sucker just for a quick smile on my face...
Old 04-25-2014, 01:04 AM   #92
Amac
Member#: 146329
w/k3 Aeras
Im just Happy this thread is still going. Im still working on getting my motor together. After that, its time to save for a 6 speed, 5x114 hubs, r180, axles and brembos. So yeah, just a few things.
Old 05-05-2014, 09:46 AM   #93
SaltWaterSubie
Member#: 389951
07 Impreza 2.5i se
black
Nice one. Although RWD looks fun, it wouldn't be of much use in my climate.
SaltWaterSubie is offline   Reply With Quote
Old 05-05-2014, 11:05 AM   #94
sureshot007
Member#: 142405
#716 G2 OBS
I recently got my PPG rwd adapter (after having been boned by a fellow nasioc member on a welded diff), and I'm looking forward to giving this thing a whirl at STPR.
sureshot007 is offline   Reply With Quote
Old 05-06-2014, 05:32 PM   #95
djelly84
Member#: 186766
04 WRX Driftaru
White & Blue
Damn this thread blew up. Didn't read everything just through the last couple pages but wanted to post some responses based on my experience. Been drifting my Rwd 04 WRX since late 2010. So first, the svx does not have a r200, it has a r180. The weak area of subaru's isn't the differential. It's the axles. The r160 will hold up to say 350hp Rwd. The r160 axles normally won't hold near that much Rwd. The R180 can actually hold a lot of horsepower. I had no problems on the diff at 550tq. Friend also runs it and makes over 600 Rwhp. Most difficult thing is welding the r180 correctly. It's different than how you'd weld an open differential. Below is a picture of the r180 welded correctly. You weld the bottom spider gears to the cups that slide into the housing. It took me three diffs blowing up to figure that out lol. Axles are different issue. Stock r180 axles are hit and miss. Normally people bust them between 300-400 Rwhp. Seen them break all different ways. On the axle shaft, stubs. Most common is the cv grenading. Aftermarket axles like DSS are better, but still can have issues. I had several issues with the axles between 400-600tq. Again, broke them all types of ways. Everytime though DSS was awesome about warrantying them and all that. Awesome customer service. Eventually I got sick of breaking axles though as i traveled out of state for two big drift events and had axle breaks pretty much stop my driving. Once right before qualifying and second on the first heat of a two day event. Not fun. Only real way to stop issues from happening is to convert to a r200 rear diff. Different people have used different r200 variants ranging from old 300zx long nose r200s, s13, s14 and even 350z diffs (have to lose stock fuel tank for last one). I chose to go q45 as it is same size as s14, has a low final drive of 3.54, and you can use 6 bolt star flange nissan axles, like 350z, which are known for being really strong. You then machine s14 five bolt hubs to match sti hubs and press these into sti rear knuckles. You use whatever axles for your diff and have spacers made to push out your axles from the diff stub shafts for your wheelbase. Sti vs s14 (unmachined) Unmachined s14 Machined s14 350z cradle - tyconway's S13 cradle and axle spacers - Logan Noel's Alright hope this helps! Go get sideways!
djelly84 is offline   Reply With Quote
Old 05-06-2014, 06:09 PM   #96
Amac
Member#: 146329
w/k3 Aeras
Well that was help full, thank you Sir. Hows the jz swap going dj?
Old 05-06-2014, 08:29 PM   #97
djelly84
Member#: 186766
04 WRX Driftaru
White & Blue
Slowly but surely...trying to knuckle down and get it done!
Wasn't going to mention my opinion on how suitable the boxer engine configuration is for drifting, but since you mentioned it lol...
Old 05-06-2014, 09:20 PM   #98
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
when you machined your hubs did you just chuck it up onto the hub centric part? or did you make a splined chuck ? i was about to machine a set, but the guy that is helping me thinks that i need to make a splined chuck in order to make it centered with no runout thanks for all the help
olsen726 is offline   Reply With Quote
Old 05-06-2014, 09:31 PM   #99
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
here are some pics of how i modified a stock subaru crossmember to fit an s14diff. just to give you guys some ideas on how to do it/ what to expect
here is a pic of me laying out the cuts on the xmember
this one is showing how the new piece will be placed between the two cuts that i will be making
here is a pic of the cuts i made
here is one of the cut piece removed
here is a pic of how the diff will sit in its new home
and a pic of one side of the old diff mount bracing removed
here is a pic with both sides removed
Old 05-06-2014, 09:32 PM   #100
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
here i am laying out for the holes that the differential will mount to
and a pic of the new piece getting ready to be fit up
new piece tacked it
after that i bolted the crossmember to the car
Here is a pic of it getting ready to be welded
Back side welded
Sorry the pics arent better
Taking the RWD vs. AWD discussion to one place (with poll) Eyeflyistheeye General Community 178 05-01-2008 12:51 AM
Would a RWD conversion fix the gearbox issues? jcl Transmission (AT/MT) & Driveline 7 03-02-2008 02:48 PM
LS1 and RWD conversion on a Honda Prelude.... SilverBoosted Off-Topic 31 07-31-2006 05:58 PM
What are the main differences in these 2 technologies for a 2wd / rwd conversion? dawoniyi Transmission (AT/MT) & Driveline 1 04-21-2006 11:40 AM
front diff/ rear diff/ and RWD conversion supermoose Subaru Conversions 5 09-08-2003 05:16 PM
