Welcome to the North American Subaru Impreza Owners Club Sunday January 25, 2015
Old 09-03-2013, 03:31 AM   #26
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
The ej257 in the 05 sti motor in the car.
srREXed is offline   Reply With Quote
Old 01-17-2014, 03:32 PM   #27
ssotelo11
Member#: 373870
Help me my fellow friends I am doing version 7 swap here it is 02 Wrx usdm harness,jdm engine jdm ecu both version 7. what is the diagram for the repinning havin a hard time getting the car to fire.will the diagram up top work for my swap or is it for Australian cars? I tired the diagram no go??? Help a brother out
ssotelo11 is offline   Reply With Quote
Old 01-19-2014, 02:46 PM   #28
ssotelo11
Member#: 373870
help me out bros icant get the wiring hook up and car wont fire any ideas?
Old 01-19-2014, 09:54 PM   #29
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
All the info in this thread pertaining to the AVCS is correct. That is all that you need to change on a 02-05 USDM WRX to make a JDM STi engine work.
On some JDM engines there is an intake temp sensor that is under the intercooler that needs to be unplugged to make the car run. Check for that and if it is there unplug it and everything should work.
Without changing or adding anything tied to the AVCS the car should be able to start and run with either the USDM ECU or the JDM ECU.
PM me if you have any further questions.
Zephyr is offline   Reply With Quote
Old 03-24-2014, 07:46 PM   #30
02redwolf
Member#: 382010
So did you get it fixed? Was it the little plug under the TB?
02redwolf is offline   Reply With Quote
Old 08-18-2014, 11:06 PM   #31
ronf1964
Member#: 398704
Default E1 Connector
Does anyone have the wire color pin out on the E1 Connector (Engine side). It was cut off on the EJ207 that I purchased. I have the old connector and pins but I need to know where the wires were supposed to go to.
ronf1964 is offline   Reply With Quote
Old 08-19-2014, 12:53 PM   #32
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Pin 1, Crank Position Sensor, W, Connects to OrL
Pin 2, Crank Position Sensor, B, Connects to WL
Pin 3, Cam Position Sensor, R, Connects to Or
Pin 4, Cam Position Sensor, G, Connects to W
Pin 6, Knock Sensor, Y, Connects to RL
Pin 7, ACTIVE VALVE CONTROL ANGLE SENSOR LH, B, Connects to WL
Pin 8, ACTIVE VALVE CONTROL ANGLE SENSOR RH, W, Connects to Or
Pin 9, ACTIVE VALVE CONTROL ANGLE SENSOR RH, G, Connects to W
Pin 10, ACTIVE VALVE CONTROL ANGLE SENSOR LH, R, Connects to OrL
Old 08-24-2014, 10:07 AM   #33
Trboboost91
Member#: 282961
05 Saabaru
Alright wiring masters, let's see if you can tackle this one.
I'm trying to get my jdm ej205 w/Avcs working in The saabaru.
My engine harness was also hacked off at the big connectors and I did not get the
Plugs. so I have the connectors for both cam sensors and both solenoids but basically need to know what terminals on the cam sensors/solenoids go to what terminal holes on the 3 big connectors. I have been using random wires so colors won't help me much.
I'm sure the IA performance Avcs engine harness would be a quick solution but I want to see if I can get it done myself. Just can't seem to figure this part out.
Trboboost91 is offline   Reply With Quote
Old 12-13-2014, 11:33 AM   #34
subarufan555
Member#: 255117
2004 ANY Subi
ANY
I just swapped JDm V8 engine and transmission in to my 05 Saab Aero Wagon.
I made the AvCS Wireing myself ( I have a IAP Performance instructions that they send with their kits)
I did switch pins on drivers side plug (black plug behind battery)
I switch pins in ECU plug According to DS 1 instructions.
I unplug Air temp sensor on intake
But according to IAP instructions there is 5 wires on Ecu side of their kit and 4 on passenger side plug engine bay.
They claim to plug the 5 wire in number 14 on Ecu plug.
They describe it as Shielded wire ground ( bare wire)
In the FAQ question they explain :
The shielded wiring bundle is a 4 wire cluster with 1 ground wire at Ecu end. The ground wire is intentionally bare wire with a piece of blue shrink tubing to signify it . Simply instal it do not fret that it is bare.
I didn't do this #14 pin
So as I understand from reading this I just take a bare wire attach a Ecu pin to it and stick it to #14 on
Ecu and leave it hanging there bare???!!!
Haw long it shudl be?
The reason I'm mentioning all of this is because my car runs Not right when AVCS is hooked up.... Like there is something missing.it runs low Rpm when idling like is missing fuel. When driven it feels like it is starving for fuel.
When I dysconect AVCs wires it runs great but no AVCS.
What can I do here?
subarufan555 is offline   Reply With Quote
Old 12-13-2014, 10:51 PM   #35
subarufan555
Member#: 255117
2004 ANY Subi
ANY
Bump...
FS : PA: 2002 WRX Return to Stock!!! (exhaust, ecu, turbos, exterior, etc.) Bugeye_Bull Engine/Power/Exhaust 8 11-14-2011 01:29 PM
FS/FT : TN :*Going back to stock* 02 wrx harness to 04 Sti complete swap Bug_i_Sti Engine/Power/Exhaust 0 03-01-2011 08:09 PM
A/C wiring help, WRX harness with Legacy A/C compressor wiring help mutiger93gt Legacy Forum 3 03-01-2010 06:34 PM
So... 2002 WRX, Timing advance value in ECU = "1" Chi_San Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-12-2009 05:36 PM
2002 wrx harness urabus1 Private 'Wanted' Classifieds 9 12-22-2003 10:19 PM
