Mid Atlantic Impreza Club
Old 03-20-2014, 12:25 AM   #1876
AspenScoob255
Member#: 217405
2006 WRX
Originally Posted by Horner View Post
They wouldn't happen to be the aluminum links are they?
No sir, 04 came with steel sorry.
AspenScoob255 is offline   Reply With Quote
Old 03-20-2014, 11:21 AM   #1877
Horner
Member#: 324477
2002 2.0 vf43+ meth
6mt wrb sedan
Darn, i was really looking for the aluminum links. its all good though, i saw how much rear camber plates were and i could just have another set of adjustable links by the time i got done. Unless i can get a machine shop to cut slots in my existing rear plates or pick up a cheap set of rear plates i doubt i will be going that route anytime soon.
Although it would be super badass..... Feal revalved, hyperco spring coilovers with all 4 corner camber plates, whtieline adjustable swaybars and HD mounts, front whiteline alk, and aluminum sti front control arms and lateral links with TIC bushings.....
I really want to do it but the wallet says no..... at the moment.....
Horner is offline   Reply With Quote
Old 03-20-2014, 11:39 AM   #1878
AspenScoob255
Member#: 217405
2006 WRX
Darn, i was really looking for the aluminum links. its all good though, i saw how much rear camber plates were and i could just have another set of adjustable links by the time i got done. Unless i can get a machine shop to cut slots in my existing rear plates or pick up a cheap set of rear plates i doubt i will be going that route anytime soon. Although it would be super badass..... Feal revalved, hyperco spring coilovers with all 4 corner camber plates, whtieline adjustable swaybars and HD mounts, front whiteline alk, and aluminum sti front control arms and lateral links with TIC bushings..... I really want to do it but the wallet says no..... at the moment.....
Ya, i want aluminum as well just non-STI. Don't need the wheels pushed out any farther in the back. That setup should handle very well. If you don't want to slot the plates you could always slot the upper bolt hole on the rear struts and adjust camber that way.
Old 03-20-2014, 11:57 AM   #1879
Horner
Member#: 324477
2002 2.0 vf43+ meth
6mt wrb sedan
Yea you have a point. i could slot one of the sets of lower mounts and still run the fixed upper pillow ball. Maybe just some camber bolts in the rear to give me my adjustment back. Im not looking to adjust much but i hate taking adjust-ability out of the car. It might help with the longer arms in the rear to push alittle more negative camber without adjusting anything.
lol who am i kidding, we are going HELLAUNFUNCTIONAL... I NEEDZ MOR CAMBERZ
Old 03-20-2014, 12:50 PM   #1880
AspenScoob255
Member#: 217405
2006 WRX
Yea you have a point. i could slot one of the sets of lower mounts and still run the fixed upper pillow ball. Maybe just some camber bolts in the rear to give me my adjustment back. Im not looking to adjust much but i hate taking adjust-ability out of the car. It might help with the longer arms in the rear to push alittle more negative camber without adjusting anything. lol who am i kidding, we are going HELLAUNFUNCTIONAL... I NEEDZ MOR CAMBERZ
There ya go
Old 03-23-2014, 07:52 PM   #1881
robo1040
Member#: 231114
2011 WRX sedan
ok this is gonna be a long one, but I got a couple problems goin on.
first, im throwing a downstream o2 code, insufficient switching, I have the invidia catless, and I installed a 02 extension cause I had to run them in my other cars when going catless. first, when I called machV they said they can disable downstream 02 to fix that code. then when I emailed eric at torqued he said you cannot disable downstream 02 in these cars, and the cobb map disables the "catalyst efficiency" code and to NOT run a extension. SO.. I took the extension out and have the downstream straight in the bung. Jason, you running catless or catted? how about you Anthony? eric said these cars are much different than bugeyes.
onto my next problem. I installed the invidia long tube header and now am getting p0171, bank 1 lean, and p1153 bank 2 sensor 1 problem. ive done research and it seems like if you take these 02s out and breathe on them wrong they go bad, but many people also suspect that with a new header install, the 02 gets damaged on startup and initial run because of all the **** burning off the header inside of it. TONS of people have had these problems after header installs of all brands. Jason, did you experience this? my fuel mileage went from like 25mpg to 15mpg, which if this was a customer at my shop with these symptoms id be replacing the front 02, but that would also be like a 2001 Pontiac sunfire and not a 2011 wrx. LOL. I guess im just looking for a "yeah that sounds right", before I go spend 150 bucks on a 02 when I could be buying something cool
robo1040 is offline   Reply With Quote
Old 03-23-2014, 09:04 PM   #1882
oncesir
Member#: 141793
02 WRB WRX Wagon
That code is due to the o2 extender. Only older cars can get away with those and the spark plug anti-fouler tricks. Removing the extender should fix that problem.
oncesir is offline   Reply With Quote
Old 03-23-2014, 09:50 PM   #1883
OCMDWRX13
Member#: 360857
2013 WRX
WR Blue
ok this is gonna be a long one, but I got a couple problems goin on. first, im throwing a downstream o2 code, insufficient switching, I have the invidia catless, and I installed a 02 extension cause I had to run them in my other cars when going catless. first, when I called machV they said they can disable downstream 02 to fix that code. then when I emailed eric at torqued he said you cannot disable downstream 02 in these cars, and the cobb map disables the "catalyst efficiency" code and to NOT run a extension. SO.. I took the extension out and have the downstream straight in the bung. Jason, you running catless or catted? how about you Anthony? eric said these cars are much different than bugeyes. onto my next problem. I installed the invidia long tube header and now am getting p0171, bank 1 lean, and p1153 bank 2 sensor 1 problem. ive done research and it seems like if you take these 02s out and breathe on them wrong they go bad, but many people also suspect that with a new header install, the 02 gets damaged on startup and initial run because of all the **** burning off the header inside of it. TONS of people have had these problems after header installs of all brands. Jason, did you experience this? my fuel mileage went from like 25mpg to 15mpg, which if this was a customer at my shop with these symptoms id be replacing the front 02, but that would also be like a 2001 Pontiac sunfire and not a 2011 wrx. LOL. I guess im just looking for a "yeah that sounds right", before I go spend 150 bucks on a 02 when I could be buying something cool
I haven't had any codes or problems come up since I have been catless. As far as the header I haven't really haven't heard anything other than everyone says get a tune after. So I'm not sure. I don't have the extension on my o2 for my downpipe and haven't had any codes come up.
OCMDWRX13 is offline   Reply With Quote
Old 03-23-2014, 10:19 PM   #1884
Horner
Member#: 324477
2002 2.0 vf43+ meth
6mt wrb sedan
I haven't had any funky stuff happen since my header install but I washed it out with brake clean cause there were metal shavings in the tubes before I did my install. You should have seen the crap that I washed out..
To my knowledge, Jason's car is full catless without the extender and all seems well. I don't recall anything weird happening after the header install either but he should be able to comment further on that subject.
I know my mpg went to hell after I did the header and got tuned but I haven't gotten any abnormal readings on the wideband. It's just my car is a lot more sensitive to throttle while cruising. If I keep it between 5"-10" of vacuum it cruises pretty decent. Anything past that and it starts adding fuel and my mpg plummets to 16mpg or less just cruising.
Old 03-24-2014, 11:35 AM   #1885
AspenScoob255
Member#: 217405
2006 WRX
Did you reset the ecu after removing the extension? Also if the O2 sensors are the same, swap them and see if the code comes up again or changes. I believe you are right in thinking it is the sensors.
Old 03-24-2014, 07:16 PM   #1886
robo1040
Member#: 231114
2011 WRX sedan
well I ordered the front o2 today. I don't think they are same part number so I couldn't swap them. I reset the pcm after removing the extension and the downstream code hasn't come back yet, but I haven't driven the car much because its dumping fuel like crazy
Old 03-25-2014, 08:46 AM   #1887
AspenScoob255
Member#: 217405
2006 WRX
Your AFR's are likely erratic after the reset which ruins fuel economy while the car learns. It should go back to normal or close to it after a day or 2 of driving. That is if the issue is resolved, i guess you will know for sure here soon enough.
Old 03-25-2014, 08:07 PM   #1888
robo1040
Member#: 231114
2011 WRX sedan
Yeah the o2 came in today but it was erong
I ordered the oem denso one from rock auto so we will see what happens in a few days
Old 03-25-2014, 09:31 PM   #1889
Workman217
Member#: 359747
2004 legacy
Mystic Blue Pearl
Yeah these sensors are very sensitive. Even on N/A. After my header install I had a A/F ratio / sensor 1 code. I monitored it through obd and was getting nothing. I haven't had any issues since I replaced the sensor. Im guessing all the junk burning off in the header caused the sensor to go bad?. Who knows......
Workman217 is offline   Reply With Quote
Old 03-28-2014, 12:41 PM   #1890
Ghostlystang
Member#: 338515
2013 WRX 6spd swap'd
305/345 ([email protected])
I'm full cat less and still used the factory sensors. Never had a code pop and fuel mileage is fine right around 22mph on average.
Ghostlystang is offline   Reply With Quote
Old 03-28-2014, 02:56 PM   #1891
AspenScoob255
Member#: 217405
2006 WRX
Well, at 22mph I suppose your fuel economy is pretty damn good.....
Old 03-28-2014, 03:56 PM   #1892
Ghostlystang
Member#: 338515
damn typo's
Old 03-28-2014, 04:15 PM   #1893
Horner
Member#: 324477
2002 2.0 vf43+ meth
6mt wrb sedan
Lol I read that earlier and didn't even notice.
Did a few pulls on the way home today with the front windows down.......
Old 03-28-2014, 09:26 PM   #1894
Ghostlystang
Member#: 338515
Ya windows down with the EWG really lets you know how loud it is lol.
Old 03-29-2014, 11:42 AM   #1895
fittedwingz0413
Member#: 382785
Any local td04 available. Im without vehicle. ....
fittedwingz0413 is offline   Reply With Quote
Old 03-29-2014, 11:47 AM   #1896
fittedwingz0413
Member#: 382785
When is next local meet?
Old 03-29-2014, 12:30 PM   #1897
AspenScoob255
Member#: 217405
2006 WRX
Happen to have one in the garage, about 60k on it.
Old 03-29-2014, 01:14 PM   #1898
fittedwingz0413
Member#: 382785
How much shaftplay? When coyld I see it ure in Salisbury right. .. aspen white...u live near red door?
Old 03-29-2014, 01:15 PM   #1899
fittedwingz0413
Member#: 382785
Txt mw or call 4106036570
Old 03-29-2014, 07:39 PM   #1900
robo1040
Member#: 231114
2011 WRX sedan
well I got the front o2 replaced and fixed the issue. I think it was the crap burning off the header that fouled the sensor. I also got my new front fenders painted and put them on today, and I raised the car up so I wont need to roll 'em..
