Welcome to the North American Subaru Impreza Owners Club Wednesday February 10, 2016
Old 02-25-2014, 03:49 AM   #26
maxmercury
Member#: 382760
Really looks good. Just make sure you read on the painting if you're doing it yourself because you don't want to wind up like...well...
http://www.youtube.com/watch?v=pDz7I...id=P-ZG5vGCE2g
maxmercury is offline   Reply With Quote
Old 02-26-2014, 01:05 AM   #27
slavik.86
Member#: 238300
00 2.5rs built
ej255 swap
U serious? This guys a total gee when it comes to painting. Your looking at a pro here
slavik.86 is offline   Reply With Quote
Old 03-04-2014, 05:13 PM   #28
cannonbuilt
Member#: 272859
Praise God everybody!!! God is great!! Glad to be back on the project , been sick last few days and busy working on my friends car, now that his car is done I can focus on mine . thinking of dropping the battery here.
cannonbuilt is offline   Reply With Quote
Old 03-04-2014, 05:18 PM   #29
cannonbuilt
Member#: 272859
Have a piece of roof sheet metal I kept from my other car
Old 03-11-2014, 03:46 AM   #30
cannonbuilt
Member#: 272859
Old 03-16-2014, 05:42 AM   #31
cannonbuilt
Member#: 272859
Started mocking up the air and heater box, and the dash
Old 03-16-2014, 05:47 AM   #32
cannonbuilt
Member#: 272859
Finished the battery box Had to use some homemade ingenuity to make the creese in the bottom pan
Old 03-18-2014, 11:34 PM   #33
eph
Member#: 83120
1992 SS EJ225T
cj91legss
I should have looked more under your dash when I dropped by to get mine from you. Good luck with your swap. Hope mine goes well.
eph is offline   Reply With Quote
Old 03-18-2014, 11:50 PM   #34
cannonbuilt
Member#: 272859
I am sure yours will go well, you just have to dink around with it a bit
Old 03-19-2014, 12:00 AM   #35
eph
Member#: 83120
1992 SS EJ225T
cj91legss
I like the battery tray idea. What made you do that?
Old 03-19-2014, 12:26 AM   #36
cannonbuilt
Member#: 272859
I just don't like the engine bay to be cluttered
Old 03-21-2014, 12:17 AM   #37
cannonbuilt
Member#: 272859
Got the new radiator support, going to drill it out and install
Old 03-21-2014, 02:04 AM   #38
Brandon2k13
Member#: 376571
I drive a car,
and I quite like it.
Subscribing to this, looks sweet.
Brandon2k13 is offline   Reply With Quote
Old 03-21-2014, 03:07 AM   #39
cannonbuilt
Member#: 272859
Few days ago had a chance to weld up the different wire and hose inlets that go trough the fire wall
Also had to extend the steering column outlet cause the bushing would not fit
Old 03-21-2014, 03:13 AM   #40
cannonbuilt
Member#: 272859
Old 03-26-2014, 11:59 PM   #41
cannonbuilt
Member#: 272859
Welded the support on yesterday
Old 03-27-2014, 01:26 AM   #42
cannonbuilt
Member#: 272859
First coat I put on the welds was a fiberglass based filler,( fiberal-Upol ) it helps seal any pin holes that I might have missed. Sanded that down
Then I put a coat of light weight filler, in other words (bondo)
..........waiting for it to dry........
Old 03-27-2014, 01:25 PM   #43
Aww_hail
Member#: 353893
2013 WRX
wrb
Originally Posted by cannonbuilt View Post
Had an idea to delete the gas cap door and weld it up and put it in the trunk but having second thoughts. Proly be dripping gas from the nozzle everytime unto the carpet
From experience: don't do that. Great looking build thus far. Looks like you are making some really good progress.
Aww_hail is offline   Reply With Quote
Old 03-28-2014, 05:03 PM   #44
cannonbuilt
Member#: 272859
Sanded down the welded areas , next is scuffing the whole engine bay area and support, get it ready for paint
All scuffed up ready to be taped up , then will go grab some paint . 🏃
Old 03-28-2014, 11:12 PM   #45
cannonbuilt
Member#: 272859
Ready for paint, degreased the whole engine compartment , sprayed some adhesion promoter and bout to mix some sealer
Old 03-29-2014, 12:23 AM   #46
cannonbuilt
Member#: 272859
Sealer mixed with paint is on , moving on to paint
Midnight black pearl
Old 03-29-2014, 02:40 AM   #47
cannonbuilt
Member#: 272859
Done, looking good
Old 03-29-2014, 11:18 AM   #48
Gixhost
Member#: 180111
* 2004.114.3 STi
Subscribed!
Gixhost is offline   Reply With Quote
Old 03-30-2014, 02:12 AM   #49
cannonbuilt
Member#: 272859
This is where the abs was sitting at originally . Buddy came over and helped me delete the abs ( weight reduction ) lol Bought some T splitters and brake line
Old 03-30-2014, 02:17 AM   #50
cannonbuilt
Member#: 272859
Always fun to peel that tape off and reveal what's underneath
Also we went ahead and threw the engine in after we installed the brake lines
