Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 02-20-2014, 02:01 PM   #1901
Maxwell Power
Member#: 190729
he's not sending it to Dan.
Maxwell Power is offline   Reply With Quote
Old 02-20-2014, 02:03 PM   #1902
Wolfie_OBXT
Member#: 364484
2006 OBXT
I must have missed something? At any rate, how are things moving along?
Wolfie_OBXT is offline   Reply With Quote
Old 02-20-2014, 02:34 PM   #1903
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
I dropped the block at local machine shop were they will deck the faces.
They had a better straight edge tool that showed less gaps, my ruler was very bad test example.
I'm going to have crank polished and just trow everything back together. Might get new ring set will see.
Bariga is offline   Reply With Quote
Old 02-20-2014, 02:50 PM   #1904
Wolfie_OBXT
Member#: 364484
2006 OBXT
What head studs are you going to use and any plans for O rings?
Old 02-20-2014, 04:07 PM   #1905
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
nah **** orings, i use map h11 kit
Old 02-20-2014, 09:36 PM   #1906
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
So other than decking is the local machine shop going polish the crank and put the motor back together??
If yes why not send it to Dan or MPS?
Old 02-20-2014, 10:49 PM   #1907
Wolfie_OBXT
Member#: 364484
2006 OBXT
Really, what makes you say that?
Old 02-20-2014, 11:20 PM   #1908
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Will be shipping the block back to benson. Video Link: http://www.youtube.com/watch?v=vUxbo8JqF_Q
Is that rust on the sleeves? You running straight water or any coolant?
Old 02-21-2014, 10:23 AM   #1909
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
I actually ran Evans waterless coolant that was proven not to rust any internals.
As far as engine i will be assembling it, every time i have to pay for it anyways mind as well learn to do it my self.
Old 02-21-2014, 11:14 AM   #1910
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
I actually ran Evans waterless coolant that was proven not to rust any internals. As far as engine i will be assembling it, every time i have to pay for it anyways mind as well learn to do it my self.
Good idea. Proven under who's standards? Lol
Old 03-14-2014, 01:54 PM   #1911
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Got almost everything ready, block was cleaned and surfaced, heads were cleaned inspected and also surfaced, crank got polished.
Replacing all bearings, piston rings and piston pins.
Will start assembling after finals.
Old 03-17-2014, 10:52 AM   #1912
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Sick!! Looks like you'll have a nice spring break project!
wgr73 is offline   Reply With Quote
Old 03-27-2014, 04:54 PM   #1913
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
almost ready..
I am staying with 7670 turbo, installing Flex fuel sensor and probably will be upgrading from ID1000 to ID1300 injectors.
Old 03-27-2014, 06:12 PM   #1914
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Whats with the ricer engine mounts and valve covers
Old 03-27-2014, 06:44 PM   #1915
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
relax your jaws, don't forget to cup on the balls
Old 04-07-2014, 03:38 PM   #1916
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
got my flex fuel sensor working, showing 9% with pump gas
need to pick up some e85 and start tuning it.
Going to make boost map per Ethonol %, so with **** gas ill run 20 psi with 60% and up 25 psi +
Old 04-07-2014, 04:02 PM   #1917
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
This sounds awesome! What are you currently using in terms of software for flex fuel tuning? I'm setting up a 15 STi tonight for flex! Using RaceRom for it.
STi Mikey is offline   Reply With Quote
Old 04-07-2014, 05:50 PM   #1918
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Are you going to use an overlay fuel and ignition map? ethanol % vs ethanol temp
Old 04-11-2014, 11:13 PM   #1919
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
right now made 4d overlay fuel map Ethanol % vs MAP, added e85 made 50% mix.
Right now 4d map is straight line starts from 10% - 0 units to 50% - 25 units
Domenic is going to send me map of how he tunes e85 and vipec, so far i enjoy stink free exhaust
Old 04-16-2014, 02:10 PM   #1920
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Pics from my rebuild.
Old 04-16-2014, 02:10 PM   #1921
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Old 04-16-2014, 02:22 PM   #1922
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
Looking fresh! magnesium valve covers?
jnorth85 is offline   Reply With Quote
Old 04-16-2014, 07:49 PM   #1923
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Break it in and turn it up Anton!! E85 FTW!
Old 04-16-2014, 08:05 PM   #1924
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
as of now at 20 psi I'm at 75% duty.
So I hope getting ID1300's and bumping base pressure to 50 will give me good head room with walbro e85 pump?
Old 04-16-2014, 08:30 PM   #1925
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Hey B, is your fuel pump hardwired? What pump you running now?
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 634 06-11-2016 02:34 AM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
