Old 01-24-2014, 10:57 AM   #226
EVL RS-T
Member#: 30071
2001 RS-T
2015 XT
Originally Posted by BlueToRed View Post
I know this question isnt a 06 to 02 drivetrain swap question but its related i want to do an 08 sti drivetrain swap into my wrx 08 sedan and the question here is if i swapped said drivetrain and trans in would i also have to the differential adjuster by the shifter??
If you don't install the DCCD controller, the center diff will default to a specific torque split (F/R)... For 04-05 this was 35:65, and for 06+ this was 41:59... so the 06 drivetrain will utilize the more balanced (41:59) torque split.
EVL RS-T is offline   Reply With Quote
Old 01-24-2014, 11:34 AM   #227
BlueToRed
Member#: 362319
2008 Subaru WRX
WRB Stage 2+ & WRB 13 STI
Exactly the answer i wanted thank you very much
BlueToRed is offline   Reply With Quote
Old 01-28-2014, 02:51 AM   #228
ASAPboxly
Member#: 380017
Can someone confirm if this is correct for a swap into a 2008 WRX:
TY856WB7KA JDM IMPREZA WRX STI MY06 + S204 - 3.9 FD
- with shift linkage, clutch slave,
A/t or modified STI driveshaft
08 WRX R160 Differential - 3.9 Gear Ratio
08 WRX axles, starter, clutch and flywheel (recently replaced, would like to use it till it's done for)
I would prefer to stay at 5x100 due to the multiple sets of wheels and current BBK setup on the vehicle.
What would have to be replaced to use the 08 WRX clutch assembly? Also, do the JDM v9 DCCDs maintain a 41:59 split without a controller, just like their USDM counterpart?
ASAPboxly is offline   Reply With Quote
Old 03-02-2014, 02:03 PM   #229
buz445
Member#: 383314
buz445 is offline   Reply With Quote
Old 04-06-2014, 11:00 PM   #230
tersplat
Member#: 337888
2003 WRX Wagon
Just got done with my weekend 6 speed swap from an 06 STI into my 03 WRX wagon! It was a lot easier to get the 5 speed out, than fit the 6 speed in. It is definitely a lot tighter in there now. I really hope I am going to be able to change the clutch without pulling the transmission out when the time comes like I could with the 5 speed. I will be wiring in the DCCDPro tomorrow or Tuesday. It feels great! The ratios threw me off a little bit, and I'm still trying to get the hang of putting it in reverse instead of 6th... Thanks for the DIY!
tersplat is offline   Reply With Quote
Old 04-22-2014, 06:42 PM   #231
WrXwAgOnWrB
Member#: 269631
05 9-2x
Dark Blue Metallic
I need help on my 04 FXTi swap. I have or had the 4AT and an STi motor in the car. I bought the whole 2004 six speed STi swap, Brembo brakes, axles, cross-members rear 180 diff ect... I plan on using my stock A/T drive-shaft I have my FXT lowered on WRX struts.
Now I have a fully built 2.5l complete long block ready to attach to the six speed. I have a 2004 Hydra ECM and a complete 2004 STi harness MPH Prodrive gauges. No DCCD but I may decide to hook it up later via Spiider DCCD pro.
My question is I need to maintain the Anti-lock brakes by using the A/T harness? Or I may be able to use certain parts of the STi harness. I am stuck on how to wire the 6speed into the car. Maybe unplug the A/T from the stock harness and plug in the M/T.
Please help If possible.. I hope
WrXwAgOnWrB is offline   Reply With Quote
Old 07-02-2014, 03:10 PM   #232
big606
Member#: 395203
Default 07 wrx to 06 sti 6pd
im doing a swap on my 07 wrx trying to get everything I need so I can get the car back going as soon as possible I been trying to find place to buy after market dccd controllers only been able to locate one not wanting anything to fancy just something reasonably priced....
big606 is offline   Reply With Quote
Old 07-02-2014, 05:01 PM   #233
EVL RS-T
Member#: 30071
2001 RS-T
2015 XT
MapDCCD.com
Old 07-04-2014, 03:57 PM   #234
Subifantastic
Member#: 381700
dccdpro universal in my opinion. No bells and whistles, easy to install and tons if
online help as it has been around a long time.
Subifantastic is offline   Reply With Quote
Old 08-12-2014, 10:22 PM   #235
asuito
Member#: 398909
Default Help needed!
Hello, I own a 04 wrx and I just build a new 2.5L engine with cams pistons a 20g turbo and all the supporting mods. My car is not a USDM spec so I need more info in what I will need for a transmission upgrade because I think its not going to last long. My transmission code is TY754VN5AA and my VIN code is JF1GDALD34G054052. Could you give me some options to upgrade my transmission so it handles 400 awhp?
asuito is offline   Reply With Quote
Old 08-13-2014, 01:28 PM   #236
toph
Member#: 78640
14 KTM SuperDuke
15 STi CWP | 02 STi Wagon
I have a question that I am having a hard time finding answers to:
I have a full GR drivetrain (tranny, hubs, knuckles, brakes axles) and would like to piece together a swap into a GD. Is there a way for the GR knuckles, axles, diff etc to mount up? What do you do for a suspension setup? Not much information out there about this (maybe my googling isn't up to snuff). I have seen Xluben use 5x100 hubs, but I have 5 sets of 5x114 wheels plus many of the parts, going the 5x114 route would be more cost effective right now.
toph is offline   Reply With Quote
Old 09-09-2014, 04:21 AM   #237
ewudude121
Member#: 401130
Default automatic to Manuel
so im trying to convert my auto wrx into a 6speed and im not really sure what to start with or what exact things to buy and what can be some parts i can put in from the parts that it has now to the new set up
ewudude121 is offline   Reply With Quote
Old 09-27-2014, 08:27 AM   #238
cuztomimportz
Member#: 97904
I haven't seen or found anything about this so I figured I'd ask here. I am finishing up my V8 6-speed swap into my 02 wrx. I am using the trans, driveshaft, r180 rear with stock wrx axles up front and hybrid axles in the rear to retain my stock hubs for now. So far everything is installed except for the hybrid axles because i have to order the races for them. That said when i was putting the front axles onto the axles stubs that came with the transmission....I noticed that only the passenger side stub has a hole for the roll pin from my wrx axles.....the driver's side does not have this hole to accept a roll pin.
Is this normal.....is it safe to run with no roll pin?
cuztomimportz is offline   Reply With Quote
Old 10-05-2014, 09:45 PM   #239
WrXwAgOnWrB
Member#: 269631
05 9-2x
Dark Blue Metallic
Unless it clips in you don't want your axle floating back and forth on the trans spline.
Sent from my iPhone using NASIOC
Old 02-09-2015, 06:07 PM   #240
Osakel2013
Member#: 413104
Default Dont mind me
I just havr to make 3 real post lol dont mind me sorry
Osakel2013 is offline   Reply With Quote
Old 09-14-2015, 07:45 AM   #241
Titter
Member#: 416107
2002 WRX Wagon
EJ 207 Spec C 4EAT
Originally Posted by Cyclops View Post
Optional stuff:
STI Lower control arms (need FSB and endlinks also) - Paid $150 for the LCAs and another $140 for a Whiteline 27mm FSB and $50 for Whiteline endlinks
STI Lateral links (need RSB and endlinks also) - Paid $140 for the lateral links and $50 for Poltec rear endlinks
good stuff man! just wanted to add that im pretty sure that these "optional" things are mandatory for 02 wagon owners who want to swap to 6 speed. dont have to be STI but they need to be sedan length not OE wagon length
Titter is offline   Reply With Quote
Old 01-14-2016, 10:03 PM   #242
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
I have a 02 wrx and have a 06 mt. How do you plug in the vss? The plug goes on but not enough to latch. The sti's have the plug on the chassis not a pigtail like the wrx. What gives?
Old 01-23-2016, 10:52 PM   #243
scby rex
Member#: 104878
02 wrxbastardchild
Nevermind, my donor gearbox had the inner retainer from the plug stuck in the vss.
Old 04-25-2016, 08:43 PM   #244
trjames82
Member#: 432986
So I've read a few of these forums on here and other websites and I'm probably more confused now then when I started. I'm wanting to put a 6 speed in my 02 wrx. With the r180 diff. What confused on is it looks cheaper to do an 04 swap cause the best I can see you can use the wrx struts and spring and front axles where the 07 swap requires everything from struts to hubs to all the axles but in one thread it sounds like the 04 won't work with the r180 and the next thread says it will. Will some answer this for me and correct anything I have said that's wrong I'm likely just misreading something.
trjames82 is offline   Reply With Quote
Master swap list for 04-07 Sti 6 speed into WRX crashtke Transmission (AT/MT) & Driveline 808 08-12-2015 09:01 AM
Feeler: 06 wrx sti 6-speed drivetrain swap... 06TRDude Drivetrain 8 02-23-2009 07:50 PM
Cost estimates for 6-speed swap into an 02 WRX? aasim_a Transmission (AT/MT) & Driveline 24 05-31-2008 04:37 PM
Parts needed for an STI drivetrain swap into an 01 RS SubeSTIle Subaru Conversions 15 11-04-2006 01:11 PM
Parts needed for an STI drivetrain swap into an 01 RS SubeSTIle South West Impreza Club Forum -- SWIC 2 10-31-2006 04:15 PM
