Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 04-24-2014, 10:26 AM   #1
ShadowWRX13
Member#: 374574
2004 wrx
Default fp hta68
i just recently purchased an hta68 and i'm looking to rebuild it. does anyone here know of a decent rebuild kit for them? they look like they're about $50 on ebay and a few other places but i dont want to get anything really cheap and i wasnt sure if anyone knew if theres any differences.
ShadowWRX13 is offline   Reply With Quote
Old 04-24-2014, 05:51 PM   #2
rexblake
Member#: 178426
2010 S4
Gray
Call Forced Performance. They can point you in the right direction.
Old 04-25-2014, 11:42 PM   #3
SCwrx85
Member#: 340328
04 WRX
Agreed.
And honestly unless you are extremely experienced with turbo overhaul i would not suggest this. Typically parts of the rotating assembly are replaced during rebuild and the assembly must be rebalanced. Truly anytime the turbo is disassembled it should be rebalanced before assembly. Once the rotating assembly is balanced it is then marked and taken apart for reassembly into the CHRA. This step is absolutely critical to get it exactly were it was marked. If not the turbo will fail...quickly. Unless you are extremely familiar with this process i would not undertake it.
And on another note a reputable overhaul kit should run at least 100 dollars. These are literally the heart of your turbo...do you really want to trust that to crap you bought off ebay?
SCwrx85 is offline   Reply With Quote
