Old 04-24-2014, 11:54 PM   #1
mrc808
Member#: 155622
Default arc catch can
do you guys have any idea how to install an ARC oil catch can in a WRX..pics would be nice..or is it the same like the prova AOS..is there any inlet and outlet of those two hoses or i can use either one for outlet or inlet..lmk thanks
mrc808 is online now   Reply With Quote
Old 04-25-2014, 01:36 AM   #2
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
Brother EddieJ. is offline   Reply With Quote
Old 04-25-2014, 01:37 AM   #3
Brother EddieJ.
Member#: 181617
2004 wrx
Btw it's not arc specific it's general Wrx catch can install.
Old 04-25-2014, 02:18 AM   #4
mrc808
Member#: 155622
Thanks for the info but I'm asking about the ARC catch can cause maybe they make it different from the other catch can
Old 04-25-2014, 03:15 AM   #5
Brother EddieJ.
Member#: 181617
2004 wrx
It has an inlet and outlet? You need vacuum to make it work? Catch cans are the same theory. The internal filters or elements may be different. Oil separators (grimmspeed, Crawford) are a different ball game.
Old 04-25-2014, 03:35 AM   #6
mrc808
Member#: 155622
thats my problem bro..i don't know which one is inlet or outlet on the two tube…or both can be inlet n outlet….
Old 04-25-2014, 07:07 AM   #7
danger1138
Member#: 279525
04 rex luger!
Post a pic of your catch can. I think i the "nipples" are side to side they can be used either way, interchangeable, either one could be vacuum. In my setup, one nipple to attach the hose is right above the other, not side by side, & instructions clearly say that the port being used for vacuum (on my setup) is the bottom one.
danger1138 is offline   Reply With Quote
Old 04-25-2014, 07:21 AM   #8
Brother EddieJ.
Member#: 181617
2004 wrx
Post a pic. I found a few different versions.
Old 04-25-2014, 12:14 PM   #9
mrc808
Member#: 155622
I'll try to post pics. But my catch can is the universal version. It has two nipples that close together
Old 04-25-2014, 01:39 PM   #10
mrc808
Member#: 155622
Old 04-26-2014, 01:52 AM   #11
mrc808
Member#: 155622
bump…any idea….help…..
Old 04-27-2014, 10:30 PM   #12
mrc808
Member#: 155622
Any ideas how to install my universal ARC catch can. Is there inlet or outlet on those two nipples. Help pls..
Old 04-28-2014, 04:37 AM   #13
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
The time you've spent trying to get an answer you could've installed and troubleshot if it was working correctly. Or you simply could sell it as you do not need a catch can.
Old 04-28-2014, 07:59 AM   #14
vogun16
Member#: 93206
02 WRX....
JDM V7/8/9 RA-R Rotated
It probably doesn't matter which port you use.
vogun16 is offline   Reply With Quote
Old 04-28-2014, 08:11 AM   #15
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Left is inlet.
Right is outlet.
Unless it doesn't work right. Then:
Right is inlet.
Left is outlet.
Old 04-28-2014, 10:36 AM   #16
mrc808
Member#: 155622
Originally Posted by Psychoreo View Post
Left is inlet.
Right is outlet.
Right is inlet.
Left is outlet.
Did you have this catch or installed this catch can before..
Old 04-28-2014, 10:42 AM   #17
Psychoreo
Member#: 79643
2015 WRX STI
Nope.
But those are the only two ways to install it. Just go install it and drive around for a week. If it gets stuff in it, you did it right. If not, switch the lines. It's not going to hurt anything.
Old 04-28-2014, 11:23 AM   #18
mrc808
Member#: 155622
Nope.
Ok thanks....
