Old 04-25-2014, 11:05 PM   #1
bl0wnb0xerbabiE
Member#: 121722
2006 Impreza WRX tr
Obsidian Black
Default 06 2.5l WRX + Steamspeed Hybrid STX td05h-GTX2867 (Garrett) - 416whp/399lb-ft
Event: Custom Dyno tune
Ambient Temp: 74 degrees Fahrenheit
Elevation: 100 ft above sea level
Weather: Blue and Clear
Tires: Dunlop Sport Maxx 225/45/17
Car: 2006 Subaru WRX
Tuner: Ed at Equilibrium Tuning
Dyno Info: Graphs for both Dynojet and Mustang below
Transmission: Stock 5 speed
Gear: 3rd
Peak HP at RPM: 416.6 whp at 6600rpm SAE corrected
Peak Torque at RPM: 399.6 lb-ft at 4050rpm SAE corrected
Baseline hp/tq for a stock on same dyno: Stock STI runs 210-220whp on the mustang dyno
Target Boost: 19 psi
Target AFR: 10.7
Fuel: Piss poor Cali 91 octane
Engine/Power Modifications
- Steamspeed's hybrid STX td05h-Garrett GTX 2867 journal bearing turbo - 8cm housing w/ 2.4 inch inlet - ported turbine and wastegate - IWG - Billet 11 blade compressor wheel and lightweight 9-blade turbine wheel
- KS tech 73mm CAI
- Walbro 255h fuel pump
- Greddy Evo catback exhaust
- Invidia 3 inch catless downpipe w/ DEI titanium wrap with high temp silicone coating
- Unknown brand uppipe w/ DEI titanium wrap with high temp silicone coating
- Tomei UEL
- PTP Turbo blanket
- Cusco heatshield
- Motive Autowerks TGV deletes
- Hallman Pro MBC
- Ebay BIG TMIC
- Block off plates
- Air pump delete
- Grimmspeed turbo inlet
- DW 850cc injectors
Driveline Modifications:
- ACT heavy duty clutch
- Streelight flywheel
- Perrin lightened crank pulley
- Kartboy short shifter
- Kartboy shifter bushings
Suspension and other modifications:
- Whiteline front fixed swaybar
- Whiteline rear adjustable swaybar
- Helix endlinks
- Hawk HPS brake pads
- Eibach Camber bolts
- STI rear strut tower bar
- STI powder coated black BBS rims 17 x 7.5
- Tein H tech springs
- aftermarket shocks
- Group N front tophats
- Greddy turbo timer
- Greddy shift knob
- STRI boost and oil pressure gauges
Soon to be...
- Grimmspeed TMIC splitter and shroud
- DEI Reflect-A-Gold wrap on heatshields, TMIC, and intake
- Hot coat UEL headers
- then maybe exterior mods yada yada..
Big thanks to Ed @ Eqtuning for a great tune. Him and his team were amazed and completely surprised at the power output of this turbo. We were originally going to go with the AEM CAI but the turbo was maxing out the MAF readings so we had to go with the KStech big maf intake. We also had to go with a slightly softer wastegate spring. Money well spent and the car pulls like a champ, especially up top.
I would have liked to have seen slightly faster spoolup but the amount of power mid to high more than makes up for it. The current wastegate seems to hit 18 psi and slowwwllllyyy get up to 19 psi. Ed believes that with an EWG, this turbo would "shiiinnnee." Our power expectations were surpassed and then some. I highly recommend this turbo (Garrett GTX compressor) to anyone looking for 20g typer power levels.
Below is the Dynojet graph:
And the more realistic Mustang dyno numbers:
bl0wnb0xerbabiE is offline   Reply With Quote
Old 04-26-2014, 12:22 AM   #2
Equilibrium Tuning
Member#: 26933
2006 STI
I was extremely impressed with this turbo. This kind of power on 91 octane combined with such great spool is unheard of. They need a little refinement on the wastegate port and actuator and this is going to be an all out killer turbo. Can't wait to see it on e85.
-- Ed
Old 04-26-2014, 12:30 AM   #3
Back Road Runner
Member#: 60082
2004 Forester STI
What do you suggest for the wastegate modifications based on seeing this turbo? I'm curious because I'm putting one in this weekend and am curious about your input. Mine will be on E85, but I'm limited to an APS 65mm intake and 1000cc injectors for the moment for peak, and I'm pushing both on my 18G.
Also I'm curious what the difference is between the Dynojet and Mustang. Do you actually have two dynos there, or is this merely a software thing? Also your labeling says engine hp and engine torque. Is this a converted estimate or just a label but still wheel numbers?
Old 04-26-2014, 12:31 AM   #4
NA STI
Member#: 285083
2006 STi
Those numbers and curves are very nice, especially for 91oct.
Im a little confused on this hybrid turbo thoe... what makes it a gtx2867 if it dosnt even use a gt28 turbine? Also if it used a legit gtx67 compressor wheel it wouldnt have 11 blades.
NA STI is offline   Reply With Quote
Old 04-26-2014, 01:31 AM   #5
Back Road Runner
Member#: 60082
2004 Forester STI
You're curious why it's 11 blades vs 10 blades I assume. You might want to ask Steamspeed about the reason. I could only make guesses. It's also a bit of blur with various sites stating both 10 and 11 blades for various options. For example, the GTX2863 is supposed to have 11 blades, but you'll find sites indicating both 10 and 11. The GTX2867 is supposed to have 10 blades, and again you'll see sites indicating both 10 and 11. I've also seen pics of the compressor wheels labeled as the GTX2863 and GTX2867 with 10 and 11 blades. So...what's right? I can't tell you. I don't know what's a typo and what's not. I also don't know what's a genuine Garrett compressor and what's an equal compressor blade profile but made by another company. For example, Kinugawa has GTX2867 compressor wheels. Guess what? They're 11 blades. This may also be a ball bearing vs journal bearing debate. For example, if you bought CHRA ball bearing GTX2867, you might have a 10 blade compressor wheel. However, if you bought a journal bearing version, maybe Garrett doesn't make a real version, so a manufacturer like Kinugawa steps in a makes an 11 blade version that fits the journal bearing application. I'm not really sure. At the end of the day, I don't really have an answer for you. My guess is that if you went the ball bearing route, you'd probably end up with a 10 blade version. If you did not go the ball bearing route, you probably have an 11 blade version with the 11 blade version being made by someone else, still billet and same blade profile. That'd be my guess, but it's a complete, blind guess based on zero fact or information to back it up. Again, ask Steamspeed if you want an answer.
Old 04-26-2014, 06:05 AM   #6
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
Is it a bit disingenuous to label this as 416whp when there's also an apparently legitimate reading of 354whp? 62whp ain't chicken feed.
Old 04-26-2014, 08:52 AM   #7
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
Very Nice to see another one of these on the dyno. I need to get my STX67 equipped fxt back on the rollers soon.
Great job tuning Ed!
rexworx is offline   Reply With Quote
Old 04-26-2014, 09:08 AM   #8
HooliganSTi
Member#: 161608
2004 WRX Wagon
PSM V8 STi swapped
Nice numbers! I just installed my STX71 this makes me happy...
HooliganSTi is offline   Reply With Quote
Old 04-26-2014, 09:54 AM   #9
bilt2run
Member#: 134211
very nice..It looks to make more power then the gtx3071 that Ed tuned a while back!! this thing should rock on corn
bilt2run is offline   Reply With Quote
Old 04-26-2014, 10:01 AM   #10
HooliganSTi
Member#: 161608
2004 WRX Wagon
PSM V8 STi swapped
I'd hardly call posting the results for two different types of dyno being disingenuous. If anything it being upfront. The differences in readings between the two types are well known and usually reflect what's shown above with the DJ reading a good bit higher. Varies by machine but nothing new here....
Old 04-26-2014, 10:49 AM   #11
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Yeah but real question is what type dyno is this? That should be the only dyno plot posted, not hypothetical numbers. There is about 15% difference in the numbers but in reality these type of dynos don't vary that much in real world unless you are refering to old school mustang dyno which is rarely used anymore. Sure most say dynos are only tuning devices but in reality hp and trq has exact definition that most dyno calibrations don't reflect the same results.
I thought it was funny how the dynojet numbers was listed in thread title but he post that mustang are the more realistic.
bswilmington is offline   Reply With Quote
Old 04-26-2014, 06:41 PM   #12
bl0wnb0xerbabiE
Member#: 121722
2006 Impreza WRX tr
Obsidian Black
Originally Posted by bswilmington View Post
Yeah but real question is what type dyno is this? That should be the only dyno plot posted, not hypothetical numbers. There is about 15% difference in the numbers but in reality these type of dynos don't vary that much in real world unless you are refering to old school mustang dyno which is rarely used anymore. Sure most say dynos are only tuning devices but in reality hp and trq has exact definition that most dyno calibrations don't reflect the same results. I thought it was funny how the dynojet numbers was listed in thread title but he post that mustang are the more realistic.
good point but the 418whp graph reading isn't some fake number that we made up; this is a legitimate graph just like the mustang is.
The reasoned I posted both numbers is 1) I had them 2) transparency 3) to show that dyno numbers are ALL relative. For all I know, maybe my car is actually putting out 375whp; there's know way to determine that but you can narrow it down by using different measuring calibrations, dynos etc. for the same setup on the same day. I personally believe that the car feels closer to 354whp but the 418whp comes from a Dynojet calibration which is what many people post on here anyways so I decided I would put it. So putting up both was meant to simply highlight that the dyno number is just a number without multiple comparisons; it's the area under the curve that is the most significant and I am very pleased.
My car smacks hard past 3800rpm and I can daily drive it around town without boosting at lower rpms. =D
Old 04-26-2014, 07:42 PM   #13
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
Looks solid. Good luck with that stock 5sp, I popped two after hitting these torque levels. Both shaved 3rd gear almost completely off.
VladiWrX is offline   Reply With Quote
Old 04-26-2014, 08:01 PM   #14
bl0wnb0xerbabiE
Member#: 121722
2006 Impreza WRX tr
Obsidian Black
eek. How were u driving when u broke it?
Old 04-26-2014, 08:28 PM   #15
bswilmington
Member#: 217563
Originally Posted by bl0wnb0xerbabiE View Post
good point but the 418whp graph reading isn't some fake number that we made up; this is a legitimate graph just like the mustang is. The reasoned I posted both numbers is 1) I had them 2) transparency 3) to show that dyno numbers are ALL relative. For all I know, maybe my car is actually putting out 375whp; there's know way to determine that but you can narrow it down by using different measuring calibrations, dynos etc. for the same setup on the same day. I personally believe that the car feels closer to 354whp but the 418whp comes from a Dynojet calibration which is what many people post on here anyways so I decided I would put it. So putting up both was meant to simply highlight that the dyno number is just a number without multiple comparisons; it's the area under the curve that is the most significant and I am very pleased. My car smacks hard past 3800rpm and I can daily drive it around town without boosting at lower rpms. =D
I understand your point. But what type of dyno is it? Doesn't appear to be DJ, so it would assume that is made up calibration and isn't the real calibration the dyno is set up for. I've never seen dyno that could post whatever dyno model numbers you request. It must be self made calibration that is suppose to resemble DJ #s. If that is the case then it is made up number and I would stick with the correct calibration that the dyno manufacture put into the computer.
Your graph shows roughly 15% difference in numbers but in reality mustangs and DJ now have closer to 5% difference. It is what it is, and I do understand your view point. Sorry I'm just stickler for real world numbers and I think DJ have got a bad name with people trying to show crazy numbers specially when made up correction factors are made to "resemble" a dyno that it even isn't. But I love DJ cause when you use real one on SAE correction it gives what I believe is real world numbers that auto manufactures come up with. (Yes I know manufactures rate at crank before someone tells me). For example my 381 hp tundra did 313whp on DJ which is 18% power train loss which is believeable for 4x4 on 32" tires when truck was in 2wd. Stock sti does 240whp and is rated 300hp which equals 20% power train loss, , which to me is believeable for car in AWD with heavy drivetrain components.
Sorry for the rant. I just hate to see DJ get make believe numbers cause everyone already thinks they read till the moon, but all mustang numbers are always the lowest. In reality the mustang numbers that are posted are possibly higher than DJ numbers.
Old 04-27-2014, 04:57 AM   #16
northman
Member#: 163631
07 Forester XT
Dom 1.5XT-R
All the BS aside, that Mustang graph looks nice. 350 whp, and peak torque before 4,000 RPM is not too shabby.
northman is offline   Reply With Quote
Old 04-27-2014, 06:26 AM   #17
A-man07
Member#: 271525
07 STi
You should edit the thread title to reflect both numbers. That was my point, otherwise it looks like "false advertising."
Surprised no one has pointed out the real way to tell how much power you're making is 1/4 mile times.
Old 04-27-2014, 11:08 AM   #18
Equilibrium Tuning
Member#: 26933
2006 STI
The dyno is a Dyncom brand chassis dyno. The "dynojet" calibration is how the dyno reads out of the box. I use a .85 CF to make it read like my road dyno software which happened to read just like the older mustang dynos.
On the mustang calibration, stock 08+ STI's put down 195-205whp. At these power levels I would expect to see 116-117mph traps.
-- Ed
Old 04-27-2014, 04:45 PM   #19
Back Road Runner
Member#: 60082
2004 Forester STI
I like curve shapes more than I like raw numbers. This should flow like a 20G, so I would expect to see a peak HP slightly higher than peak TQ. In this case, this is what we see. The raw number is whatever it will be. It's hard to quantify that without a direct comparison of other setups on the same car and on the same dyno. The other rough option is to know what base cars do like Ed provided. A STI putting down 195-205HP is rather conservative, so a high reading at such a configuration will also be conservative. 340TQ and 355HP would then be pretty conservative values, and the car is realistically doing a little bit better. Now 340TQ at 19psi seems high, but I'm used to smaller numbers a thousand feet up. Plus excellent efficiency can mean excellent torque. I'll actually have my GTX2867 in today sometime and will get to start playing around with it a little, zero WG to start and then tweaking during the week. Maybe I'll see some unusually (for me) high torque numbers per boost level. Who knows, lol. I'm just hoping it will stomp my 18G over the whole curve.
Old 04-28-2014, 12:07 AM   #20
Equilibrium Tuning
Member#: 26933
2006 STI
Just to give a comparison, 20g's and ATP GTX3071's usually do about 325-330whp on 91 on the mustang calibration. Hitting 350whp on 91 on this calibration is very tough. I hope this is standard for this turbo and not just a fluke because that is seriously impressive power!
-- Ed
Old 04-28-2014, 04:27 AM   #21
Back Road Runner
Member#: 60082
2004 Forester STI
This turbo does seem to flow well up top, definitely a healthy bump up from my 18G, holds 24psi (E85) flat to 7k and moves 50 g/s more air. Mine's in and running, but I think I've got a leak to hunt down first unfortunately. High boost spool-up is quite...delayed...at the moment (worse than OP and I've got the smaller 7cm^2 hotside), not sure why yet. It'll produce low boost (2-5psi) slightly better than the 18G near 2k rpm but then ramp up oddly slow for no apparent reason. The responsiveness and early positive pressure seem to indicate more bottom end potential, but something's stopping me. I'm guessing a leak somewhere, so I gotta snug down some clamps and see if things improve.
I'm pretty impressed by the dynamics/transient behavior. The 18G's a reasonably quick turbo, not 13T-TD04 fast, but quick in its own right. The GTX2867 is noticeably quicker and a healthy step towards the transparently quick TD04. The low inertia bits show their worth pretty well. I'm looking forward to more quality time with it to really feel it out.
Old 04-28-2014, 09:03 AM   #22
rexworx
Member#: 103232
GTX 3071R'd 11WRX
-- Ed
How did you feel lag and response is compared to a 20g etc? When did it hit full boost and and any issue holding it out to higher rpm? What rpm did you start the pull at? Seem like it would have quite a bit more in it with E85 Id assume.
Old 04-28-2014, 11:49 AM   #23
subaru_gc8
Member#: 29292
2004 WRX wagon
im sold on this turbo
Old 04-28-2014, 04:30 PM   #24
spdracerut
Member#: 269226
FYI, genuiene Garrett 67mm compressor is 10-blade and the 63mm is 11-blade. All of the Garrett GTX wheels are 11-blade except the 67mm.
spdracerut is offline   Reply With Quote
