Old 04-25-2014, 03:19 PM   #8501
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Originally Posted by seanathanq83 View Post
Till after I tune it and you decide you want more power
How is the S256 on your EJ207 ?
Gigs90 is offline   Reply With Quote
Old 04-25-2014, 03:29 PM   #8502
iconone
Member#: 174883
135i 05 CGM WRX
2006 Yamaha R1
this is true. Hopefully this set up will put me where I want to be. Probably not but we shall see.
iconone is offline   Reply With Quote
Old 04-25-2014, 03:44 PM   #8503
iconone
Member#: 174883
135i 05 CGM WRX
2006 Yamaha R1
That was an extremely fun set up on his car. Check out my YouTube page for videos.
Old 04-25-2014, 06:10 PM   #8504
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
I'll be in my bunk
Old 04-25-2014, 09:08 PM   #8505
sube-trex
Member#: 97577
2001 IS 300
Thanks. I'm going to go with a 18g xt or xt-r.
sube-trex is offline   Reply With Quote
Old 04-27-2014, 02:47 PM   #8506
2JZ
Member#: 291949
Where is the PCV in a version 8 motor? Is this the PCV (under the throttle body connected by a black hose that leads go a gray y fitting)? Will the wrx part # work? Id like to replace this.
http://imgur.com/URSXLdz
Because I've also seen the PCV attached to the y pipe in some USDM cars.
2JZ is offline   Reply With Quote
Old 04-28-2014, 08:18 PM   #8507
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
go pro footage of my car. loving the go pro and new tires
https://www.youtube.com/watch?v=lwGM...ature=youtu.be
mrxr250rider is offline   Reply With Quote
Old 04-28-2014, 08:29 PM   #8508
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
What BPV is that ?
Old 04-28-2014, 08:42 PM   #8509
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
forge with red spring
Old 04-29-2014, 07:39 AM   #8510
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
yes and yes
use a 02-03 wrx pcv.
Old 04-29-2014, 09:27 AM   #8511
AWDBoost
Member#: 33082
V7 EJ207
Prodrive GDB
Just bought my V7 engine from jdmracingmotors. It has a upgraded Tomei arms M7760 turbo. Engine has complete harness ..
AWDBoost is offline   Reply With Quote
Old 04-29-2014, 09:51 AM   #8512
kornfeld
Member#: 252586
2005 Saab 9-2x Aero
V9 EJ207, Stock Int/Exh
Here's the wrx PCV assembly and part number:
On my V9, this was definitely not present. It just has a regular metal PCV valve that threads into the intake manifold.
kornfeld is offline   Reply With Quote
Old 04-29-2014, 09:59 AM   #8513
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
This is the wrong PCV assembly for 2JZ's car. Note the PCV in the T fitting and the sensor plug.(which isn't used with the 207 ecus).
Old 04-29-2014, 10:22 AM   #8514
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Well that's kinda awesome that it comes with a small 20g !
Old 04-29-2014, 11:13 AM   #8515
AWDBoost
Member#: 33082
V7 EJ207
Prodrive GDB
Yes I asked Robert and he says that it has stock injectors .. So I'm thinking I should get me a set of 850's
Old 04-29-2014, 11:26 AM   #8516
kornfeld
Member#: 252586
2005 Saab 9-2x Aero
That was my point...his original question was if the WRX part works or not. His car is an 05, so I posted the part number for the 05 PCV assembly, which won't work for him (as far as I know).
The later edit you added about using an 02 or 03 PCV was the missing piece of info.
Last edited by kornfeld; 04-29-2014 at 12:26 PM. Reason: PCV, not PCV valve; edit made by the department of redundancy department
Old 04-29-2014, 12:24 PM   #8517
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
The later edit you added about using an 02 or 03 PCV valve was the missing piece of info.
I don't know how you saw he has an 05 from his profile or post.
He could buy that pass through fitting and get the 05 wrx part to work. It would just look like an octopus with that useless sensor unplugged and flapping around
Old 04-29-2014, 12:30 PM   #8518
kornfeld
Member#: 252586
2005 Saab 9-2x Aero
We're on another forum together...we both have a Saab 92x.
He should just go with the regular metal valve that threads into the intake manifold, I think we're in agreement on that! :thumbsup:
Old 04-29-2014, 12:56 PM   #8519
2JZ
Member#: 291949
Thanks for the information guys. I pulled the part number from opposed forces but wanted to be sure.
How's your swap running Kornfeld?
Old 04-29-2014, 12:56 PM   #8520
2JZ
Member#: 291949
Old 04-29-2014, 01:13 PM   #8521
kornfeld
Member#: 252586
2005 Saab 9-2x Aero
Good. My replacement intercooler showed up this past weekend, so I need to install that. I just haven't had a chance to do so for the last few days. Hopefully I can finish with getting it tuned now.
Aside from that, I've just been tying up a few odds and ends. I've got a leaking thermostat, so I need to get that pulled back apart and fixed.
Old 04-30-2014, 09:28 AM   #8522
1MOFOSTI
Member#: 375748
04 STi
Just Finished playing around on the Dyno ....
POWER - 441WHP / 432WTQ
- Engine v8 EJ207
- Boost 25 PSI
- Injectors size -1000cc Top feed
- Injector duty cycle - 80%
- Elevation -100ft
- Turbo-FP RED
- Fuel E90
- Dual Walbros 255's
The clutch has 20% left on it if im lucky, so wouldn't be surprised if it hit just over 450WHP once i install the Twin plate.
Attached Dyno sheet is the 2nd Pull. 433WHP. Car ended up making 441WHP / 432WTQ
EJ207 POWER!!!
1MOFOSTI is offline   Reply With Quote
Old 04-30-2014, 09:33 AM   #8523
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
What did you pay for the motor if you don't mind me asking? Also, you should just pony up for ID 1k's, even if you don't run E85.
Subian is offline   Reply With Quote
Old 04-30-2014, 10:00 AM   #8524
AWDBoost
Member#: 33082
V7 EJ207
Prodrive GDB
Originally Posted by 1MOFOSTI View Post
Just Finished playing around on the Dyno .... POWER - 441WHP / 432WTQ - Engine v8 EJ207 - Boost 25 PSI - Injectors size -1000cc Top feed - Injector duty cycle - 80% - Elevation -100ft - Turbo-FP RED - Fuel E90 - Dual Walbros 255's The clutch has 20% left on it if im lucky, so wouldn't be surprised if it hit just over 450WHP once i install the Twin plate. Attached Dyno sheet is the 2nd Pull. 433WHP. Car ended up making 441WHP / 432WTQ EJ207 POWER!!!
Now thats some serious power! Congrats
Old 04-30-2014, 10:01 AM   #8525
AWDBoost
Member#: 33082
V7 EJ207
Prodrive GDB
$4400 includes avcs harness and the Tomei turbo
