Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Old 04-14-2013, 12:10 PM   #776
TIGWERKS
Member#: 256615
Texas is great so far. Working on some killer stuff out here and have a lot of stuff coming up. It's a great change both in work place and living. Was a much needed and refreshing change from California.
If you guys decide to go with clamshell clamps I have all the cad files for the weld ferrules and have some extra clamps here as well I think. If you know where to look they are pretty damn cheap compared to the $300 usual cost.
TIGWERKS is offline   Reply With Quote
Old 08-20-2013, 12:59 PM   #777
benit0
Member#: 202204
02 WRX
just finished this setup. Stock location turbo.
benit0 is offline   Reply With Quote
Old 08-20-2013, 01:18 PM   #778
gotsugg
Member#: 204014
02 02 WRB Bugeye
GTX3582 front mount turbo
^^^ More pics
gotsugg is offline   Reply With Quote
Old 12-16-2013, 07:52 PM   #779
funk32
Member#: 245787
2004 STi
question for people that have done this or know about rads. Are you able to use a normal type rad and just put it into a V mount configuration? I can't see any pics with fill points/rad caps on the rads, would this cause issues?
thanks
funk32 is offline   Reply With Quote
Old 12-16-2013, 09:30 PM   #780
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
Ill try to post mine... I have had great sucess with in 110 degree heat
shilohb is offline   Reply With Quote
Old 12-19-2013, 02:47 PM   #781
ivanismyname
Member#: 278829
2004 STI
JBP
looks great ^^^^
ivanismyname is offline   Reply With Quote
Old 12-19-2013, 09:05 PM   #782
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 539/421
Is anyone making a alternator relocation kit still?
A Fatal Ode is offline   Reply With Quote
Old 12-20-2013, 06:26 PM   #783
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
I told myself that I wouldn't get back into the game but I might start a v-mount build again on my new chassis. It'll go onto my 07 STi if I decide to go for it. It'll be far different than my last approach. It was... let's call it a learning experience. haha
arco is offline   Reply With Quote
Old 04-11-2014, 09:56 PM   #784
sysfailur
Member#: 135993
08 AW STi GTX3071
V-Mount, 18x12, 335 R888
thanks
The long story short is, not really... you can but it won't be very clean. I have seen one person do it and imo it looked stupid.
If you're intersted in doing it I recommend a Mishimoto (or other brand) MR2 radiator. The inlet/outlet are both @ a 45 degree angle up so tilting it 45 degrees means now it's straight out the back. We were going to hose it directly in/out of the block on each side but the fittings were so huge EVERYTHING needed modification lol
This is -20AN:
sysfailur is offline   Reply With Quote
Old 04-12-2014, 11:09 AM   #785
TIGWERKS
Member#: 256615
The system can be tricky bleed all the air out with out fill caps or some kind psi relief valve to help bleed the system. I had to use a combo of a coolant system psi and the fill funnel with several rotations of both to bleed the coolant system.
Easiest way i think to do it, is make a radiator from scratch. Its about the same cost.or less than buying a radiator and then having to modify it. .build it how you want it from the start
Old 04-12-2014, 12:08 PM   #786
smitty5788
Member#: 267886
2011 STI
Should be finishing up this one in the next couple weeks. Anyone going to Road Atlanta the weekend of may 9th can see it in person. Ill try to come back in here and post a completed picture. Feel free to ask any questions about the setup.
smitty5788 is offline   Reply With Quote
Old 04-12-2014, 01:41 PM   #787
acheung
Member#: 118389
Got a v mount fmic core if anybody is looking or interested! Great deal on it too!
acheung is offline   Reply With Quote
Old 04-14-2014, 11:48 PM   #788
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 539/421
which core?
Old 04-15-2014, 01:00 AM   #789
acheung
Member#: 118389
The good kind... Process west!
Old 04-29-2014, 12:27 AM   #790
sysfailur
Member#: 135993
08 AW STi GTX3071
I realize wires are a mess but here ya go... she's fabbed up 98%. A few little supports here and there but nothing major still needed.
More pics here... newest stuff is on the bottom.
Old 04-29-2014, 09:39 AM   #791
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 539/421
looks good man. what kind of driving do you do? i'm curious because of the size of the core...
Old 04-29-2014, 10:27 PM   #792
hummelsubaru
Member#: 220153
'05 WRX JBP WFC#207
GTX3076 ViPec V44
^would you redo the wire sysfailur?
hummelsubaru is offline   Reply With Quote
Old 05-12-2014, 11:56 PM   #793
sysfailur
Member#: 135993
08 AW STi GTX3071
Workin on it! Wiring will be done Tues/Wed.
It's a response build... intercooler core can handle 942CFM which is plenty Auto-x, ripping around, and track days.
Old 05-17-2014, 12:43 PM   #794
smitty5788
Member#: 267886
2011 STI
Nearly finished with this one:
Old 06-05-2014, 06:43 PM   #795
verentchan
Member#: 355749
2008 WRX
Silver/Black
smitty5788, what intercooler and radiator are those and what are the dimensions? I think I'm gonna try something similar on my v-mount build.
verentchan is offline   Reply With Quote
Old 06-06-2014, 02:43 AM   #796
smitty5788
Member#: 267886
2011 STI
The kit was a joint effort between us and Nameless performance. Give them a call and ask for Jason, tell him Pat said to call about the v-mount setup. They have made two other kits I believe, all a little different. Ours was the first one built. It has room for a precision 5858 that is mounted below the radiator. One of the others was on a matte green hatch that was for sale on here a while back.
The radiator is double pass, I think the later kits used CNC machined end tanks and were actually triple pass. I will grab the dimensions when I get back to the shop in the morning.
Old 07-22-2014, 01:53 PM   #797
funk32
Member#: 245787
2004 STi
quick test fit of rad and IC
Edmonton-20140722-00306 by Funk32, on Flickr
Edmonton-20140722-00307 by Funk32, on Flickr
Old 09-10-2014, 03:33 AM   #798
crick.ru
Member#: 374023
Greetings from Russia
To be continued...
crick.ru is offline   Reply With Quote
Old 09-28-2014, 12:53 AM   #799
funk32
Member#: 245787
2004 STi
Edmonton-20140921-00432 by Funk32, on Flickr
Edmonton-20140925-00459 by Funk32, on Flickr
Edmonton-20140925-00458 by Funk32, on Flickr
AND she is all welded up now
Edmonton-20140929-00482 by Funk32, on Flickr
Old 10-29-2014, 08:54 PM   #800
arco
Member#: 57156
2007 V.8 207 STi
any new developments in regards to what people do to replace the AC condenser?
The Ultimate Auxiliary Lighting and Mount Thread Rapid_Roo Electrical & Lighting 6764 Yesterday 05:42 PM
Brembo Caliper mounting threads slightly stripped what to do? dogfrndnew Brakes, Steering & Suspension 31 03-31-2013 12:20 PM
FS : CUSCO Engine Mounts xdrian Engine/Power/Exhaust 6 06-20-2010 09:37 PM
Group N transmission mount threads JBravo920 Transmission (AT/MT) & Driveline 5 10-28-2007 11:17 PM
aftermarket seat mounting thread aspera Motorsports 8 12-05-2003 11:27 PM
