Old 04-26-2014, 12:05 PM   #3151
93tilinfinity
Member#: 388891
Great thread, thanks for all the information guys!
Looking at going to 18x8.5 +38 on 235/40/18. Seems like I will be 21 mm closer to the fender in terms of the rim per the 1010 wheel calculator. However, since the tire is what will actually contact the fender and not the wheel, it seems like I need to lower this number since I'm not going larger in tire width vs stock. I'm just not sure what adjustment is required. Initially I was just ignoring the change in rim width, (which would mean 15mm poke) but I'm guessing thats not correct... Also, once I have that number (call it tire poke?) is there a general rule of thumb for how far one can push the tire outward before a roll is required?
I really hope I didn't mess this post up.
93tilinfinity is offline   Reply With Quote
Old 04-26-2014, 12:08 PM   #3152
sc00by4life
Member#: 97135
Originally Posted by 93tilinfinity View Post
Great thread, thanks for all the information guys! Looking at going to 18x8.5 +38 on 235/40/18. Seems like I will be 21 mm closer to the fender in terms of the rim per the 1010 wheel calculator. However, since the tire is what will actually contact the fender and not the wheel, I need to lower this number since I'm not going larger in tire width vs stock. I'm just not sure what adjustment is required. Also, once I have that number (call it outward tire poke) is there a general rule of thumb for how far one can push the tire outward before a roll is required? I really hope I didn't mess this post up. Thanks!
Asking those kinds of questions means you shouldn't worry about finding a lower offset.
Throw the wheels on the car and enjoy it.
Old 04-26-2014, 12:13 PM   #3153
Ruzty1311
Member#: 311911
2012 WRX Limited Sdn
SWP (TP Stg 2)
You looked way too far into it lol You'll be fine with that setup....no roll required
Ruzty1311 is online now   Reply With Quote
Old 04-26-2014, 01:52 PM   #3154
93tilinfinity
Member#: 388891
Awesome, thanks guys!
Old 04-26-2014, 02:42 PM   #3155
Turtlefart
Member#: 320054
18x9.5 +38 Enkei RPF1, 255/35/18 Nitto NT555.
Stock suspension, fenders not rolled with absolutely no rubbing.
Turtlefart is offline   Reply With Quote
Old 04-26-2014, 05:24 PM   #3156
Studmike02
Member#: 220095
'95 MX-5
18x9.5 E38 Rota Gforces2 with 255/35/18 Federal 595 RS-R tires, rear fender rolled. Lowered on BCBR Coilovers.
Grassy WRX by Mjbrownell02, on Flickr
Studmike02 is offline   Reply With Quote
Old 04-26-2014, 07:05 PM   #3157
Ruzty1311
Member#: 311911
SWP (TP Stg 2)
There's one or two things happening here...
Either A) You don't weigh much and you haven't hit any BIG swooping type bumps like on a freeway or highway....hell...even a steep driveway or cross section at high speeds.
B) You don't ride with anybody in the car that weighs over 200lbs
This is pretty misleading for those looking for info because 99% of the time with your setup (this is my exact setup besides different brand tires) you WILL rub at some point or another ESPECIALLY when you decide to lower the car though in this instance is somewhat irrelevant because we're talking stock height
I advice anyone going for this setup to roll your rear fenders!
Old 04-26-2014, 09:18 PM   #3158
Turtlefart
Member#: 320054
I'm not misleading anyone. I'm 6'3" and 220 lbs and I have had another 200 lb guy in the car on a ****ty back road with lots of bumps. No rubbing. I don't know what else to tell you. Sorry you rub? If you read this whole thread there are multiple people with this setup and they don't rub. Some do. So to be safe, yes roll the rears.
Old 04-26-2014, 09:24 PM   #3159
greencb7
Member#: 350765
Enkei RPF1's 18x9.5" +38 running Bridgestone RE760 265/35/18, set -2 camber front and back. Rear fenders rolled and sitting on feals.
greencb7 is offline   Reply With Quote
Old 04-28-2014, 12:24 PM   #3160
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
anyone have RSR that are driving in the rain? i'm looking at RE760's also. i might go with comp 2's again even though they arent the greatest in the rain.
looking at 265/35/18
i know RSR tread pattern is very aggressive just wanted some input. want sticky tires but with the weather thats been going on its iffy.
JAMM0N is offline   Reply With Quote
Old 04-28-2014, 02:44 PM   #3161
Ptown_finezT
Member#: 308190
2012 wrx hatch
dgm,2010 swp legacy prem.
RE760 are good all around. I love them.
Ptown_finezT is offline   Reply With Quote
Old 04-28-2014, 05:28 PM   #3162
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
tough decision. stretch or flat with face. i still have to camber. i'll see what 255's look like and work my way from there.
265's have a minor stretch and 275's almost look flush with the wall. decisions decisions. *cough* battle wagon ^_^
Old 04-28-2014, 06:35 PM   #3163
bilingham
Member#: 388451
2014 WRX hatch
Default Does the steering change much?
It sounds like a set of 17x9 +45 RPF1s with reasonable width tires will fit well. My question is how is the steering feel affected? I would hate to mess up the fine handling of the stock set up on my new 2014 WRX.
bilingham is offline   Reply With Quote
Old 04-28-2014, 06:42 PM   #3164
Digitalwave
Member#: 321857
On stock suspension you wouldn't notice much difference. It depends on the tire you go with, really.
Digitalwave is offline   Reply With Quote
Old 04-28-2014, 06:46 PM   #3165
bilingham
Member#: 388451
2014 WRX hatch
Probably a 255/40/17 pilot A/S 3
Old 04-28-2014, 06:47 PM   #3166
Digitalwave
Member#: 321857
If anything the steering will be slightly heavier and with a 255 you might get more tramlining on the grooves of the road, but it won't be a dramatic differences.
Old 04-28-2014, 06:50 PM   #3167
sc00by4life
Member#: 97135
The 17x9 rpf1's weigh significantly less than stock.
Old 04-28-2014, 06:53 PM   #3168
Digitalwave
Member#: 321857
I'm not talking about wheel weight, but the effort needed to turn the 255's. Like I said, barely any difference.
Old 04-28-2014, 06:59 PM   #3169
bilingham
Member#: 388451
2014 WRX hatch
I ran staggered RPF1s for 10 years on my 350z, fantastic wheels from the function standpoint. Their appearance my not be as contemporary as some popular wheels, but they are about as light and strong as you will ever find. Many pounds lighter than the factory 17x8s.
Old 04-28-2014, 07:15 PM   #3170
sc00by4life
Member#: 97135
In terms of friction?
Because is imagine the rpf even with a 255 weighs less than stock.
Old 04-28-2014, 07:20 PM   #3171
Digitalwave
Member#: 321857
Friction/contact patch.
Old 04-29-2014, 12:46 PM   #3172
bilingham
Member#: 388451
2014 WRX hatch
Now that you have driven this wheel/tire set up for some time, what do you think? Is there anything you would change or do differently?
Originally Posted by AkursedX View Post
Thank you for the help that you guys have provided me in this thread. Here is the result. 17x9 et45 Enkei RPF1's with Falken FK453 Tires in 255/40/17. Stock ride height. No rubbing.
(pardon the dirtiness of the car)
Old 04-29-2014, 09:47 PM   #3173
b5rks
Member#: 280634
15 STi
ISM
Originally Posted by slide View Post
2013 STI Hatch
Wheels: Gram lights 57DR 18x9.5 38 mm offset
Tires: 255/35/18 star specs
Suspension: stock
Rears rub on compression from big bumps at speed. Other than that no rubbing. I will get pics up soon (need to upload to photobucket still)
Pics would be awesome. I am thinking about running this setup on my 2015. Did you consider running 265 instead of 255?
b5rks is offline   Reply With Quote
Old 04-29-2014, 09:52 PM   #3174
Ruzty1311
Member#: 311911
SWP (TP Stg 2)
Why would he even consider running 265's? 255's fit perfect on that setup
Old 05-02-2014, 07:00 PM   #3175
Grownman
Member#: 379638
Originally Posted by obZen View Post
This thread REALLY helped me out when I was looking for a summer wheel setup. Here's my current setup:
Specs:
Enkei NT03-m | 18x9.5 | +40 | 5x100
Michelin Pilot Super Sport 265/35zr18
Rear fenders rolled, front fenders untouched
Suspension is stock, no rubbing anywhere. Currently don't have plans to lower.
How flush do the wheels sit? Do you have more pictures?
Grownman is offline   Reply With Quote
