Old 04-30-2014, 12:13 PM   #1
jdmshocker
Member#: 194422
2004 WRX Wagon
Default 18x10 gd wrx wagon
Not sure where to post this, but i figured I could post it here so future newbs like me can find this thread . So lets get started!
So first off I will be making 18x10 +25 offset fit on my 04' wrx wagon. No sedan front end, but possibly 280zx/240z fender flares or jetta mkii flares. Fortune auto 500's. Spacers (not sure how big) extended wheel studs and lug nuts. TIRES! .....And of course fender pull and roll
On to some pictures I took today, definitely the issues i have read up on with this size and offset. I don't even know if spacers will help much for clearance.
Fronts look like they will rub on the coilovers when I get them...
Certain that the tire will rub on the trailing arms on the rear.
Ahhhhh yesss....the poke haha....I don't like the "sunken, super duper negative camber stance" We'll see if I make this work with not too much negative camber and the flares. I don't plan to slam the car hopefully 1 finger gap or none?
No turning back now
looks like it'll rub on my bumper too :/ hrmmmm
jdmshocker is offline   Reply With Quote
Old 04-30-2014, 01:05 PM   #2
jdmshocker
Member#: 194422
2004 WRX Wagon
Well doing some more research i feel like i bit off more than i can chew....i wont give up though!
Old 04-30-2014, 01:18 PM   #3
Tire Rack Moderator
Member#: 1215
ext. 4362
good luck ... looks like a pretty huge undertaking
Luke@tirerack is offline   Reply With Quote
Old 04-30-2014, 01:54 PM   #4
jdmshocker
Member#: 194422
2004 WRX Wagon
I'm going to need luck haha. Placing an order on the coilovers today or tomorrow. Next would be tires.....not sure on size. Seems some people are even fitting 235/40/18 on 10's I need to find some pictures of how stretched that will be.
Old 04-30-2014, 01:58 PM   #5
JohnnyZ91
Member#: 377110
2004 Wrx STI
Haha damn bro, this is a monster undertaking.
JohnnyZ91 is offline   Reply With Quote
Old 04-30-2014, 02:06 PM   #6
jdmshocker
Member#: 194422
2004 WRX Wagon
I guess the biggest "inspiration" behind this i have rear quarter panel rust. So i figured what the hell, lets cover it with a fender flare and fit some wide wheels? haha
Old 04-30-2014, 04:07 PM   #7
JonnyV2889
Member#: 197384
2006 WRX Ltd
I got some sedan rear quarters sitting at the house for this exact project. Looking to stuff a more reasonable 17x9 35-40. Good luck. Depending on what you chose for rubber. I had 18x9 +29 under my previous sedan w 235/40 star specs. There was just a slight stretch, add an inch to that
JonnyV2889 is offline   Reply With Quote
Old 04-30-2014, 05:24 PM   #8
jdmshocker
Member#: 194422
2004 WRX Wagon
Maybe 245/40's or 255/35 is what ill research on. I have been talking to some people on fortune auto's, still not certain on what spring rate I want to go with. 9k/8k f/r was what i was thinking.....any suggestions.
Well looking on FA's site they come default with 8/6 k's wonder if 9/7k wouldnt be too bad especially if i plan on getting into autoX
Old 04-30-2014, 05:32 PM   #9
sc00by4life
Member#: 97135
Maybe 245/40's or 255/35 is what ill research on. I have been talking to some people on fortune auto's, still not certain on what spring rate I want to go with. 9k/8k f/r was what i was thinking.....any suggestions. Well looking on FA's site they come default with 8/6 k's wonder if 9/7k wouldnt be too bad especially if i plan on getting into autoX
How are the dampers? You shouldn't need a spring that stiff.
Mann engineering/JRZ/other high end shock manufacturers sometimes go as low as 4k/4k.
If you're doing flares, you should run a proper sized tire.
Before you start modding you need to decide if you plan to be competitive in autocross or not. Read the rulebook for the class you plan to compete in. Especially if you are a total newbie....you should be learning in a stock car or else you will most likely develop bad habits.
Old 04-30-2014, 07:07 PM   #10
jdmshocker
Member#: 194422
2004 WRX Wagon
Definitely do not plan to get competitive just some weekend fun.
Old 04-30-2014, 08:43 PM   #11
vicious_fishes
Member#: 158864
2003 SOHC destroker
is that first picture with strut clearance etc at +25?
Old 04-30-2014, 09:00 PM   #12
Wirtz
Member#: 286408
WFC #952
Function:error!
10 wides on stock suspension loloololol and you're surprised you're having clearance issues haha sorry
Wirtz is offline   Reply With Quote
Old 04-30-2014, 09:09 PM   #13
jdmshocker
Member#: 194422
2004 WRX Wagon
I knew I would I'm not running wheels with stock suspension. It was a test fit to see what I need to do.
Old 04-30-2014, 09:22 PM   #14
jdmshocker
Member#: 194422
2004 WRX Wagon
Yes and that was with the shock compressed. I wanted to see how much clearance I had. It's very doable.
Old 05-01-2014, 03:42 AM   #15
vicious_fishes
Member#: 158864
2003 SOHC destroker
intredasting. so an 18x10 +40 or whatever would have the WHEEL hitting against the strut
stock camber bolts at negative or positive?
Old 05-01-2014, 08:17 AM   #16
jdmshocker
Member#: 194422
2004 WRX Wagon
car is completely stock now
Old 05-01-2014, 10:39 AM   #17
sc00by4life
Member#: 97135
intredasting. so an 18x10 +40 or whatever would have the WHEEL hitting against the strut stock camber bolts at negative or positive?
Stock suspension most likely yes. All the camber is happening at the hub which is shoving the wheel towards the strut.
With coilovers and camber plates you can adjust the stock camber bolts full positive and then use camber plates/lateral links to achieve the desires camber.
Old 05-01-2014, 11:23 AM   #18
lub
Member#: 343218
2004 WRX wagon
I ain't mad at this...carry on.
lub is offline   Reply With Quote
Old 05-01-2014, 12:36 PM   #19
vicious_fishes
Member#: 158864
2003 SOHC destroker
this was exactly why i was asking. plates negative, bolts positive = more (at least, inboard) clearance.
Old 05-01-2014, 01:17 PM   #20
jdmshocker
Member#: 194422
2004 WRX Wagon
thanks for the information, i need to definitely figure the camber issue once everything i get everything ready. So far i have the coilovers on order should be here in 3-4 weeks. Ordered some jetta flares. Stuck on tires.....245/40/18 is probably going to be too much of stretch for me i think. I am now leaning towards the 255/35/18...nankang ns-20 will be around 400 for all 4. I had 18x9 with 245/40/18 on my previous evo 8 and those seemed to be a perfect fit... :/
Old 06-08-2014, 08:13 AM   #21
ngv41
Member#: 332471
2005 wrx wagon
Obsidian black
I have 18x10 on my 05 wrx wagon
ngv41 is offline   Reply With Quote
Old 06-08-2014, 08:27 AM   #22
ngv41
Member#: 332471
2005 wrx wagon
Obsidian black
I have BC BR coilovers with front and rear camber plates and front and rear camber bolts. For the front, I only needed to max out the camber plates and trim the fender liners so it doesnt rub. Oh and no rubbing against front bumper. For the rear... I almost spent two weeks to make them rub less. Both rear camber plates and camber bolts are maxed out, no rubbing on coilovers (it barely clears), rear quarters need to be pulled a lot, rear bumper needs to be trimmed to avoid cut on edge of the tires, and there is a some kind of bracket that holds the rear bumper and I had to cut out that bracket. Right now it still rubs but its not that bad. I drove mine to all the way to the Wisconsin Milwaukee with no problem. Let me know if you have more questions
Old 06-08-2014, 10:57 AM   #23
jdmshocker
Member#: 194422
2004 WRX Wagon
Could you post pictures! I ordered 255/35/18 . What offset are your wheels? What camber bolts are you using? Thanks a lot =]
Old 06-08-2014, 04:27 PM   #24
sc00by4life
Member#: 97135
A 255 is going to require a ****load of work.
Look up subK's wagon. He's gone through several different 9.5-10" widths.
Old 06-08-2014, 04:54 PM   #25
Andrewxxcarlson
Member#: 316415
2006 WRX
Interested.
Andrewxxcarlson is offline   Reply With Quote
