Old 11-24-2012, 12:55 PM   #676
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
I've done a bunch of reading in this thread, and I'm a noob. Can someone explain what overlap means?
Jubert69 is offline   Reply With Quote
Old 11-24-2012, 03:40 PM   #677
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
"Overlap" refers to the period of time, near the end of the exhaust stroke and the beginning of the intake stroke, when the intake and exhaust valves are open at the same time. For the exhaust valves, this is right before they close. For the intake valves, this is right after they have opened.
It might be counter-intuitive at first, but a carefully tuned amount of overlap can yield more power than no overlap at all. The lumpy idle that muscle-cars have with big cams is a side-effect of a relatively large amount of overlap. At higher RPM it's a good thing, but at idle it behaves like your intuition would lead you to expect - the motor pulls in some exhaust during the intake stroke, and combustion suffers.
With adjustable valve timing, we can tune the overlap to occur only in the conditions where it's actually helpful, so we get the increased volumetric efficiency in the midrange, but without the lumpy idle.
Old 11-24-2012, 03:57 PM   #678
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Hear me out on this, let me know if I need to clarify.
0 AVCS = Acts like Small Cams
20-30 AVCS = Acts like Bigger Cams
So around low loads, you want little to no overlap, which is low AVCS and higher loads want more AVCS because of overlap?
Old 11-24-2012, 09:37 PM   #679
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
Focal Active Setup
Not really. It does not work like that. Unfortunately, it is not that simple. The muscle car example was just an illustration of how overlap can affect an engine. In our case, it really depends on the scenario. Load is just one axis. You also have to consider RPM. Some low load situation call for fair amount of overlap to produce internal EGR effect which yields better fuel economy and lower emissions. In high load situations, you typically do not want lots of overlap because the positive pressure on the intake side will force the charge into the chamber and the engine does not rely heavily on scavenging to improve volumetric efficiency. I say typically because the exhaust side also influences this and depending on what you're running there, the overlap requirement may change. The more flow you can get on the exhaust side, the more you might be able to use overlap to improve VE.
Ziggyrama is offline   Reply With Quote
Old 10-24-2013, 02:42 AM   #680
jasaircraft
Member#: 219110
Hi Ziggyrama
If you had to switch intake only avcs (because wiring wise and time mandate it) in an on/off manner (lets agree off is 0deg and on in 30?)
How would you switch it? rpm or load based? of use both axis?
jasaircraft is offline   Reply With Quote
Old 10-24-2013, 03:57 AM   #681
khalonen
Member#: 145460
2003 European STi
SC40 billet
Originally Posted by jasaircraft View Post
Hi Ziggyrama
If I had to choose 1, I would take RPM. Just because for relatively small turbo sizes that majority of Subarus use, exhaust backpressure is high at upper RPM range, say above 5000. You dont' want overlap there.
khalonen is offline   Reply With Quote
Old 10-24-2013, 02:32 PM   #682
jasaircraft
Member#: 219110
so basically avcs on (advanced) from 1500 till 5000 and off (retarded) at idle and above 5000.. right?
could I have any issues with valves touching themselves with kelfords 272 both 11.3 in and 10.7ex
Old 10-24-2013, 03:15 PM   #683
Clark Turner
Member#: 178047
02 WRX STI Spec C
Do not try to switch 12 volts to the solenoids. You will destroy the valves and likely the engine. The system is meant to be a closed loop system with pulsed 12 volts PWM.
Clark Turner is offline   Reply With Quote
Old 10-24-2013, 11:13 PM   #684
jasaircraft
Member#: 219110
hi clark, pwm either the 12v or the earth signal should result the same as the other pin should have a constant... Right? I checked with the stock ecu 12v is constant and earth is pwm.
100%duty cycle is a constant pulse will move the cams how many degrees? 30?
So if I where to physically lock the cams 30 deg advanced I could see if they touch each other, I have no issue with piston as they are the deep carved type instead of the stock flats.
Old 10-24-2013, 11:56 PM   #685
Clark Turner
Member#: 178047
02 WRX STI Spec C
I am aware of how the system works. What you are suggesting is what we all tried 10 years ago and it will burn out the solenoids and with your cams, the valves will hit. But by all means try it out.
Old 10-25-2013, 06:49 AM   #686
Ziggyrama
Member#: 53665
Focal Active Setup
That will not be optimal by any means. 30 degree advance between 1500 and 5000 RPMs will give you OK drivability around town but high load scenarios will leave power on the table. Your fuel economy will also not be so good. Not sure what you're trying to do but be aware that you're trying to make it something it wasn't meant to do.
Old 10-25-2013, 11:26 AM   #687
jasaircraft
Member#: 219110
Whats up with the attitude?
Anyways, we decided to let the system off as the car will be mostly drag racing... About the solenoids burning... Maybe in the long run...
We'll perform the test locking the pulleys in the most advanced position and turning the engine by hand, using fiber optics see how close they get
Old 10-25-2013, 11:29 AM   #688
jasaircraft
Member#: 219110
Thanks ziggygrama
So basically the advance is good for low to mid rpms at low load sites but not good on the higher load sites, which gives a good idea of how the map should look like.
Old 10-26-2013, 11:03 AM   #689
Spec C
Member#: 77737
2003 spec C
This could be worth a look
http://forums.nasioc.com/forums/show...1475616&page=3
Spec C is offline   Reply With Quote
Old 10-28-2013, 12:29 PM   #690
Clark Turner
Member#: 178047
02 WRX STI Spec C
I don't have an attitude at all. You asked and I told you what would happen. You have aftermarket cams and they will hit in my experience. Even if you did this and you had cams that would not hit, this would not be worth it. You need proper closed loop control. Sounds like you are new to all this. But this has been tried many many many times on Stand alones and the results where destroyed engines or poor performance. If the car is a drag car, rip AVCS off the car. It would never be active anyways.
Old 11-16-2013, 05:00 PM   #691
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
Since the last build, I've had problems with my avcs working properly, My left side intake is only coming up to 4 to maybe 6* max, the passenger side comes up to 25 or so, I believe we were going for 30-35 though, during the last removal I saw the cam gear probably wasnt cared for enough while removing the bolts for timing belt removal, My best guess right now is saying its one of the upper (intake) cam gears, but at 150 a piece Id like to know for sure, motor is out right now, Ive had my new kelford cams inspected, swapped avcs solenoids with a working sti's, made sure no filter where in banjo's
Id like to know for sure what it is, I tried everything I could while it was in the car, short of changing cam sensors
Thanks in advance CAR IS AN 04 STI USDM (SINGLE AVCS)
Irv Weissmanhowerton is offline   Reply With Quote
Old 05-03-2014, 11:30 AM   #692
roadtrip1098
Member#: 185688
2006 STi
WR Blue
Maybe I'm resurrecting the thread here, but I had a friend with an 04 STi same issue with cam advance. It ended up being one of the screens in the banjo bolts having been sucked into the oil line and impeding flow. You may want to check that if you haven't already.
roadtrip1098 is offline   Reply With Quote
Old 05-03-2014, 01:44 PM   #693
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
filters are a known culprit
we had a car with odd avcs behavior, where one side was really late to advance untill 3000 rpm
ended up being faulty cam gear, fyi
Hyper is offline   Reply With Quote
Old 05-03-2014, 05:41 PM   #694
SeeeeeYa
Member#: 129681
2017 FXT-T ES
SBM
Not possible. Someone told you a story.
For one, there is no "suck" on that line, only pressure. Secondly, there is not enough flow to push that screen out of the bolt... ever look at it? Even if it gets completely blocked all it does is impede flow.
That screen is going nowhere.
SeeeeeYa is offline   Reply With Quote
Old 05-09-2014, 05:35 AM   #695
roadtrip1098
Member#: 185688
2006 STi
WR Blue
A story? It was a friends car, but we pulled the screen out in my garage. It had deteriorated to the point where it fell apart. Part of it was in the bolt, part of it was in the solenoid.
You say that there is no suck, just pressure. By the very definition, sucking results from pressure. For example, a vacuum creates a low pressure in it's tank, which than sucks air in.
I'm just trying to help the OP here in letting them know that the little screens are known to cause AVCS issues.
Old 11-16-2014, 04:44 PM   #696
jegvd
Member#: 406469
good thread for discussion...
jegvd is offline   Reply With Quote
Old 11-20-2014, 03:58 AM   #697
throttlehappy
Member#: 313497
2016 STi FA20DiT
Yellow
Have also seen the screen filter collapse under pressure and oil pressure pushed it into the cam gear
throttlehappy is offline   Reply With Quote
Old 11-26-2014, 12:19 AM   #698
Subbie subba
Member#: 407166
Would that work on older models?
Subbie subba is offline   Reply With Quote
Old 01-11-2015, 10:29 PM   #699
macster9090
Member#: 410700
2002 wrx hatch
blue
so i used to have a profile on here guess it got deleted.
anyways my ej205 bugeye went BOOM.
long story short i got a jdm ej205 45k miles avcs along with full wire harness and ecu.
being that i dont have emissions i am going to swap the ecu to jdm, guess ive got to sell my cobb tuner.
what type of problems might i run into? ive read the ecu for this on my car is plug and play so i just have to reroute the wire harness?
who or what is my best tuning option? and will i still be able to use the ob2 connector to read codes ect.?
i plan on doing a right up on the process it takes me as soon as my nubie restrictions are lifted and i can start a thread. thx
macster9090 is offline   Reply With Quote
Old 01-15-2015, 10:30 PM   #700
thesupatuna
Member#: 411024
Default jdm avcs maps
The Jdm V8 st mapping is a lot more aggressive then the usdm
thesupatuna is offline   Reply With Quote
Let's talk hybrid economy / performance tuning Bad Noodle Open Source Reflashes 17 04-29-2012 09:30 PM
Let's talk flywheels WRXThis Transmission (AT/MT) & Driveline 9 04-17-2002 02:04 PM
Let's talk about when to change out the rods. Andrew Normally Aspirated with bolt-on Forced Induction Powertrain 10 03-04-2002 11:44 AM
Let's talk amps.... Teh Legacy Car Audio, Video & Security 15 10-19-2001 02:09 AM
Let's talk about the Rimmer Supercharger rao General Forum Archive 88 09-21-2000 07:56 AM
