Old 07-05-2013, 10:15 PM   #1
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Default What to do? What would you do?
I have a 1994 impreza 1.8 with an auto. This is my beater! I use this car for hauling parts, going fishing, going in the woods, mudding and whatever I don't want to use my nice cars for. I have lots of parts so I can't decide high compression 2.5, turbo the 1.8, wrx swap or whatever. Should I leave the auto or install a 5spd? What would you do? I already have a forester xt and a wrx so it is just a fun car I don't want to make this a race car.
Old 07-05-2013, 10:26 PM   #2
Blktrax
Member#: 220971
2002 WRX 213K Mi.
Original Motor and Turbo
One word:
Tracks
http://www.americantracktruck.com/
Because F-YEA!
Blktrax is offline   Reply With Quote
Old 07-05-2013, 10:36 PM   #3
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Those trax are really cool I have a friend with some but that wouldn't work for my everyday stuff.
Old 07-06-2013, 12:42 AM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
For that being a 94, a simple EJ25D swap would be super easy, relaible and add roughly 55HP at the wheels. That'd be my suggestion. Not as much work as a turbo kit, though folks have successfully boosted EJ18s with little to NO extra engine management.
Keep the auto if it still shifts alright. For a beater, it's kind nice to drop it in D or 1 to crawl around berms or rutty trails.
Jay
Old 07-06-2013, 02:18 AM   #5
subi400
Member#: 216984
1996 Impreza outback
Green
I love my hybrid higher compression 2.5 block and phase 1 2.2 heads with the original steel borla single port header . Has pad style and hla rocker assembly for the heads with the delta 230 hp cams in it and with the heads combustion chambers widened to match the 2.5 bore.
I like it because it feels like a stroker and it just pulls all the way to 6500 redline (ej25d NA ecu) in 2nd, while 3rd is where I really notice it. 1st gear is pretty crazy...
For you, if you wanted to experiment I would do this:
-ej251 NA shortblock in good condition
-phase 1 dual port exhaust 2.2 heads (slightly widen the combustion chambers to match the 2.5 bore) with the roller rocker and solid adjuster assembly so you can run the delta 200 torque grind cams
-Obx equal length header or borla uel knock off and a decent cheap catback
I believe you could switch over to like a 2.2 ecu from a 96 impreza??
This would be a very torquey setup...
subi400 is offline   Reply With Quote
Old 07-06-2013, 07:05 PM   #6
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
^^^ that is one of the builds I am thinking about.
Old 07-06-2013, 08:52 PM   #7
walhalla
Member#: 333084
I like the EJ25D swap with keeping the auto. Cheap, fast enough and reliable.
walhalla is offline   Reply With Quote
Old 07-06-2013, 11:03 PM   #8
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
I run a 25D block, 22E single port heads, 200 grind cams with the SLAs, MSD coil, GS phenolic spacers, williaty intake, single port 2" UEL, 370cc JECS injectors, and PP6 piggyback fuel management tuned by Pre.
Spanks on WRXs out of the gate, but lacks that top end that a spinny whirlygig offers. Sounds beastly too, perfect power for a GF chassis IMO, but I'm pulling it out to swap (And selling it, shameless plug) an EJ205.
cal_look_zero is offline   Reply With Quote
Old 07-07-2013, 12:17 AM   #9
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I do alot of Subaru work but I haven't built a na monster yet so that is appealing to me. I also have a 2.1 stroker shortblock in the shop and was thinking of throwing nos on it since I have that laying around. IDK
Old 07-07-2013, 01:29 AM   #10
subi400
Member#: 216984
Green
If you want more info about my build then pm me
Old 05-25-2014, 10:49 AM   #11
Jasonkostyshyn
Member#: 391701
Hey I know it's somewhat off topic but I'm new to site and it won't let me post my own thread sooooo quick question I was wondering what parts I can use from other subaru models to help build my 1998 subaru legacy gt limited I just wanted to know for buying kits and looking at parts to put in the engine aswell as all around also I found less kits for my car and more for others so if I know what interchangeable then I can buy thenlooking for no mods to engine to make the parts fit
Jasonkostyshyn is offline   Reply With Quote
Old 05-27-2014, 01:46 PM   #12
mhanraha
Member#: 294087
Yeah I'm in a similar situation. I have a 2000 wagon with a 2.2 that's a beater.
Anyways it's leaking from the rear main seal, oil pan, and cam shaft. I'm interested in trying the 2.2 heads on a 2.5 block, any idea how much this would cost?
mhanraha is offline   Reply With Quote
Old 05-28-2014, 07:53 AM   #13
98legacywagon
Member#: 392044
Ej25d
98legacywagon is offline   Reply With Quote
Old 05-28-2014, 10:09 AM   #14
mhanraha
Member#: 294087
So I'm starting to toy with the idea of doing this work myself. I've replaced my CV Joints, struts, the starter and some misc. sensors on the car. How hard would it be to do myself?
So to do the oil separator plate/main seal I'd need to pull the engine which I've never done before.
What else would I need as far as tools?
Old 05-28-2014, 08:40 PM   #15
James2.5i
Member#: 305063
2016 VDUBBB
Do you have to do anything? I'd just try to keep it as reliable as possible so you don't get stuck on your next fishing trip or mud run.
James2.5i is offline   Reply With Quote
Old 05-28-2014, 08:50 PM   #16
02bugeye27
Member#: 392104
Cool !
02bugeye27 is offline   Reply With Quote
Old 05-30-2014, 01:00 PM   #17
Back Road Runner
Member#: 60082
2004 Forester STI
Why not an EG33 swap? If you want to play NA, play with displacement. Also the flat 6 exhaust note is sexy. EG33s are cheap, make good power, and are rock solid. You'll do a little fab work and have to run an aftermarket ECU, but you'd be doing similar with a hybrid setup anyways.
Back Road Runner is offline   Reply With Quote
